1945 GB
    February 2010
Posted by EBergerud on Saturday, January 30, 2016 11:01 PM
I've had dicey experiences with Ammo products. If you want to fix pigments you can dispense with MIG etc (although MIG Pigment Thinner and Fixer are both perfectly good) and save some money. Pigment Thinner is basically ISP - it will attach pigments, but it is possible to remove them pretty easily. MIG is $6 for a little bottle - ISP is about $2 for a huge bottle at a drug store. MIG Fixer is some kind of mineral spirits - another product available at a bargain - but it changes the color of the pigments and they won't come off. One MIG product I do like is their "MUD" which is the best wet effects mud I've seen. I can almost duplicate it with pigments mixed with some kind of clear (Pledge works) and maybe some matte acrylic paint or an artist gel/medium/paste. (I dislike plaster very much - it changes the mud color greatly.) But MIG Mud looks like mud - it comes in three different colors and each in coarse/fine texture. You could alter the color a little with acrylic paints (water based only like Vallejo Model Color or Golden Fluids) or leave it alone. Well worth a try anyway. BTW: I'm beginning to use pigments for more purposes than before - it's excellent for fading and even panel lines. Oh pigments themselves - they go a long way so maybe MIGs are worth it. For my money go to an art store and get artist pigments by Sennelier or Gamblin - they're much cheaper per volume and are of the best quality available - they're made for looney artists that like to make their own paints and that's a picky crowd. You only need five colors to duplicate anything: white, black, ochre, umber and sienna.
Eric
A model boat is much cheaper than a real one and won't sink with you in it.
    October 2004
Posted by ygmodeler4 on Monday, February 1, 2016 6:52 PM
EBergerud
Josiah,
I hope you don't mind some criticism. I think this is part of the group build process, and let me emphasize that everyone has only a point of view but never the solid truth. (Unless you think Spitfires are better looking than Zeros: if you do, then you're wrong.)
Your Mo was a very good and very clean build. You did a good job with Measure 21 which can be easily botched. And there is no such thing as an easy ship. But I think a good build could have been better.
1. Rig the ship. Check out YouTube or probably a few hundred articles on this board much less Model Warship on how to approach it. I'd say that simple is far better than none. Maybe a dozen lines connecting masts to hull, or masts to masts, (the variations are endless) will make a huge difference. Use whatever line you'd like. Depending upon scale I'd using fly fishing tying line, but mono works: so does very thin sewing thread. In the real world WWII warships' rigging varied greatly depending upon the situation and weather. Also, in the real world, you can't really see rigging clearly from a distance. But it's there and you can see something. I like simple knots (like single cross) and ISP or CA, but others use stretched sprue. It doesn't mean that many, but it will change the look of your model a lot.
2. Railings: Ship loonies spend tons of money on PE. (I've just spent $80 on a super PE/wood deck set for a 1/700 Flyhawk Derfflinger and think I might be nuts.) Is this worth it? Ship loonies are even more detail oriented than armor loonies, but the answer is no. I've hung out with my betters on Model Warship for some years and have concluded that three things are true. A.) A ship can be made out of the box if rigged. B.)Railings are easy, cheap and almost essential. You can get generic railings for any scale ship for under $10 - well worth it, but I think it's fine to skip PE catapults, boats etc that will cost you money and lots of time. But the railings you see - like the rigging. Other stuff you don't.
3. Masts: completely optional. Meister uber-builder at Model Warship is Jim Baumann - if there's a better warship modeler in the solar system I've never heard of him - does everything - all scales, scratch, resin etc etc. He does argue that you should duplicate masts in styrene models with brass/metal. Easily done actually. Brass masts/yards are much easier to rig even if you sacrifice a tiny bit of detail.
4. I've done a lot of work on water bases and like your idea of lentils a lot - I've done similar things with oat flakes and it didn't work as well. However, there's a step between texture and color. No matter what you base is ultimately made of (oat flakes, plaster, lentils, whatever) it must be covered by some kind of white paper. (Unless the base is thin, hard and flat and will be covered with a white acrylic.) I think Flodman on Modelwarship is right that you should cover a surface with ripped up typing paper - stuck with thinned white glue - and then put the paint on top of that. Pretty easy (especially if in small bits) and the resulting paint will be the color you want it.
Anyway, fine model and keep making ships.
Eric
Eric thank you! These suggestions are very helpful! I still need to put the planes on the catapult so I will have a go at rigging it too. I won't be able to put any railings on this time, the model is a Lindberg 1/900 scale and after a quick search I did not find any PE railings. (Though I'm not sure I would have the patience for anything PE in that size even if I did find some). Thank you for all the critiques and everyone else's too!
-Josiah
    February 2010
Posted by EBergerud on Tuesday, February 2, 2016 2:16 AM
Didn't realize it was 1/900 - must be an old kit. So even generic 1/700 railings would look too big. Try it with the next ship. Generic railings in 1/700, 1/600 (Airfix ships essentially) and even 1/350 are very inexpensive and will improve the ship greatly. It's also something you can see. I think railings are easy - you'll probably have more trouble getting them off the sprue (easy to do but you have to look very carefully and press down with a hobby knife, don't cut across) than putting them on. To get them on I use the all time greatest non-Tamiya glue available - Aleene's Tacky Glue which you can find in most hardware stores and any craft store. It'll grab the light pieces of rail (maybe 1-2" long) like a magnet on the hull. Then put some very small dots of super glue so it will set fast. If you like ships and get used to them, basic PE like ladders, hatches and walk-ways will become a natural part of the arsenal. Who knows, you might end up plunking down between $15-$150 for full PE sets. I model every military subject, but must admit that a well made ship is something special (and time consuming).
For rigging you'll want a very thin thread at that scale. I strongly suggest finding waxed threads: fly tying lines (like a standard 6/0 or thinner like 10/0) are very good and easy to work with. I think some sewing threads are waxed but if you have an outdoors shop that sells fishing supplies, they'll have tying line in lots of sizes. Hard core prefer incredibly thin threads that are beastly hard to work with and almost invisible from 5' away: I don't see the point. You can also use stretched sprue. Go on the forum of Model Warship (the best ship modelling site on the planet), and near the top of "Tips & Tricks" uber-meister Jim Baumann shares his very simple method of mass producing stretched sprue - far easier and effective than most modellers' methods. (BTW: a useful skill for both planes and armor.) The advantage of waxed lines or sprue is that you can light some incense (Baumann's post on sprue shows this too) and pass the warm smoke under the rigging and the line will tighten up almost by magic. 1lb or 2 lb test monofilament fishing line (not tying line - much thicker) is terrific for rigging a biplane, but is out of scale on ships and is actually pretty hard to deal with on thin masts as opposed to the turnbuckles or holes used in bipes. For cutting rigging line expensive scissors aren't necessary, but the shorter the blades the better - Squadron makes a pair for about $5 with big handles but 2" blades. Stuff like that saves a lot of time and gives better results.
Eric
    October 2004
Posted by ygmodeler4 on Tuesday, February 2, 2016 8:40 AM
Thanks!!
-Josiah
    January 2015
Posted by Moff on Friday, February 5, 2016 8:20 AM
Hey, thanks everyone for advising me to persevere in connection with the DshK! It looks nice and matches the tank perfectly! I'll upload some pics (hopefully) soon.
"Gaiety is the most outstanding feature of the Soviet Union." - Josef Stalin
    January 2015
Posted by Moff on Thursday, March 3, 2016 6:34 PM
Moff
...Yeah, well, so much for soon. I know this GB is closed and the thread is dead, but I thought I'd upload some pics of the DshK.
FINISHED DshK Left Side #13FINISHED DshK Left Side #12FINISHED DshK Left Side #11FINISHED DshK Left Side #4FINISHED DshK Front Focus #3FINISHED DshK Front Focus #2FINISHED DshK Front Focus #1FINISHED DshK Front Left #4
Posted by Bish on Friday, March 4, 2016 12:48 AM
Thats real nice Moff,  grat to see it done.
    August 2009
Posted by JOE RIX on Friday, March 4, 2016 7:17 AM
Oh Man Moff, That turned out great. Your time and patience certainly paid off. Excellent work.
I'm afraid I have not laid hands on my P-47 in the past couple of months. The remodeling continues. Although, I have got all moved into my new digs and I'm rather pleased with how much of my stuff I got packed into my smaller space. It's cozy but quite nice. I'll get some pics here soon for you. Still have at last a couple of more weeks to goto get the rest of the flooring in the house. Hopefully, I'll be able to resume with some bench time soon. Cheers.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    March 2012
Posted by mustang1989 on Friday, March 4, 2016 7:29 AM
Not part of this GB but thats awesome work Moff. Great detail!!
 Forum | Modelers Social Club Forum (proboards.com)
    October 2009
Posted by greentracker98 on Friday, March 4, 2016 12:35 PM
Sorry everyone Its been a little while since I've bee in. I had my "new" computer die. and I have to send it in to get fixed. Win Vista doesn't work here anymore. I'm using Mozilla Firefox until I get my new computer back.
Okay, My 1945 dio may be a little while longer. I'll get it finished asap. I've backed out of the Boeing build now. I can't afford the aftermarket parts I need right now.
I just had to have a starter put in my car. so, now I owe the garage $200.
I think the funk I was in is caused in part by trying to do too many builds at the same time
Good luck on everyones builds. They all look great.
A.K.A. Ken                Making Modeling Great Again
    October 2009
Posted by greentracker98 on Tuesday, April 5, 2016 10:32 AM
Hi all,Sorry for not getting an  update in.
Anyway, I have ordered a verlinden cobblestone section and should have ir in a day or two. I'll finish my build as soon as I get the cobblestones.
Thanx
Posted by Bish on Tuesday, April 5, 2016 12:05 PM
Look forward to seeing that Ken.
    January 2015
Posted by Moff on Monday, April 11, 2016 8:47 AM
I've learned some important things from this GB. Apparently, the end date is quite flexible, and no one kicks your door down in the middle of the night if you don't finish in time. Big Smile
Posted by Bish on Monday, April 11, 2016 3:58 PM
Moff
Well, i certainly don't, and most GB hosts seem to be happy for it to carry on after wards. My general view is that any builds started before the end date are free to carry on posting after the GB is officialy over. There has to be some cut off other wise it could just drag on for ever.
    January 2015
Posted by Moff on Wednesday, April 13, 2016 8:17 AM
Bish
Moff
Good. Though I feel I may have been more lazy if I wasn't mortally afraid.
    November 2010
Posted by Eagle90 on Monday, November 28, 2016 12:43 PM
Hey everyone, As you might know, I had a life changing thing happen and I was not able to finish this GB.  Well, I'm settled down after the event (well, as much as possible) and have gotten back into building again.  So, I guess as they say...better late then never.  Here she is.  The 234/4.  I included a family pic.  I have done all versions now.  Love the 234!  Enjoy.
Eagle90
Posted by Bish on Monday, November 28, 2016 1:21 PM
Nice job Bobby, really did this one justice, and glad you liked it. Welcome back.
    November 2010
Posted by Eagle90 on Monday, November 28, 2016 1:27 PM
Bish
Thank you sir!  It was an awesome kit!  The detail was mind blowing.
The "family" pic is so cool!  They just look like trouble don't they?  LOL!
    August 2009
Posted by JOE RIX on Monday, November 28, 2016 6:59 PM
Oh Man Bobby, I love your 234's. They are quite fantastic. What scale are those? I, too, am a huge fan of the 234 and hope to get a Puma (I have the 1/35 Dragon) and a 234/4 built one day. You've certainly given me some inspiration with your fantastic family. Thanks for taking the time to get back and share them. You are the man!
    November 2010
Posted by Eagle90 on Tuesday, November 29, 2016 5:52 AM
JOE RIX
Hey Joe,  They are pretty cool pieces.  They are 1/35.  The 234/4 I just did is a Dragon kit.  Be ready!  They are uber detailed!  Well, at least to a novice armor builder.  LOL!  It was amazing the detail in the Dragon kits.  Beautifully done I must say!  Coming up with a different camo for each was fun too.  I'd love to do a couple of dios with them!  You line them up like in the pic and man....TROUBLE!  Devil
The other kits I did of the 234's were Testor and Italeri kits.  They were very nice too, but no where near asa detailed as the Dragon kit.  The Dragon kit gives you so many options too.  Open or closed windows!  Open or closed engine vents.  Very nice accessories (MG's, MP's, tools, etc.).  The wheels and tires along were amazing!  You will enjoy that kit for sure!
Eagle90
    April 2023
Posted by deja-view on Friday, April 14, 2023 6:18 PM
So, this thread just ended in 2016, and no one added anything since then??
    April 2006
Posted by jgeratic on Monday, April 17, 2023 12:20 PM
A Group Build on average lasts one year and this one actually ended 2015 as set out on the first page.
