Greetings daywalker. As mentioned earlier some manufacturers did not clear varnish propellers but shellaced them. To do laminations on propellers you can either laminate woods with expoy or enamel paint kit items. I could post either method but painting is a bit quicker for most modelers to do. You almost have to have a separate setup to use woods.
A. For woods;
1. A box of rubber / latex gloves.
2. various thin woods from dollhouse marqueting sheets for floor planking and etc. The thickness is important here.
a. bass wood
b.mahogany woods
c. walnut
3.Clear varnish, semi gloss is best for small scale.
4. Homemade wire supports to hang them on while drying.
5. Beau coup Xacto blades (#11 are best.)
6. The lanimations should be an average of three of two kinds. 3 bass 3 walnut etc.
I can post an image /drawing of the process later tonight.
