Well gentleman, I have not posted anything for over a month now. So here is an update. I changed from the Paddy Wagon to the M-4 Screaming MiMi. I asked if it was OK and I did not see anyone say no so I switched, anyway here is the progress
This build went pretty fast. The only issue I had was with the rocket tubes, that is attaching them to the turret. I ended up having to cement the main gun in position because the rocket launcher kept depressing the barrel.
Decals were next and they went without a problem.
Then I began the weathering. This is one area that I feel I need to work on.
During the process of weathering I used rubbing alcohol to thin the craft paint I use. That is a big mistake if you use future for the gloss coat. The alcohol attacked the future and caused the future to cloud up. You can see a little bit of this on one of the rocket tubes. I used a large flat brush and applied a thin coat of future and the cloudiness went away.
I went to the spares box and found some goodies I thought would look good on the front of the tank. The plank is a popsicle stick cut to size and distressed.
The kit came with three figures. I modifed one to occupy the left hatch, he is the one that had the M-1 carbine. To me he looked goofy in that pose so I figured he would look better in the tank.
Here it is completed. I just realized that I did not muddy up the entire track. I will go back and do that and add that picture. Over all this kit was fun and easy.
