Hi guys,
OK, it's been a while since I've done an update with photos, so I'm taking a break from the vlog to show you some shots of where I'm at.
Right now, I'm in the process of buttoning up the front end. As I have been warned by multiple parties (Chuck Davis haunts me in my sleep, calmly telling me to test-fit everything), I am test-fitting everything and proceeding at a pace that would make a snail cast its eyestalks down in shame.
I attached the chin and radiator today, and I was able to get the water pipe from the radiator to the water pump in back. However, I haven't glued the chin cowl to the radiator yet. In this pic I'm test-fitting the cloth panel that I'm using for Otto Creutzmann's D.VII. Because it is supposed to be an extension of the cloth covering the rest of the airframe, the gap will be filled and smoothed over.
I've glued the panel behind the chin in place. I'm a little concerned about the gap between it and the cloth panel on the side. I haven't been able to find any references to show me how pronounced it was on the actual aircraft.
Here I'm just showing the water pipe running to the water pump. Also, you can see that I have added the cover over the fuel tank and magazine. That was a very tight fit, and there is the tiniest gap made more pronounced in the pic by some black paint. I was using rubber bands to hold the panel in place and the liquid cement followed it due to capillary action. Needless to say, I have some clean up to do there.
So, the plan is to fit the sides on working forward. I'll finish and attach the muffler before gluing the starboard forward panel in place. Then, when the sides are where they need to be, glue the radiator, chin cowl and upper covers in place.
Who knows? Maybe next week, I'll get paint on her.
You guys have been doing a great job. Again, congrats to Shiv--I can't tell you how cool it is to see that badge in your sig line!
You guys have a great weekend. I'm going to see Ironman 3!
