Japanese Group Build VII
    March 2015
Posted by Toshi on Thursday, January 18, 2018 2:57 PM
plasticjunkie
You are welcome Toshi. Carzy how just about each Japanese aircraft company had "their" own colors. I'm not a stickler on a "correct" color but try to get as close as possible. I think they called it Kawasaki tan or something like that. And by the by, the wheel wells and doors should be the same tan. Some of the later KI61s had them in NMF.
Looking good Toshi.
Yes, having such diverse colors of; “Each Japanese aircraft company”, makes things very interesting for modelers throughout the years.  And yes, I saw that the wheel wells, doors, and the cockpit is that Kawasaki Tan Color you showed me how to mix.
I googled “Tamiya 1/48 Kawasaki Ki-61 Hien Tony” and got over a hundred pics of other modelers rendition of their Tamiya Hien and I found a general look and color scheme of their builds to compare with what you recomended.  And you were accurate with your color renditions.
I will continue to research this build online to the best of my abilities.  I still am interested in how the mottle will look when I get to that point, I also checked out a couple of my previous builds with mottling.  My Revell 1/48 Me262 and also my Tamiya 1/48 Phiel to use as references.  And I do have a sense of direction in which I want to go with.
I also find it most interesting and a challenge to do the Hien in a NMF then AB the mottle on top of that.  Then there’s the red tail with the black out and the blue stripes with the Hinomaru.  It makes this build a particulary interesting color scheme.  A colorful one at that.
Your friend, Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
Posted by Gamera on Thursday, January 18, 2018 3:17 PM
Toshi: Again looking good! A very colourful aircraft, I've got to get around to building a second hopefully more successful one! That mottling is a pain to get right.
PJ: Lol, great episodes. I'm partial to 'The Architects of Fear', 'The Chameleon', 'Wolf 549' and 'The Inheritors' as well.
I went back and watched 'The Invisible Enemy' when Adam West passed away last year.
I'd recommend the series 'Thriller' but you've probably seen all of them!
    November 2008
Posted by plasticjunkie on Thursday, January 18, 2018 3:59 PM
Cliff
Forgot Wolf 359, love that one too. Did you know there is an actual star 7 light years away from us with that name? Yea Robert Culp was great in The Arcitects of Fear. Remember Bill Shatner in Cold Hands Warm Hart?
Toshi
That mottling will test your patience for sure but fun none the less. I thin down my enamels and set the AB at low pressure, about 8 psi and carefully scribble away.
 GIFMaker.org_jy_Ayj_O
    March 2015
Posted by Toshi on Thursday, January 18, 2018 4:10 PM
plasticjunkie
Cliff
Toshi
Thank you, will do with 8 psi.
    March 2015
Posted by Toshi on Thursday, January 18, 2018 4:11 PM
Here’s what I’ll end with today.  My grandson should be here soon.  lol!
    November 2008
Posted by plasticjunkie on Thursday, January 18, 2018 4:29 PM
Toshi
Each AB is different and so are the paints. You have to experiment with the thinner to paint ratio and psi at your end. Usually with acrylics a higher PSI may be needed to cycle the paint.
    March 2015
Posted by Toshi on Thursday, January 18, 2018 5:02 PM
plasticjunkie
Toshi
Yes, Thank you for the reiteration.  I’m going to use either my Iwata Eclipse or my NEO for Iwata TRN1 trigger AB.  Interestingly they both have the same nozzle size (35) yet they react differently.  The Eclipse is very sensitive to paint drying at the nozzle tip at low psi as oppose to the TRN1.
The TRN1 can shoot at low or high psi without drying.  Also the trigger AB is very ergonomic due to it‘s trigger handle.  I might just stick with the TRN1 for the camoflauge and use the Eclipse for the NMF.
For the NMF, I’m going to use Vallejo Metal Color Chrome 77.707.  It’s premixed and shoots extremely well and has a nice finish.  I used it on my Academy 1/48 P-38 Lightning.  I really liked the finish of this particular paint.  Thank you once again!
Your friend, Toshi
Posted by Gamera on Thursday, January 18, 2018 6:17 PM
Toshi: You're moving right along. Good luck with the airbrushing. Not sure how I'd do the mottling but after the 262 you've got plenty of practice.
PJ: Yeah 359, I'm friggin' dyslexic or something today. Yeah, real thing and the Star Trek: The Next Generation guys grabbed that star from the episode for the Borg battle episode. Somebody made a nifty line of Outer Limit figures about twenty years or so ago. Would be cool for someone to get ahold of the molds and reissue them.
Posted by Gamera on Thursday, January 18, 2018 6:21 PM
And btw guys you've probably all already seen this but Steve/ModelCrazy is getting the report back from the donor for his transplant so if you guys could remember him in your thoughts and prayers please.
http://cs.finescale.com/fsm/general_discussion/f/50/t/177731.aspx
    October 2008
Posted by Rigidrider on Thursday, January 18, 2018 7:38 PM
PJ, gotta get in on this one... One of my favorite TZ was when the WWI pilot went forward in time, then tried to get back! The episodes you mentioned were (for the time ) stellar. TZ, OSB, TOL.... when I was a kid, thats all we talked about the next day in school! So many good memories...
OK, as to the paint color... when I was researching this aircraft, man, I found the standard JA green, Brown, Grey, and to my surprize Yellow, Yellow Orange, Red, and The Blue I chose to do. Being I had decals to do the Blue unit of the 16th Chuti I picked it. The way I got the color where it looked like the picture, I mixed Tamiya Dark sea blue with Tamia Blue until i thought is matched.I would put a drop on a paper and dry it w/ a hair drier and blend more if I had to until it looked the same.
Toshi... I had never seen this one either. My wife bought it for me and brought it back from Japan on her last trip there. I was happy she did because I figured that Cliff would be starting his FB soon there after. I havn;t bought my Tony yet, but I've begun the search. I think the guy I know at Hobby Town said that Hasagawa was releasing a new one soon... I think.
Cliff... I was unaware that Steve was transplant need. I am so sorry to hear that, and he will most assuredly be in our thoughts and prayers...
Thanks...Doug
When Life Hands You A Bucket Of Lemons...
Make Lemonade!
Then Sell It Back At $2 Bucks A Glass...
    November 2008
Posted by plasticjunkie on Thursday, January 18, 2018 9:18 PM
Doug, I had forgotten that one too and one of my faves. It's called "The Last Flight". Leftenant (Brit pronunciation)  Decker RFC  lands his Newport bipe in a USAF base in France in 1959. The only thing is that when he took off from his base was 1917! Is that crazy or what?
Man I love that blue shade and would love to do it the same way.
    November 2008
Posted by plasticjunkie on Thursday, January 18, 2018 9:20 PM
All the best for Steve. Will pray for him tonight.
Posted by Gamera on Friday, January 19, 2018 7:59 AM
Yeah, so many great episodes of those grand old shows!
Doug: Sounds great, looking forward to photos!
    March 2015
Posted by Toshi on Friday, January 19, 2018 10:25 AM
To rigidride,
Yes, this is a unique and very streamlined aircraft.  If you’re going to wait for the new release Hasegawa, I’d love to see it in a GB or a WIP in the Aircraft section.  I always do both just to keep everyone up to date.  Thanks for your information and support.
Your friend, Toshi
    July 2014
Posted by modelcrazy on Friday, January 19, 2018 8:38 PM
Hey Gam,
Put me down for these 2 as well. I'll start on these first before the Frank or Ha Go. You know I just can't do a coulple.
1/72 Hase G3M2/G3M3 Type 96 Nell
1/700 J.M.S.D.F. DDG Kirishima...."Hyper detail" = lots of PE!
Thanks
Steve
Steve
Posted by Gamera on Saturday, January 20, 2018 3:54 PM
Toshi: Your usual great work there on the cockpit!
Steve: Sure, just put you down for both!
    July 2014
Posted by modelcrazy on Saturday, January 20, 2018 4:20 PM
LOL thanks Gam, you know I'm your bigest Japanese GB fan!
Steve
    April 2006
Posted by jgeratic on Saturday, January 20, 2018 4:40 PM
Hi Toshi, welcome to the group here.  Look forward to that clear view aircraft build.
So the Claude I'm building was flying in 1938 during Chinese war.  As I understand it, no protective measures on the finish of these aircraft.  Apparently one of the metals that made up the light alloy was copper (4%) and it was this that invited corrosion.
I've basically airbrushed with aluminum paint, as well as some variations with both flat and white aluminum.  I couldn't use flory wash the normal way.  It would wipe right out of the engraved detail (too shallow?).  So I used only a few drops mixed in with a Vallejo umber wash.  I would wipe it off with a fingertip before it had a chance to dry.
Masking stage ... flat aluminum to seal the mask edges, followed with white, and then Italeri's Insignia Red.
Now to clean things up.  On the port fuselage, lost the top of the Hinomaru while peeling the tape off.  I noticed the tape was picking up the odd paint flecks overall, so will have to give a look over for touch ups.  Port wing Hinomaru also needs a little more paint - looks a tad pink, though digital makes it look worse.
regards,
Jack
    July 2014
Posted by modelcrazy on Saturday, January 20, 2018 4:48 PM
Looks fantastic Jack Yes. Just curious, have you built models before? Wink
Steve
    April 2006
Posted by jgeratic on Saturday, January 20, 2018 4:57 PM
Heya Steve, thanks.
Yeah, sometimes it feels I'm building for the first time, or is it not enough because of the road bumps experienced to the finish line.
Look forward to those builds, particularly the ship - lots of detail!
regards,
Jack
    November 2008
Posted by plasticjunkie on Saturday, January 20, 2018 6:22 PM
Jack
The nmf looks fantastic. That is a very good looking scheme indeed.
Posted by Gamera on Sunday, January 21, 2018 6:19 PM
Jack: Wow, very eye-catching! The NM and red look pretty darn good to me from the photos.
    July 2014
Posted by modelcrazy on Sunday, January 21, 2018 6:59 PM
I opened the Kirishima box today and was excited with the skill level of this 1/700 kit. I believe this will take some time to complete.
The instructions.
The sprues, decals and PE set.
I would be amiss if I didn't play to my strengths and put this in a water base.
Steve
    November 2008
Posted by plasticjunkie on Sunday, January 21, 2018 7:05 PM
At 1/700 that has ALOT of parts so looks like you have your hands full Steve. Your water feature will make this pop! Beer
Posted by Gamera on Sunday, January 21, 2018 8:53 PM
Nice! Looks like the standard Hasegawa quality!
    April 2006
Posted by jgeratic on Sunday, January 21, 2018 11:30 PM
Thank you PJ and Cliff.
Steve, that ship certainly has a lot of parts - it could pass for a 350 that has been shrunk down. What strikes me is the small details are not distributed throughout, as there are some very large clean areas besides the hull.
regards,
Jack
Posted by Gamera on Monday, January 22, 2018 9:41 AM
I wonder if I could find a 1/700th Godzilla head to go with one... Wink
    October 2008
Posted by Rigidrider on Monday, January 22, 2018 10:43 AM
Jack... Claude is looking better and better! Nice NMF!
Toshi... Not sure when that will be, but , You got it!  Look forward to building a Tony.
Well... I think I can call mine finished! All in all, a typical Tamiya kit, No issues to speak of, and a nice looking aircraft when finished. Here are the finished shots...
Canopies, props and such in place and some light weathering.
Almost forgot the fuselage band.
 The Fully Finished shots, Not sure about Pilot's personal markings, but I saw the rabbit on a decal sheet and since these were so fast... ehhh, why not.
Any way, As always, A fun build and good info here, always enjoy watching everyones progress and ideas come together, I have a couple more I'd like to do, and if OK, I'll be back in a bit! Thanks all!
Doug
Make Lemonade!
Posted by Gamera on Monday, January 22, 2018 11:03 AM
Doug: Wow, great job there!!! And congrats on having the first finished model!
I went ahead and posted one of your photos, if you want another let me know and I'll switch them out.
    April 2006
Posted by jgeratic on Monday, January 22, 2018 11:17 AM
Thank you Doug, and yes, that is an excellent build you have done here. Yes
Really like that blue scheme, not something seen often, at least I haven't.  Pro masking there too on the fuselage stripe.
regards,
Jack
