Did I have a bad moment today...
Last night I gave the P-194 it's top-site base coat, this morning I did the masking for the splinter camo, all was well.
After removing all the masking tape, I saw that I needed to redo the underside, ok, no prob.
I just removed the masking and discovered that had sprayed to steep into the softmask (between top and bottom) so that I now have a hard line between the two colors
I really don't feel like starting all over again, so I'll just mask and make a hard demarcation line between them.
UPDATE :
Do you know what the advantage is of having modeled for almost 20 years without an AB ; if you don't feel like it, you don't need no mask and AB
That's what I did, I solved the problem the old fashioned way, so there goes my blues again, and here are the happy times
