Finally got started on the engine today and got a few thing done. I'm still waiting on a couple of parts I ordered to come in. Pulleys, carb, oil filter and a few other things for the engine. Got some paint work done today and started some of the assembly.
I've been using Maskol by Humbrol instead of taping up areas that might be sensitive to paint that hasn't cured all the way. I primed the engine pieces yesterday, painted them and assembled them today. Maskol really creates a great tape line without worrying about pulling up any of the paint. Here a few pics to show you what it looks like.
Engine primed and the transmissions covered in Maskol with a paint brush. It takes about 10-15 minutes to dry:
This is what it looks like after two coats of Chevy engine red acrylic. I peeled off the Maskol about 10 minutes after it was painted. Acrylics dry to the touch pretty fast, so that helps, but it peels off really easy and won't permanently stick :
Maskol peeled off:
After letting the Chevy engine red dry for another ten minutes or so (20 minutes total), I painted Maskol on the entire motor, except the transmission and painted it with Model Master Metalizer aluminum and sealer, then let it dry for 10 minutes or so and then peeled the Maskol off:
A couple more pics of the separation lines using Maskol:
Anyhow, if you hate trying to mask off the engine and transmission, or other similar parts while painting them, Maskol is very easy to use and very effective at creating a very nice and clean line.
Tim
