Thanks, G and B!
Bish, I used Ye Olde Hairspray Method. You paint the base coat, then spray on a couple of coats of hairspray. Let dry for a few minutes, then apply the top coat (which in this case was the stripes, and using acrylics apparently works best). After the top coat is dry, you brush on some water and let it set for a few minutes (this loosens up the paint). Then I used a detail brush and toothpick to pick out the chips. Works pretty well.
