The Official F4U Corsair Group Build 4/01/08 - rolling end date
    January 2007
Posted by Gigatron on Saturday, April 12, 2008 6:10 PM
Well, she's on temporary hiatus, yet again.  I ended up obliterating most of the raised panel ines while sanding the seams.  So, I'm ordering a rescribing tool from missionmodels.
-Fred
    December 2003
Posted by scottrc on Saturday, April 12, 2008 6:25 PM
Just got this picture to show you of these front landing gear doors.  Not much to scale eh?
Scott
    September 2007
Posted by dirtball on Saturday, April 12, 2008 6:39 PM
 And I thought my REVEL engine looked like crap!!. Lonestar makes a wheel well set with doors and struts. About $20 from there own website or Great models. Actualy I`m thinking of getting the AIRES set. I know its for the TRUMP, but some of the guys have convinced me to go for it.I think its there way of railroading me...............Harv
"I once shot an elephant in my pajamas. How he got in my pajamas, I`ll never know!"
    December 2003
Posted by scottrc on Saturday, April 12, 2008 7:34 PM
Thanks Harv, I forgot about the Lonestar sets and I too am interested at looking at the AIRES set.
I was thinking about making a set out of brass tube.
    September 2007
Posted by dirtball on Saturday, April 12, 2008 8:43 PM
  I know metal legs are made by Scale Aircraft something or other, but they are for the Trump and dont think they would fit. Last night at work, was digging around our shop and came across some small enough springs to use on the outer part of landing gear. I think they will work. If you plan on doing yours out of tube, think of me, ok?.................Harv
    February 2008
Posted by piperjoe on Saturday, April 12, 2008 9:29 PM
Came up with something you guys might want to try.  Tried to take a picture of the idea but the macro on my camera won't allow the shot to reproduce well so will describe it.
Glue wands: Was lighting a fire in the fireplace (...bear with me, please) and you know how those long match sticks are (10 inches long)?  I thought, hey what if I broke the match head off, leaving about 7 1/2 inches of 1/8 sq. wood for a handle.  Made up three handles.  Then I got three sewing needles, the kind with a thread hole in the end, the largest being about 1/32 inch diameter, then a smaller dia. needle, and then another smaller dia. needle.
Take each needle and file the thread end off just enough until you create a small fork shaped opening.  The three needles will produce three different width fork openings.  My fork lengths are about 1/8 inch long.  Take a pin vise and drill an appropriate size hole for a pin into the end of a wood match stick leaving about 3/4" to 7/8" of the pin sticking fork end out from each match stick.  One pin to one match stick thereby creating three different size CA glue wands.  Glue each pin into its matchstick with thick CA and bind the wood where the pin was inserted for about 1/4" with sewing thread.  Soak this thread and about an extra inch of the wood wand with thin CA.  LIghtly sand each wand to smooth the wood surface.
You now have three different sized wands for picking up CA per your modeling needs via capillary action and you can place the glue exactly where you need it in small quantities via the same capillary action.  I place a small amount of whatever thickness CA I'm using on a small paper plate and dip the fork into the glue.  Capillary action draws the glue up the fork.  The length of the wand gives great control and you can reach into areas easily when required.
    October 2006
Posted by kenjitak on Sunday, April 13, 2008 1:10 AM
That's a great "tip" Piperjoe! Seriously, I'm going to have to try that out soon! Thanks!
Ken
    July 2003
Posted by ridleusmc on Sunday, April 13, 2008 1:32 AM
Yeah, that is a good idea.  I have a left over sewing kit.  It's just a useless pouch sitting in a drawer....  That's it, it's history,
I finished my Mustang today, and I started my F4U-5N.
Semper Fi,
Chris
    March 2007
Posted by JMart on Sunday, April 13, 2008 7:10 AM
great tip piperjoe... I get some medical needles from work, also work quite well and are made in various widhts, cheers.
    February 2008
Posted by piperjoe on Sunday, April 13, 2008 8:22 AM
Thanks, guys!
Remember to go slowly when sanding the metal away, especially just before you sand away the thread loop and create the "fork".  You want maximum fork length to hold the glue.  Have fun and be careful of the pin's sharp end!  (Don't ask me how I know about that Whistling [:-^] )  Use a small piece of balsa, or similiar, and stick the pin into that as you work on the thread end with sandpaper.
Cheers!
    December 2003
Posted by scottrc on Sunday, April 13, 2008 9:49 AM
Glue wands sound like a great idea for the various amounts and locations that CA is applied.  I use CA extensively in my ships and your idea sounds like a good one.  On a side note, anyone use the Lock Tite CA brush?  This stuff is great, less expensive, and everyone sells it.
Back to my landing gear dilema.  I ordered a set of Airies, if they don't fit ,they will make a good patter to scratchbuild a set from.
Cheers,
Scott
    September 2007
Posted by dirtball on Sunday, April 13, 2008 10:38 AM
  Scott, please let me know what you think about the AIRES set. I havent ordered mine yet and curious to see if they will work with the Revell. Good luck.............Harv
    October 2007
Posted by Summit on Sunday, April 13, 2008 5:32 PM
Progress update, Got a new floor of 5/8" plywood down. Waiting for carpet....... After my carpet is installed I will be heading for Colorado for a week or so the see my Favorite WWII Vet-  My Dad. (he is 91)  Time to go give him a hand on Spring Chores on the Ranch... Looks like I will be out of the loop until May something.  Dont leave me too far behind. Sorry for being OT and longwinded but OT but did not want you guys to think I bailed out.....
BTW Joe - Great Tip, sure sounds better then a toothpick or piece of wire Thumbs Up [tup]
Sean "I've reached nearly fifty years of age with my system." Weekend GB 2008
    February 2008
Posted by piperjoe on Sunday, April 13, 2008 5:55 PM
Thanks, Sean.  Have a great trip to Colorado and enjoy your time at the ranch with your Dad.  Give him a big "Thank You" from me for his WWII service!  BTW:  Lived in the Denver area back in the early '80's and my wife and I sure loved roaming the beautiful mountains in our CJ-7.
    September 2007
Posted by dirtball on Sunday, April 13, 2008 8:59 PM
Sean, you know this means you`ll have to tell your dad"Thanks" from all of us here...Spent a short time in Denver myself in the uuuhh, 60`s for B52 training. Loved it there..Dont be gone to long, now. But we wont leave you too far behind!  Have fun and see you soon............Harv
    May 2003
Posted by DrewH on Sunday, April 13, 2008 9:15 PM
I'm alive!! I'm alive!! Big Smile [:D]
 Some nice progress being made guys! Hope to be around more, been out of town with no net Grumpy [|(] so I've missed ten or so pages. Keep it up, I hope to be back to normal soon Propeller [8-] whatever that is Tongue [:P]
Take this plastic and model it!
    September 2003
Posted by Daywalker on Sunday, April 13, 2008 10:38 PM
Sean- Glad to hear your home improvement project is going well. And, thank your Dad for me too! Smile [:)]
Drew- Sign - Welcome [#welcome] back! Big Smile [:D]
Frank
    February 2008
Posted by piperjoe on Monday, April 14, 2008 7:59 AM
Say, Daywalker, I've been admiring that Corsair landing on the AC in your signature for some time now...could you tell me where you got the pic and if that is an available print?  Thanks.
    September 2007
Posted by dirtball on Monday, April 14, 2008 2:32 PM
  Well guys, I took the plung today and ordered the Quickboost engine and Aires wheel wells from Sprue Bro. I also ordered my paint and flap set from Great Mod. My LOVELY wife was kind enough to ok the puchasses! Wish me luck.............Harv
    September 2007
Posted by dirtball on Monday, April 14, 2008 2:50 PM
  Just a quikey, does the carrier base planes use smooth or diamond tread tires? Thanks.........Harv
    October 2007
Posted by Summit on Monday, April 14, 2008 7:11 PM
Harv, it looks like whatever you prefer. I went through 5 different Corsair books and they all show mixed patterns. Most of them you cant make out, as they are moving but there are planes with the smooth then some will have diamond tread. Being's the short supply of resources  during the war I would not be suprised to see a aicraft with one of each.
Edit----- I am seeing a pattern that most of the Diamond treads were on late WWII Corsair's and Korea.  But this is not fact as I said most of the pics you can not make out and some are not dated. I am just going by the references I have and some spare time, I am not an authority on this subject or any come to think of .... Confused [%-)]
    September 2007
Posted by dirtball on Monday, April 14, 2008 8:28 PM
  Thanks Sean. By the time this build is over, most of us should be "experts"........Harv
    February 2008
Posted by piperjoe on Monday, April 14, 2008 8:35 PM
Harv, I too looked at some photos and it looks like more smooth tires show up.  For what it's worth, I checked my Tamiya F4U-1D kit and the tires are smooth.  I'm going to use them as they came in the kit on my build.
I ACTUALLY STARTED my build today!  Working on the "office".  Went to the LHS with my wife Saturday and SHE helped carry 19 Tamiya paint jars and 2 cans of Tamiya AS 8 paint to the counter...and she was smiling!!!  Angel [angel]
Posted by navypitsnipe on Monday, April 14, 2008 10:34 PM
Sounds like a keeper to me. i knew my wife was a keeper when i went to the LHS to pick up a Tamiya Lotus Super 7 (yes my blood is also part motorhead) and she picked up a Dodge charger kit to build at the same time. she even agreed to wait until i get back from deployment to continue working on it.
40,000 Tons of Diplomacy + 2,200 Marines = Toughest fighting team in the world Sis pacis instruo pro bellum
    September 2003
Posted by Daywalker on Monday, April 14, 2008 10:42 PM
Thank you, I really liked it when I found it so I added it to my signature.  It is a print by Stan Stokes titled "Corsair of the Intrepid" available here.  Thanks! Thumbs Up [tup]
Frank
    February 2008
Posted by piperjoe on Tuesday, April 15, 2008 8:16 AM
Navypitsnipe: (what exactly IS that?)  Sounds like you've got a real winner too! Angel [angel]
Thanks, Frank!  What a neat site to visit and look through all the aircraft paintings/prints. I appreciate the link.  Some great Corsair images there.  I believe you selected the best one. Thumbs Up [tup]
    September 2007
Posted by dirtball on Tuesday, April 15, 2008 12:13 PM
  Well I finished my ordering spree today. From Jerry Rutman, I ordered a prop and hub, and wheel update(tires) set. On a side note and off topic, I also ordered resin sets for the Trump P51c from him. A complete pit and also a wheelwell set that includes upper wing halfs with lamminar flow detail. Cant wait!! Doing a little work on the corsair pit today, we`ll see how it goes....Harv
    June 2007
Posted by Hartmann352 on Tuesday, April 15, 2008 8:44 PM
I hope to be starting soon....must ...finish...B-24.....P-40....and ... Corsair ...for other group builds first...must resist urge to tear into another airplane.
Fortulantely I have a wee bit-o'time to do this.
Oh & Gig, I might have to ammend the "no AM parts" I found a PE cockpit set I have for it....I might get really brave & dive into that part of this world.
Make a Toast [#toast]
Dave
"Yesterday is history, Tomorrow a mystery, but Today is a gift. That is why it is called the "present".
    January 2007
Posted by Gigatron on Tuesday, April 15, 2008 9:47 PM
Have at it, Dave.
I've been scratchbuilding parts FOR my PE set - what a world.  I pay money to have someone else do the work (in this case, Verlinden) and I still end up improving their stuff.
I've spent the last few hours making scale ammunition out of styene, .032 solder, lead foil and paint.
Here's how it all turned out:
Don't worry, in real life, it looks much better Laugh [(-D]
Enjoy,
Fred
    September 2007
Posted by dirtball on Wednesday, April 16, 2008 1:31 AM
Dave
Dave, just go for it. You wont be sorry ! PE is your FRIEND! But realy, give it a try. Its awhole new ball game. To me itis like a whole little model in its self. Lots of fun......Harv
 Oh and Fred, while your at it, could you make me up a couple of scaled feet of the ammo?
