Okie :
I hit that one too when putting my sprockets onto the 'toy' shaft (still awaiting a donor set of gearboxes) My solution was to adjust the brass sprocket-mounts on the axle.
Are you telling us those are ~pressed~ onto the Type 4 shafts, and not set-screwed? Why would Tamiya change that, after using that method so well on the other variants?
If thats truely the case , why now put a washer inside the shaft side of the sprocket? You might have to Dremel it for the flats...
Something sounds wrong... I'll ask the RC guys, and get back to ya, ok?
Rocad :
You mean other detail parts besides Aber? Dirk has metal-cast parts, including functional shackle loops, metal tow cables, and lots of other parts, some even duplicating some Aber parts (track hangers) You can hit his Yahoo Group at
http://groups.yahoo.com/group/DP-Thema/ . I have some of his parts now, and the quality is superb! A warning though: he's a bit backed up at the mo, so delivery may take a while.
GearBox Generations :
Type 1's (no black cover) were used for the 56005 Sherman, 56007 Porsche King Tiger, and 56010/56011 Tiger 1's.
Type 2's (first ones with the black cover) went into the 56014 MF-loaded Sherman.
Type 3's were used in ~only~ the Pershing , as it had the final drive ratio ~outside~ the hull, like the Panther & T34 does (most bets are on those two, not a Leopard 2A5 being next)
Type 4's were introduced with the 56018 Production King Tiger, and have been retrofitted to many others because of its almost-all metal makeup.
This help?
Erush :
I think I know where you're looking:
Look at the driver's visor - MG blister armor plate from ~under~ the front fender (as if you're laying on the ground in the path of the track!) That front plate doesn't extend down to touch the chassis hull! A simple solution to prevent crap entering here is to glue a scrap of sprue in there(my choice) or just stick a bit of foam-tape there like 'weatherstripping'.
WhiteWolf
