Now sanding is almost done, and I'll put on a primer to check if there's something more to fix. Meanwhile I just had to test fit the plane and the bomb on the stand!
Might just tilt the Spit a bit down to make look more on the hunt.
I've noticed a slight? problem with the canopy, that needs to be taken care of!
The rear part doesn't align with the spine the way I think it should. I'm thinking of either tilting the canopy sligthly, or cutting the rear part and gluing it properly to the spine, and fill the gap.
Cheers,
Azgaron
