VTOL, STOL, STOVL GB 2020
    July 2014
Posted by modelcrazy on Monday, April 5, 2021 8:38 AM
Piers. I have no words of wisdom, in fact, it looks better that I could ever achieve. If anyone's technique works I'd gladly give it a try.
I think that blue/yellow scheme is kickin though.
Steve
    July 2014
Posted by modelcrazy on Monday, April 5, 2021 2:18 PM
Bish
modelcrazy
I got you up Mark. Be sure to snag one of those badges if you want.
I have a couple of GB's I plan on starting Jan if you're intrested.
Lockheed Martin
Two many wings, Two many tails
The feelers will go up in November sometime.
Already got my Lockheed lined up.
I was actually wondering if I had any Lockheed in my stash. After doing a little research I found I have tons of them..even Martin. There's so many aircraft that I know well but don't think about who manufactured them. Not many Convairs though.
Steve
Posted by keavdog on Thursday, April 15, 2021 4:05 PM
Test fitting the nacelles  - this thing is huge!
There's a collar on the inside of the nacelle that glues on which holds onto the shaft coming off the wing.  While test fitting the starbord nacelle the collar came loose.....hence the tape.  I don't want to pull apart the nacelle so I'll have do be creative when it comes time to attach permanently.    Huh?
Thanks,
John
Posted by jeaton01 on Thursday, April 15, 2021 10:35 PM
Yeah, a rubber band would probably show...
I'm going to try to remember about that bushing problem.
John
    April 2014
Posted by lostagain on Saturday, April 17, 2021 3:21 AM
Hey Keavdog, thats very frustrating - sounds like a design fault that the socket could come loose?
That really is a big unit there, I don't have that space on my desk!
The yellow edges have been repainted by hand, following Jeaton's suggestion. It has come out really well. I didn't fancy a respray given my poor maskig the first time.
Also got the motor painted up and assembled. Despite the moulds being skewed, it builds up into a nice rendition. The photo doesn't do it justice, with separate exhaust rings, motor and inlets painted up then assembled.
    July 2014
Posted by modelcrazy on Monday, April 19, 2021 11:20 AM
The Osprey is looking good John.
Piers, The yellow came out great!
Steve
Posted by keavdog on Monday, April 19, 2021 7:13 PM
Wow yellow over blue!  That's tough - looks extremely well done.
The design of the osprey is pretty solid, I just put a bit too much pressure at the wrong angle.  It's on me.
Thanks,
John
    April 2014
Posted by lostagain on Sunday, April 25, 2021 7:40 AM
Started decalling this weekend. They gave me a scare to start with - the clear film os a cloudy white as it goes on - have a look at the Miss Champion decal but fortunately that dissapears after a while. The old decals hold together mostly, but there are some cracks in the big Champion decal.
 Then it was time for the decals on the rotors. These are long and break up easily, they have all been pieced back together. The ones on the top with all the cross stripes were the worst. I only got two of them done, the next one I will chop in two before putting them on.
Posted by jeaton01 on Sunday, April 25, 2021 4:00 PM
I've had problems with older Williams Brothers decals, too, Piers.  Looks like you are coping pretty well, but it is always hair raising.
John
    April 2014
Posted by lostagain on Monday, April 26, 2021 7:17 AM
Thanks John, yeah it is tense when you see the cracks open up...
And it took me a while to notice the top of the spark plug picture on the big decal has been scrubbed over with yellow - don't know why.
    July 2014
Posted by modelcrazy on Monday, April 26, 2021 9:45 AM
Nice save Piers. I can't tell that they had any cracks. I have to copy and print new decals for Williams Brothers kits. That works well until they're white.
Steve
    April 2014
Posted by lostagain on Sunday, May 23, 2021 7:26 AM
Gave the gloss coat a fortnight to dry out. I have had issues with leaving fingerprints on gloss coats in the past.
I painted the red tips on the rotor blades. Worried about masking over the decals, so I used post it notes cut to the curves and sprayed multiple coats at low pressure.
Next is the rigging. The wings have got obviously metal stays so I had to get a way to show that. Several iterations trying to paint monofilament or Z line with Acrylic, lacquers or Gundam marker. The best combination is monofilament and lacquer (Mr Metal), so start rigging next.
Any paint on the Ez line just falls off as it stretches or contracts.
    August 2015
Posted by crown r n7 on Sunday, May 23, 2021 8:08 AM
wow thats striking !! super job with the paint whats next.
 Nick.
    July 2014
Posted by modelcrazy on Sunday, May 23, 2021 2:01 PM
crown r n7
Ditto
Excelent job. Yeah, gloss takes a long time to dry before you don't leave prints in it. I never seem to wait long enough.
Steve
    April 2014
Posted by lostagain on Friday, May 28, 2021 7:41 AM
Tanks guys, I think I have left it long enough this time, the fingerprints are cleaning up...
I have started rigging. I have used the monofilament (fishing line) painted with Metal hobby lacquer for the stainless wing/landing gear stays, and EZ line for the tail stays and rudder/elevator control lines.
    July 2014
Posted by modelcrazy on Friday, May 28, 2021 8:30 AM
That thing looks a complicated to build and paint as a Gee Bee.
Looks excelent Piers Yes
Steve
Posted by waikong on Saturday, May 29, 2021 1:06 PM
Some great builds here, loving the Aussie bird.
Ok, is it too late to join? I saw this late last year, inspired me to break out my 1/48 Flettner fl265 kit, I actually started in Jan and finished it in Feb.  But forgot all about joining the GB!  I have in progress pics :)  GBs here have been great incentive to break out some old kits.
    July 2014
Posted by modelcrazy on Saturday, May 29, 2021 8:29 PM
waikong
Sure no problem. I'll get you listed.
Steve
Posted by waikong on Sunday, May 30, 2021 9:07 PM
Here's the kit I was building.  Special Hobby 1/48 Fl265
limited run kit, so lots of butt joints and a lot of triming and dryfitting.  Started the kit by adding some framing that was missing around the cockpit
The windows on top is molded in, so I chained drilled and opened that up.
The cockpit is a resin piece, somewhat good detail.
Here's the cockpit closed up with the framing and the top window (acetate piece) installed.
bit of a delicate job getting the wheel mounts together, but surprisingly strong once the glue is dried.
Next up will be detailing the plain rotors, paint and decal to finish it up.
    July 2014
Posted by modelcrazy on Sunday, May 30, 2021 9:24 PM
Awesome pit Waikong. I got you on the roster.
Steve
    April 2014
Posted by lostagain on Monday, May 31, 2021 7:31 AM
Waikong, I do like the Flettner - such a wierd looking craft. The cockpit has great detail, you have painted it up very well. And are those marshmallows stuck on the engine coaming? Looking forward to seeing how this one comes out.
I do have the Huma 1/72 Fl 282, won't get to that this GB though.
The Pitcairn is coming along steadily, the rotor head and the landing gear are now on. Next to get the rotor itself set up - starting with developing a jig.
    July 2014
Posted by modelcrazy on Monday, May 31, 2021 10:43 AM
That looks spectacular Piers
Steve
Posted by waikong on Monday, May 31, 2021 4:50 PM
Thanks for your comments, those marshmellows are some sort of engine exhausts I believe :) Probably sticks out too much, but i didnt have to patience to sand them all down to the same length after tackling that observation window and the windscreen. Your paint scheme is looking great Piers, I always have trouble with those 2 colors, shiny blue and yellow. Usually putting too thick of a coat to get even coverage. I think I need to undercoat with a light primer ?
Posted by waikong on Friday, June 4, 2021 4:23 PM
Ok, here's more pictures of the Flettner and the final finished build.  First some painting, decals, and improvement on the rotors - which was devoid of any details.  Used misc plastic, left over PE, and a paper clip to add the details.
More build pics here https://waihobbies.wkhc.net/index.php/35-models/sky/world-war-2/169-flettner-fl265
Thanks for this GB, otherwise I dont know if I would have finished this little kit.
Posted by keavdog on Friday, June 4, 2021 5:26 PM
Love the pit and the Flettner.  Great subjects.
Thanks,
John
Posted by jeaton01 on Friday, June 4, 2021 11:17 PM
Nice'giro.  Cleanly and neatly built.
John
    July 2014
Posted by modelcrazy on Saturday, June 5, 2021 10:22 AM
That's beautiful Waikong! Such a clean build Yes That's a subject I've never seen before.
Let me know which pic you want on the wall and it was great to have you onboard.
Steve
Posted by waikong on Sunday, June 6, 2021 10:43 PM
Thank you, John, John, and Steve. I also never heard of this thing until I saw the kit. :). Please use the last picture.
    April 2014
Posted by lostagain on Monday, June 7, 2021 5:34 AM
Waikong, that is a great result from a short run kit. Always like something that is a bit odd!
    July 2014
Posted by modelcrazy on Monday, June 7, 2021 8:28 AM
Waikong, I got you up.
Steve
