Chris,
this was a Tamiya 1/48 Mk Ia, I put a starter bumb and got Mk IIa - spinner will follow :)
It is my first Pre and Post shading - you may see my whole story on this craft :) here:
/forums/786316/ShowPost.aspx
I use Model Master enamel paint.
RAF Dark Green and RAF Dark Earth.
1. the whole craft with white primer
2. all panel lines with black
3. first coat of Dark Earth
4. added some white paint into Dark Earth and sprayed INSIDE panels - just a mist
5. Masked the Dark Earth
6. redo black panel lines (what visible)
7. put coat of Dark Green
8. added some white (about10%-20%) to Dark Green and painted INSIDE visible panels
DONE
I used a scheme from Tamiya (A I think) but modified it a bit accordingly to the pictures of the P7962.
The whole process is as described by Swanny (Thanks Swanny for a DVD - BTW when the next one will show up ? ) but an additional step is required caused by a second color (Dark Green) - Redo Black Panel lines - Thanks to Marc
I may overdo this one but ... the plane was in service on other Squadron first and than came to 303 for service, so it was not new when showed up in Northolt (and I did not know better so it is what it is :) - at least found an excuse :) )
Greg
