1/72 O' Mania!!!
    November 2003
Posted by tempestjohnny on Saturday, June 1, 2013 11:51 AM
This working for a living is seriously cutting into my modelling time. Haven't been home before 7:00pm all week. today it 9:00. I don't want to start decaling my builds and fall asleep at the bench. John
    March 2011
Posted by Taps88 on Saturday, June 1, 2013 8:12 PM
Are cross overs welcome? I will be doing a Minicraft 1/72 B-24J Liberator - The Dragon and His Tail for the Natural Metal Finish GB, I haven't started that yet. Looks like there will be plenty of time.
Eric / Formally known as Erock68
On the Bench:
Academy: 1/72 B17 Memphis Bell
Tamiya: 1/35 Panther G
Dragon: 1/35 Platformwagen SSy
Posted by Bish on Sunday, June 2, 2013 2:30 AM
Taps, my build is a cross over, so i think your ok.
    March 2011
Posted by Taps88 on Sunday, June 2, 2013 8:13 AM
Bish
Thanks Bish, I guess I'm in then.
Here's my kit:
On the Bench:
    October 2010
Posted by Dogfish_7 on Sunday, June 2, 2013 9:00 AM
Acquired a Reference copy of the WC-51 with 1:72 decals included. Airbrushed the chassis and body with AK Yellow Primer.
Bruce
Posted by Bish on Sunday, June 2, 2013 10:28 AM
Looking forward to seeing how that builds up Eric. I have the Hasegawa version of the kit with those markings, so will be nice to compare it.
Bruce, that's looking good.
    April 2011
Posted by tcepilot on Sunday, June 2, 2013 9:08 PM
Ok I'm back guys, very sorry for not updating regularly. Anyway I'm back on the bench with the Vietnam Air War GB. I will update both threads.
-tcepilot
 just make a gif here
    April 2005
Posted by taxtp on Monday, June 3, 2013 12:19 AM
Welcome back Tcepilot !
I'm just taking it one GB at a time.
    March 2011
Posted by Taps88 on Monday, June 3, 2013 2:05 PM
Bish
Bish,
To be honest, this is one build that I'm worried about. In the past, I have done Tamiya's 1/16 Tiger 1 RC, with a ton of add-ons and photo etched parts. The kit alone, was big $. I am more concerned about this build.
This Liberator is also in the NMF GB. I have never done one...............yep, never.....ever!  I was too afraid of messing up.
Well, the time has come to learn some new skills, which I why I bought the kit, in the first place.
The past few days, I have been doing research on NMF and really not sure what paint to use. Alclad and Tamiya sprays have my attention. Although, I'm an airbrush guy, I like the control. Not sure how good of controlled coverage, I can get with those Tamiya sprays.  I have also read that, you have to make sure that your construction is almost dead on. No forgiveness with the metal finish. A tough task when doing a bomber.
Seems like no pressure at all....Wink  I'm up for it though. Like I posted in the other GB...Go big or go home!
On the Bench:
Posted by Bish on Monday, June 3, 2013 2:12 PM
I admire you for doing this as your first NMF. I have been working up to larger NMF builds using Alclad. I do like the results, but I have found it tricky to use. Of the 3 builds so far, all have things I am not happy with. I want to practice more on some smaller builds before I do something big. The construction does have to be spot on when using Alclad at least, it will show up any mark or scratch.
    April 2013
Posted by SchattenSpartan on Monday, June 3, 2013 2:32 PM
Don't worry to much, Eric! I'm sure you are able to pull this off! I can only recommend the Alclad paints. They are perfect for airbrushing (you don't even have to thin them down) and produce a nice finish when you do it right. The tricky part should be getting the surface nice and flawless (any mistake will be visible when painting a NMF scheme) and getting a nice base coat. You want the surface and the basecoat as smooth as possible, or you'll end up with a very dull finish (which looks good on some models though)
I've only done a single NMF bird before, so my builds for the NMF GB are going to be as challenging as yours Wink
Cheers, Clemens
    March 2011
Posted by Taps88 on Monday, June 3, 2013 4:43 PM
Bish / Clemens,
Thanks for the vote of confidence!
I will not be running through that build quickly at all. So, I will be extra careful.
Now, Bish, What problems did you have with the Alclad? If both of you have any pointers, please let me know.
Either let me know here or message me PLEASE!
On the Bench:
    April 2013
Posted by SchattenSpartan on Tuesday, June 4, 2013 7:54 AM
I have another tipp for ya, mate! Don't ever use Alclad's microfiller as a base coat! You will end up with a dull finish, no matter what you do about it.
    September 2003
Posted by checkmateking02 on Tuesday, June 4, 2013 9:42 AM
Eric:  you could also consider Floquil model RR paints.  I haven't used Alclad and once I tried Testors MM Aluminum, but didn't care for the results.
Anyway, for an example, here is Academy's original B-17C, done up with Floquil some years ago.
The problem on the horizon is that Testors acquired Floquil a while back, and recently announced discontinuing that label along with the Polly S brand, so I don't know if the same paint will be available under the Testors brand.  Currently it's still available, and Floquil's silvers come in three varieties:  Platinum Mist, Bright Silver and Old Silver.  I can't tell them apart, though, once they are on the model.
As with any metallic finish, you still have to be sure to remove all scratch marks, sanding marks, blemishes, etc., since they show up really well.  Usually it means polishing the plastic.  For that, I just use toothpaste.
The Douglas Devastator I'm working on for this GB had a NMF interior, and I used Floquil there.  I just haven't gotten around to posting any photos.
Whatever you end up doing, practicing first with a new technique on something that doesn't matter is a good thing to do, rather than risk ruining the major project.
And good luck to you!
    March 2011
Posted by Taps88 on Tuesday, June 4, 2013 11:23 AM
checkmateking02
That's a nice looking build!
One confusing thing, that I have run into with researching this: some people say the base coat has to be gloss black, others say not necessary. Any advice? Does it (gloss black base coat) matter on which brand of paint I ultimately go with?
I've also read that people normally mask with post-it notes..so any masking tape or painters tape, is out of the question?
***EDIT*** I have something in my stash, that I started working on this afternoon. It's an old Testors F2H-2 Banshee. This will be my test subject. It's not 1/72 but will give me an idea of what I'm doing, for the NMF:
On the Bench:
    April 2013
Posted by SchattenSpartan on Tuesday, June 4, 2013 12:23 PM
checkmate: that's a nice NMF bird! I like the look of it, although I still prefer Alclad for NMF...
Eric: You don't have to use a black base-coat, although it gives you the best results. The only really important thing to do is to get a nice and even coat on your model. Tamiya's gloss black (TS-14) works really well, if you spray it on with an airbrush...
You should have a look at this
I got this link from Cliff (Gamera). That is how I'll try to paint my big Mustang for the NMF GB. I won't use that exact paints on my Thunderbolts though, because I want them to be (only a little bit) less shiny to look more rugged...
I hope I could help
Cheers, Clemens
Posted by Bish on Tuesday, June 4, 2013 1:45 PM
Taps88
Bish / Clemens,
I think the problems I had were all self inflicted. I have heard a lot of good comments about Alclad, so I am sure it wasn't that. I use Humbrol black gloss as an undercoat. On the first one I didn't polish it, and when I polished the Alclad, there was a few lumps and bumps in the black and those came through. On my second build I masked some of the panels to give them different shades and when I lifted the tap some of the Alclad came up. I think someone suggested I may not have left the black long enough to sure. On the final one, some patches of Alclad bubbled up. I may have had some airbrush cleaner residue left in the airbrush. So with all these lessons learnt, hopefully my next attempt will be a good one. I might be doing a MiG for the NMF GB, if I can fit it in.
    September 2003
Posted by checkmateking02 on Tuesday, June 4, 2013 7:54 PM
Erich:  when using Floquil I just paint it over the bare plastic.  It doesn't need any kind of undercoat, but it seems some finishes do.
    September 2003
Posted by checkmateking02 on Tuesday, June 4, 2013 7:58 PM
Sorry I missed your question about masking, Eric.
Again, I can only speak about the Floquil.  It's pretty tough.  I thin it with lacquer thinner, in about a one-to-one ratio.  Once it dries, I use regular painters' masking tape, with a low tack, and usually it doesn't pull up.  I do let it cure a fairly long time--maybe a week or two, just to be sure.
NMF's can be fragile.
    September 2003
Posted by checkmateking02 on Tuesday, June 4, 2013 8:00 PM
Bish
Taps88
Bish / Clemens,
As it goes with a lot of what we do modeling, there's a learning curve where you kind of mess around and try things, until you find a system that seems to work.
And then, the manufacturers change things, and we're back where we started.
    June 2013
Posted by Torque92 on Tuesday, June 4, 2013 8:23 PM
Since today is June 4th, I will enter this GB commemorating the Battle of Midway's 71st anniversary with an A6M2 Type 0, and a Douglas SBD Dauntless. Additionally, since June 6th is just around the corner I will also do a C-47 in honor of Operation Overlord.
    April 2011
Posted by tcepilot on Wednesday, June 5, 2013 4:15 PM
Torque92
Sounds great! Welcome to the Build! Okay so today I was looking at an old 109 I built awhile back and came up with this idea...
   ... Check up with me at the Vietnam Air War GB. I just extended it for another year.
-tcepilot
    September 2003
Posted by checkmateking02 on Wednesday, June 5, 2013 6:35 PM
That is a nice looking pile of scrap, tcepilot!
    April 2005
Posted by taxtp on Saturday, June 8, 2013 5:15 PM
This week I started on this thing. I plan to do the aircraft depicted on the box top.
Firstly I cajoled a Pavla resin bang seat to fit into the cockpit.
Basic construction goes pretty well. The difficult seams are around the nose cone, the intakes and the rear fuselage.
I replaced the pitot with Microtube.
Tamiya aerosol fine white primer. The first coat revealed that I need to work a bit hard on some seams.
Finally got some of the yellow down. It's Gunze #4 yellow as recommended by the kit instructions. I love the lines of the Draken, seems to me that it looks how a jet fighter should look.
Cheers
Tony
    September 2003
Posted by checkmateking02 on Sunday, June 9, 2013 12:26 PM
Really nice-looking, Tony.  The yellow is very eye-catching.
Posted by Bish on Sunday, June 9, 2013 2:45 PM
Looking good Tony, I do like the yellow.
How was the pavla set.
    February 2011
Posted by gunner_chris on Tuesday, June 11, 2013 11:44 AM
That yellow is very catchy - looks good.
I'm still trying to truck through my CF-18, buts its being painful in the seams.  More gaps then I like to fill......
    March 2011
Posted by Taps88 on Thursday, June 13, 2013 3:59 PM
Looking good, Tony!
That is going to be an eye catcher for sure!
On the Bench:
    October 2010
Posted by Dogfish_7 on Thursday, June 13, 2013 4:21 PM
You Guys are doing Fantastic!! Did some painting on the Dodge WC-51.
Bruce
    November 2003
Posted by tempestjohnny on Thursday, June 13, 2013 6:45 PM
Wow you guys are doing a great job. I've got to get motivated. work is killing me.  John
