Today’s mid afternoon update.
First up, I finished the cradle and mount. The parts are for the most part nicely detailed, but mold seam lines are prominent and require lots of clean up. Thankfully, the plastic is on the softer side. Also some of the attachment points and directions for certain small parts are ambiguous. Test fit, check reference photos, test fit, check reference again, and test fit again, just to be sure, before applying glue.
anyways here is the completed gun on the cradle and mount
and a close up of some of the details on the mount...
Then, while the glue was drying there, I built up one of the Bronco crew figures and posed him with an Airfix 32nd scale figure... as you can see, they are fairly close in stature and should work for this....
Next to a 1:35 scale ruler (left side) both stand at around 1.8M tall...
Then I started work on the carriage. There are stil a lot of detail parts to add there before final assembly...
Then a test fit all together along with the Bronco figure
More tomorrow... This is progressing faster than I expected...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
- Plankton
LSM
