HEEEELP !!
I use enamels only (MM) for my project. Primer used (White Primer from MM )
This supposed to be a project ready for decals (after applying gloss)
I set my Mk II with gloss coat (Model Master spray can) and .... it is not glossy. OK so I said, lets try ... I put a lot of microset and .... destroyed my first decal as soon as I tried to move it !
I think the problem is with the primer I used but I am not sure. The paint texture is flat. I even use sand paper to smooth the surface (after applying primer) and I thought it is OK. Now I see its not OK and I am going into deep .........
You guys know that I am a newbie and I just went into the trap I did not even see ....
So, what went wrong ?? How to apply decals in such surface - one shot only :( - I amy try it but .. it is a special set of decals and I do not have any replacements (have to wait for Techmod for at least two weeks ) so unless you will tel me what is wrong and how to fix or ... I will struggle during the task what was some fun already (P-51)
Greg
