OK boys and girls, absolute last photo update before I call this one done. This has to be one of my favorite parts of the build.....The Wash!!! Just seems like it comes alive at this point. I use a homebrew mix of Non-waterproof India ink, water, and a drop of dish soap. This costs about 2 bucks and will literally last a lifetime!!! So easy to apply and even easier to remove!
Here is the ink I use, picked up at the local Hobby Lobby
and the bottle I use to mix it in. If I had to guess this was mixed at 1/3 ink and 2/3 water with a drop of Dawn dish soap added to break the surface tension and allow it to flow.
Then just slather it on. No need to be particulary OCD about it
And removal after about 5-10 minutes of drying. It consists of mostly a folded paper towel and q-tips. Slightly dampened with most of the water squeezed out and just start lightly rubbing. I usually try to move perpendicular to the panel lines and not parallel. And voila!!
One quick question though as my refs are limited and what I have contradicts the Eduard drawings. On the lower cowling where its painted yellow, was there a panel line that ran from front to back down the middle? Did this split open there like Matts 152 and swing upwards??
Thanks for the info and taking a look! If you see something I have missed by all means let me know!!
