SPITFIRE GROUP BUILD 2007-2008
Posted by jeaton01 on Sunday, May 27, 2007 12:00 PM
Everybody likes the IPMS Stockholm charts, they are a good start, but they are not up to date and it can't be assumed that a paint not listed is unavailable.  Testors numbers for a Mk I in Dark Green/Dark Earth/Medium Sea Grey are 2060/2054/2058.  Sky (Type S) is 2849.  For later Spitfires substitute Ocean Grey (2057) for Dark Earth.  For desert colors Middlestone (2052) and Azure Blue (2048).  For Interiors there is Interior Grey/Green, 2062.
John
    April 2005
Posted by wing_nut on Sunday, May 27, 2007 11:25 AM
The warm-up build has commenced!Big Smile [:D]
Here is the port side cockpit PE
Marc
    September 2003
Posted by Daywalker on Sunday, May 27, 2007 10:16 AM
Chris,
Check out this website, they have a wealth of info that might help.  I don't think MM makes most of the colors you need, but the site gives some approximate color mixes.
http://ipmsstockholm.org/colorcharts/stuff_eng_colorcharts_uk.htm
Hope that helps!
Frank
    June 2006
Posted by ModelMan8 on Sunday, May 27, 2007 10:03 AM
Hi all, I just recieved my Tamiya 1/48 MKI.  I opened the box this morning and relized that all of the paint is in Tamiya color.  My LHS does not sell Tamiya, just Model Master and Testors which is what I have.  Can someone give me a quick color reference so that I use the right colors.
Thanks, Chris
    June 2004
Posted by phoenix7187 on Sunday, May 27, 2007 9:25 AM
Hay triumf those resin cockpits can look intimidating, but for the most part they are not difficult to install. I have found painting them is easier then painting the kit cockpit parts because the detail is more defined. If it's made for that kit then usually things go well. I have only 1 or 2 out of more than a dozen give me trouble. One case was becasue I was adding a tamiya tub to a dragon kit.
Stan
    September 2003
Posted by Daywalker on Friday, May 25, 2007 7:58 PM
Triumf-
Sounds like you're off to a great start in your resin future!  Never hurts to have a back-up plan, either. Wink [;)]
Frank
    August 2003
Posted by triumf on Friday, May 25, 2007 6:58 PM
Whistling [:-^]Today I started smallish on my Spit for this GB. If its a success, it will turn out as a norwegian MkIX from september 1945,a month or two before RNOAF got their own roundels. It will be FN-Z from 331 sqn, in the familiar RAF colours with the norwegian flagstripes on the rudder and on the spinner.
This will be a first for me. The first time I have ever wandered in to the dark abyss of resin-cocpitsShock [:O]Angel [angel] I`ve bought an Aires cocpit for it when I ordered the kit, and today I cleaned the resin parts from the pourstubs and sanded them carefully in water. And also thinned down the walls in the kit. When dryfitting the sidewalls they seemed to fit reasonably well;)
If it turns out to be a failure, I have a backup plan.Trow on some decals from the danish airforce of 1947, and do kit No2 as the norwegian one oobWhistling [:-^] Isn`t that a sweet plan????
life begins at 200 On the bench: RAF Ventura Tomcat 1\32 for my son Photo Sharing and Video Hosting at Photobucket Photo Sharing and Video Hosting at Photobucket
gzt
    May 2007
Posted by gzt on Friday, May 25, 2007 5:25 PM
Thanks,
I ordered two 1/48 Hasegawa Mark IX.
1. Hasegawa 1/48 Mark IX - Gabreski's Spitfire during his time (1943) with 315 Polish Squadron RAF
2. Hasegawa 1/48 Mark IX - 145 RAF in North Africa (Skalski's (Polish) or S/L Wade's (Texan)).
3. Mark Vb (Tamiya 1/48) - 303 Polish Squadron RAF flown by Jan Zumbach (RF-D)
4. Mark IIb (converted Tamiya 1/48 Mk I  - I hope there is a need of just adding guns on wings but did not do my research yet.
Greg
Flying is a thrill #2 known to mankind. Landing is #1.
http://www.rwd-6.org
    April 2005
Posted by wing_nut on Friday, May 25, 2007 1:08 PM
I will be presumptuous enough to say that I am sure Darren will add you to the roster.  He posted on the 18th in the FAA GB that he is going be tied up at work for a bit and will post when he can.  So hang in there.  Hopefully our fearless leader will be back... and with a Spitfire building vengeance.
Marc
gzt
    May 2007
Posted by gzt on Friday, May 25, 2007 12:09 PM
if its possible - I would like to join you all with my pick of:
Tamiya 1/48 Spitfire Mk Vb
Hasegawa 1/48 Mk. IX
and possibly converting Tamiya 1/48 Mk I into IIb , but I may need some help of more experienced fellows here :) (and some book research as well)
Greg
    August 2003
Posted by triumf on Friday, May 25, 2007 8:37 AM
 TANGO 1 wrote:
The Roll call:
who's doing what to which kit!
Tango 1..................Hasegawa Mk.IX "Nose Art"
JWB ......................Mk.I to  Mk.22/24
Wyoroy...................undicided.
Darson ...................Eduard 1/48 Mk.22/24
BobBaily .................Hasegawa 1/48 Mk.IX
Ruddrat ..................Tamiya 1/48 Mk.I/Mk.V
Jeaton01.................Possible 1/32 K5054?
Daywalker...............Spitfire Mk.?
Wingnut ...................Tamiya Mk.V 1/48
ModelMan8................Mk.? Revell 1/48
Chester 101................undicided
Arki30 .......................Not in----but not out!Big Smile [:D]
Harvs73.....................Hasegawa Mk.IX 1/48
Joe Rugby....................Mk.IX   1/72
Texreb.........................1/72 Mk.?
TryintoModel..................1/24 or 1/32 Mk.Vb
Kingthad........................something from the stash.
Razordws........................Mk.I ?
Silentmodeler................Mk.Vb 1/32 Hasegawa.
TGregory........................Mk.XIVc 1/48 Academy
Phoenix7187...................Mk.Vb  1/24 Trumpeter.
Yo Tango...do you please count me in on this here GB??? please
And it will most definitly be a Hasegawa MkIX from either the norwegian (RNOAF) or the danish airforce,,,Maybe with som stash from Aires in the cocpit as well;);)
    August 2003
Posted by triumf on Friday, May 25, 2007 5:25 AM
The one little thing about the Spit, is that the more you`ll lern about the little lady, yhe more You`ll want to learn. Simply addicted to her. I for one, will never get bored og sick of building models of this magificent masterpiece in engineringBow [bow] Humble thanks too MitchellAngel [angel]
    April 2005
Posted by wing_nut on Wednesday, May 23, 2007 5:53 PM
Got all the pieces in place for the practice build, warm up build... whatever you wanna call it.  Gonna start the Academy Mk XIVc as soon as I finish my little rat.  It will be a Belgian post-war photo-recon version.  From a photo I have seen it is just a round glass covered hole on the port side behind the cockpit.
I ask the guy at the LHS to order the Eduard detail set... very nice.  Too bad not color though.  And he took it upon himself to order the landing flaps tooAngry [:(!].  The nerve of that guy... assuming I was gonna buy them tooAngry [:(!].   OK so I did buy them (like there was a chance I wouldn'tWhistling [:-^])... and I thanked him for thinking of it Wink [;)](he knows me to well).Ashamed [*^_^*]Laugh [(-D]
(Just kidding John... if you are out there)
Marc
Posted by darson on Tuesday, May 22, 2007 9:35 PM
Jon I know what you mean about the old big book 'o' Spitfires.  Mine has a green cover and is titled something like Merlin powered Spitfire Mk.I to Mk.IX (Can't remember exactly as I'm at work).  It is beautifully illustrated with photos inside and out as well as scale plans for every mk from the 1 to the 9.
Cheers
    June 2004
Posted by phoenix7187 on Tuesday, May 22, 2007 8:57 PM
From what I know your right jeaton. The letter wing description refers to weapons that can be carried on that wing. I have seen  the b,c and e wings clipped. which like you said they just unbolted. I have been told they clipped the wings and carried less ammo to stay with the fw190's. The development of the XI was a direct result of 190's huge advantage over the MK.V.
I think they got beefer as well. higher loads, more ammo, fuel, and bombs. The spitfire evolved much like the 109. The eariler spits were the most maneuverable and as they progressed they got faster and carried more firepower but at the cost of higher wing loads and thus less maneuverability. I have been told the MK. IX was the best compromise between firepower, speed and handling, but was a hand full to control compaired to the later marks. This is way many pilots liked the old mk.V  still a good fighter but much more pilot friendly and in the right hands very lethal. marks after the IX maneuverability fell off fast, especially the griffon powered birds that became nose heavy.  I don't know the numbers off the top of my head but the MkV normal weight was like 6000 lbs. some of the later spits or very late versions exceeded a ton over that.  (all this info may not be rightDead [xx(]I know far more about the luftwaffe stuff than the RAF stuff) If I messed something up fell free to correct me. most if what I know about the spits is from casual talk and not research. for all I know most of this could be worng?
Stan
Posted by jeaton01 on Tuesday, May 22, 2007 8:29 AM
The manhole cover raises slightly, an eye is briefly visible....Is it a Spitfire Fanatic or is it a Groundhog!!!!
About his new book you have, Scott, how well illustrated is it?  It sounds pretty good.
Thanks for the history, Darren.
John
jwb
    February 2006
Posted by jwb on Tuesday, May 22, 2007 7:53 AM
 jeaton01 wrote:
I'm gonna throw these things out here so they can be agreed with or found wanting:
The L, nothing, or H before the F refers to the engine, whether it has a low, normal, or high altitude supercharger fit.
a, b, c, or e refers to the wing, specifically its armament fit possibilities.
The wing tip is not inluded in any of these descriptors, because they all were bolt on fits, and were interchangeable on any of the wing types.  A photograph would be the only way to tell the wing tip on a particular Spitfire, although I think the Mk. 22 and on all had the clipped tip shape.
OK, time to practice the old Duck 'n Cover!
I concur with all! (For whatever it's worth..... that and $.89..... or $3.49 depending on your tastes.... will buy you a cup of coffee. LOL)
That's the simplest explanation I've heard for the LF, F and HF designation. Well put. My big book 'o Spitfires has so much info, sometimes it's hard to find a simple answer. Smile [:)]
And good info on the wingtips! Clears up a lot knowing that.
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
Posted by darson on Tuesday, May 22, 2007 7:29 AM
Oops I kinda forgot to mention in my last post that I agree with you John re the LF, F & HF designations. In the case of the Mk.IX these designations were used to differentiate altitude rating of engine, the Spitfire LF Mk IX used a Merlin 66, the  Spitfire F Mk IX used a Merlin 61 or 63 and the Spitfire HF Mk IX used a Merlin 70.
Cheers
Posted by darson on Tuesday, May 22, 2007 7:03 AM
John my uncle was an RAF spitfire pilot with 93 Sqdn RAF and served in Italy during the war.  He said that in his squadron the choice of wingtip was completely left up to the pilot and some proffered the 'C' wings on the Spitfire Mk.VIIIs without the wingtip bits as it gave them a better roll rate.
Cheers
Posted by jeaton01 on Monday, May 21, 2007 10:25 PM
John
    June 2004
Posted by phoenix7187 on Monday, May 21, 2007 8:15 PM
The more I learn about Spitfires, the more I realize I know very little about them. LOL
I know, for some reason I can look at a 109 and tell you just about anything you want to know about it. Sometimes more than people want to know I'm sure. For some reason I find spirfires confussing? What I really need to do is just sit down one day and figure it all out.
That MK.V is the personal aircraft of ace jack sheppard EN921. I read an old book about spitfire V aces. since the book only covers the V varient I thought (the text is very misleading) he shot down 5 fw190's with this aircraft. In fact I was wrong, anton correct me later.  Yah the b denotes the wing type.
Stan
jwb
    February 2006
Posted by jwb on Monday, May 21, 2007 7:48 PM
 jboutin wrote:
Hi Jon, does it look like this?  This was a spare I forgot about that came in the hasegawa kit in addition to the mk9 tail wheel.  It looks like it wouldn't be too hard to modify, if yours is different would it be easier than this one??
Yep.... that's basically it..... looks like the Mk. VIII tail wheel. Same thing I was going to send- lloks like you've got what you need though! Wink [;)]
Jon Bius
jwb
    February 2006
Posted by jwb on Monday, May 21, 2007 7:28 PM
 jwb wrote:
 phoenix7187 wrote:
and since the Vb has clipped wings that would be the late Vb most likely?
I'll have to run down the Mark Vb question further. The "b" designation had to do with the type of wing armament, I believe, not necessarily whether the wing tips were clipped or not. I'll see if I can find something more concrete.
OK..... more info on that V.... EN92x.
It was built as part of contract # B981687/39 at Castle Bromwich, under the 4th order (9 orders were issued under that contract.). That order was built as Spitfire F Mk. Vs, both as B and C variants in that order.
I can't tell what the last digit is in the photos you posted, but all of the a/c built under EN92x are listed.... doesn't say if they were B or C. And though I'd always thought that the LF denoted clipped wings, I've since found out it did not always mean that, as some Spitfire Fs were clipped wing. (I need to read more obviously.)
So having said all that, it's definitely a Mk. V, and it looks darn good.... F, LF or wotever! Wink [;)]
Jon Bius
    June 2004
Posted by phoenix7187 on Monday, May 21, 2007 7:16 PM
Thanks jwb for the info, I am making a shelf just for spitfires. Have to have someplace to display that monster 1/24 model. I plan on making plaques for them like my luftwaffe display case. I had lost most of the info for thoes when I moved a few years back. The only one I had info for was the Vb I did about a year ago. Much appreciated.
Stan
jwb
    February 2006
Posted by jwb on Monday, May 21, 2007 6:54 PM
 phoenix7187 wrote:
jwb, thanks and since I have your attention and I'm too lazy to go look it up If that's the VIII that this ones the XI correct? and since the Vb has clipped wings that would be the late Vb most likely? I did not catch the tail wheel, good eye.
TB 476 had me perplexed. It looks like a Mk. IX, so I checked the serials.... it should have been there. But TB 475 & 476 were missing from the TB series under the Mk. IX lists. So I checked the Mk XI serials..... sometimes a few aircraft from one Mark would be converted to another Mark.... no TB 475 or 476 either. Then it hit me- the Mk. IX and XVI were essentially the same aircraft, only the XVI having Packard built Merlins. (Basically) Bingo!
TB 476 (and 475) were built in the 17th order for Mk. IXs, fulfilled as Mk. IXs and XVIs between Dec '44 and June '45. TB476 was built as a Mk XVI. Went into service Feb. 14th, 1945, and went off the books in Mar. '46.
Jon Bius
Posted by darson on Monday, May 21, 2007 1:29 AM
Phoenix, those builds look absolutely fantastic you've really done a great job congrats Thumbs Up [tup]Thumbs Up [tup]Thumbs Up [tup].
Dave, congrats on reaching the big 2000 Party [party]Propeller [8-]Make a Toast [#toast]
Cheers
Posted by jeaton01 on Monday, May 21, 2007 12:22 AM
Phoenix, I'm late coming in but I too like the weathering on your Mk V and IX, they both look like airplanes that have been working.  Someday I'll learn how to do it that well, I hope.
John
    December 2004
Posted by jboutin on Sunday, May 20, 2007 11:34 PM
Dave, Congrats on 2000 Posts!   I'm still a long ways off for that milestone.  Dito on hoping the forum will be around for a while!
JAY - fighting evil since 2:15pm, July 8,1976 -
Posted by Anonymous on Sunday, May 20, 2007 10:24 PM
 jwb wrote:
That would be neat to build wouldn't it?
A little Spitfire trivia for all:
Before the prototype Spitfire, ser. no. K5054, also called the Supermarine Type 300, their had been the Supermarine Type 224.... a very un-Spitfire looking aircraft that is part of it's lineage.
Here's a vac-formed kit I found at IPMS Stockholm:
Look's like somebody beat us to it Andy!
Ah well, there goes my chances of being a pioneer!  Good find, Jon, looks pretty nifty.
Wish my weathering skills were at your level, Phoenix!  Spits with clipped wings look right too.  The elliptical wing is beautiful but the clipped wings are just different enough to have their own appeal!
    June 2004
Posted by phoenix7187 on Sunday, May 20, 2007 8:45 PM
At one point in time I had all in 48th scale Mk's V, Vb, VI HF, VII, VIII, XI,. With kits to do the MkI, II, IIb, but still have never built any of them. I think that gives me every major varient between I and IX? MKIII I think there were only 1 built and the MK X there were only a hand full built.
 My VI did a swan dive off the top shelf and is now in the parts box, not to mention it looks very different. I have another one of these. I think my VII is MIA at this time. So I had the choice of IX or VIII.
Daywalker, I painted the base color of the stick. then added the wear with flat black with some gray added to give it worn scale effect with a small 00 brush and just dry brushed it on (that example is a little heavy IMO). Next I added some wear to metal parts by dry brushing some flat aluminum lightly on the edges of levers and controls. Finally I give it a light black wash to blend it all together and bring out small detail. I work with flat acrylic paints.
Pics are not good, I took them quickly in less sun light.
thanks for the comments guys, this one's an early build and my weathering skills were still being tuned.
Stan
