wing_nut wrote: |
Thanks Darren. A question about the 2nd cannon being plugged. Was the gun still installed and just mot used, hence the plug? Seems nuts. I only ask since the Academy kits has the plug for the 2nd gun, but both cannons in the gun bay. And we all know kit manufacturers NEVER make mistakes like that. |
If the gun arrangement was 1 cannon and 2 MGs per wing, the plug would have been used, and the bay housing the cannons would have only had 1 cannon. If it housed 2 cannons per wing, then of course the cannon bay would have been full, but the MG bays would have been empty.
The plug would have been just outboard of the inboard cannon in the 1 cannon per wing arrangement.
Are the cannons molded in the bays, or glued in? If you can glue them in, leave the outboard cannon off. If they're molded in, and you're going to have the cover open, then you'd need to remove the outboard one.
I'm sending both the large and small blisters to you. If it were me, barring a reference pic of a particular aircraft, I'd go with the large blister. I think it just looks cooler.
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
