Thanks Gents!
A short update...........
Got the Type 92 7.7mm MG done. I used a new #11 blade to carve the forward and rear grips and trigger housing, and made a trigger from stretched sprue and a trigger guard from sheet brass. The barrel was drilled out and cut off those two telephone poles supossed to be sights and replaced them with stretched sprue. Used a small brass strip to make the drum handle and glued it with CA.
Here is the kit gun:
and after my modifications and detailing:
The rear sight uses a ring type and it so happens that I missplaced a pe one i have and can't find it so Ebay is the place to look. Found a set there so hopefully it will be here soon.
