BIG CATS GROUP BUILD 2008
    April 2005
Posted by Thunderbolt379 on Sunday, June 15, 2008 10:41 PM
Thanks SMJ and Scott, I was mildly surprised to find the weld trick is so easy to do. I might try heat-working the actual kit plastic one day too.
Well, here she is, all bits on (with the exception of an S-mine ejector which fell off and needs remounting, and three teensy latches on the inside of the commander's hatch, which don't show here).
Photobucket" border="0" />
Note there are no smoke grenade mounts. At least some of the LAH's Early Tigers at Kursk seem to have not been using them (the cover painting of Tiger in Action is an example, and the decal instructions indicated the same).
Okay, on with the masking while I'm waiting on the PE set, and I can look at getting the tracks ready too.
Scott, the Panther is looking good, it's a mite more tricky than others, I look forward to seeing her come together. My feeling is PE is probably going to be too fine for my dexterity and eyesight for any more than grills and racks, so I'll be watching how you handle this lot with interest.
Cheers,
TB379
http://worldinminiature.blogspot.com/
    November 2006
Posted by dupes on Monday, June 16, 2008 8:14 AM
T-bolt - looking really good. Thumbs Up [tup]
You probably mentioned this before, but are you going to add some PE grill screens?
Posted by espins1 on Monday, June 16, 2008 10:40 AM
 ps1scw wrote:
I'm just finishing up their Premium A, looks like they decided to keep the color instructions, I got used to them, but I prefer the standard two color black/blue type.
I'm glad they at least included the black, white and blue style for the detailed assemblies, such as for the jack and exhausts.
Sometimes the photo instructions make it really difficult to see exactly how a part is supposed to be placed.  Case in point part #P7....
Scott Espin - IPMS Reno High Rollers  Geeked My Reviews
    April 2007
Posted by SMJmodeler on Tuesday, June 17, 2008 7:37 AM
Scott: Some nice detailed info and guidance, looking good!Thumbs Up [tup]
T379:  I've used a wood burning tool to do weld seams and, if you can believe it, ZIM'!...it worked pretty good too, I'll post a pic' if you'd like.  By the way, when do you plan to start painting?
    April 2005
Posted by Thunderbolt379 on Tuesday, June 17, 2008 8:38 AM
Hi Dupes and SMJ --
Yup, I'm waiting on the Eduard PE grill set for the engine deck, it should be in the post any day now. And that answers the second point, as they're the last structural parts needed before painting. With luck I could have her in the paint bay in a couple of days. I've only got 4 bars pressure left in my tank, though, and that may not get me there (the last bars disappear quicker than the first ones do). I have the overall yellow to do, then the redbrown stripes, then the fade coat on the upper surfaces, spray the tracks and spare links... We'll see. I need a gas bottle change sometime soon, that's for sure. But this kittie will definitely be ready for action (read, the glass case!) in time for build's end!
Glad you like my work guys, it means a lot from modelers of your calibre!
Cheers,
TB379
PS: Next-day ammendment: The Eduard grills were in the mail this morning!
    April 2005
Posted by Thunderbolt379 on Wednesday, June 18, 2008 7:38 AM
...And here she is with the PE grills installed. I'm very impressed with these grills, excellent parts that take about ten minutes to install, and look great under paint.
The masking is underway here, all twenty axles have been masked with tape and Maskol, and the locators for all tools likewise, along with the exhaust connector points to the Feifels. The inner end connectors are still to go, along with the jack, jack block, crowbars and flank tow cable attachment points, and the turret slide rings on both hull and turret base, and the track connector ends.
I'm optimistic of getting some paint onto her tomorrow.
Cheers,
TB379
    April 2005
Posted by Thunderbolt379 on Thursday, June 19, 2008 7:49 AM
Hi again,
The big cat was in the paintshop today, here she is with a couple of coats of dunkelgelb applied (lightened 20% with white to offset the darkening effect of oil washes to come).
Academy matched the colour of the plastic very closely to dark yellow, presumably so an inexperienced modeller would get an appreciably finished look without painting.
In the same round of work I also got the tracks done:
I used the same formula as for the StuG III for "The Hunters." They were sprayed dark brown acrylic (mixed shade) to represent the oxidation colour of the high-manganese steel of German tracks, given acrylic washes, to suggest surface rust, of lighter, brighter shades, then drybrushed with mixed enamel gunmetal for the bare steel areas. They'll get plenty of MiG dust to finish off with. I don't think the rust shows up too well on this photo, they look better in real life...
It'll b a couple of days before I can get back to the project. When I came to spray today I had barely 2 bars pressure left, instead of the 4.5 I expected. I may not have closed the valve fully on my last spraying session, and the air bled away. I've never done that since the first gas bottle I ever had, which was around 1995 or earlier. I'll change it for a full one in the morning, but I have to be away Friday afternoon to Saturday night (Aus time, it's Friday tomorrow here), so Sunday will be my first chance to blow the wheels into yellow, tackle the rotbraun overspray, then the fade coat, and spray the spare track links. There's plenty to do yet!
Cheers,
TB379
    April 2007
Posted by SMJmodeler on Thursday, June 19, 2008 8:02 AM
T379:  I like those screens, and it's good to see some paint on that Tiger!Thumbs Up [tup]...bummer about the gas bottleDisapprove [V]
    November 2006
Posted by dupes on Friday, June 20, 2008 10:17 AM
SMJ - need a slight adjustment on page 1...it should read "Tamiya Tiger I Early 1/48". Wink [;)]
In an effort to get my butt moving (and crank out some builds!), I've decided to scale down (get it? Laugh [(-D]) my project a tad. Been jonesing to do one of these Tamiya 1/48 kits since I snagged a few a while back...and while it's only 1/48 scale, it's still a Big Cat! Big Smile [:D] Here's what it looks like so far:
I'm pretty sure I'm not a huge fan of the die-cast chassis' on the Tam 1/48 line - not sure I see the point, and plastic is much easier to work with? Anyhoo, this one should build up pretty quickly. Going OOB, adding some homemade screens, and then it's off to the paintbooth. Found some decent pics of the tank Tamiya used for the markings options in Tigers In Combat I, will post one or two when I get a chance. Cool [8D]
    April 2007
Posted by SMJmodeler on Friday, June 20, 2008 10:34 AM
Done!
That Tiger is my first choice if I ever try the 1/48 thing.  I'll be watching closely to see how that one comes together!
    May 2007
Posted by Specter on Friday, June 20, 2008 12:37 PM
Started my KT the day after I got in the gb and I have no idea where the time went the build is going so fast. Still a good amount to do still though. I'll post pics soon. Really liking the gb SMJSmile [:)]
Scott: I said I would tell you how the build goes. It's just like any other DML KT, you just have to make sure there are no/or fill gaps in a few places due to the zimm, other than that everything is great
Seth
    November 2006
Posted by dupes on Friday, June 20, 2008 5:49 PM
I'm pretty interested myself! Big Smile [:D] Seen some good results here on the forums, figured it was time to give it a try. Thinking of doing a bunch of these on little dio bases...throw them on display at my wife's office, try to generate a little "local interest" in the whole modeling scene. Propeller [8-]
Should get a bunch done later tonight. Wink [;)]
Posted by Bish on Saturday, June 21, 2008 12:41 PM
Finally managed to get started on my Tiger on Thurs. mainly been working on the Verlinden engine compartment, as thats part of the dio for it. Unfortunatly i start work again on Tues which means i only get to build at weekends from now. hopefully i will be at a stage to get some pics posted next weekend.
    April 2005
Posted by Thunderbolt379 on Sunday, June 22, 2008 7:53 AM
Hi guys,
I got the gas bottle changed on Friday morning, and was able to get back to the project today. Here she is:
I used Tamiya acrylics all the way. The rotbraun is lightened 10% to match with the dunkelgelb, to offset the darkening effect of the oil filter to come. I used the Paasche #1 tip and needle but frankly was very disappointed with the result. The paint spattered, didn't want to come up the syphon despite thinning way over spec, and overspray was fully as bad as with the greens. It makes me think longingly of the velvet application of enamels. Okay, they stink, they're toxic and their cleanup smells like a gas station, but what a beautiful paintjob they do!
I used the extra-thinned dark yellow left over from doing the wheels (both sides of them all excepting those combined as the 16 twin-wheel units, two coats, plus drives and idlers, sprayed through a template) to touch up the oversprayed yellow.
Also, the fineness I expected from the small tip was totally absent. I was spraying lines as fine as this with a single-action Badger nearly 30 years ago. As a result, though Bison supply (on the web) a colour profile of each vehicle, based on their research, duplicating the 'actual' pattern on LAH 1325 was simply not possible. This pattern is generic/fictional, whatever you want to call it, and permisible perhaps only because there was no specific pattern on German armour.
Next will come a subtle fade coat on the upper surfaces, applied quickly, along with airbrushing the spare track links, which I forgot to do when doing the tracks as a whole. Then I'm onto detailing, tools, touch up the tires, and start the weathering... Hopefully the fade coat and oil filter will together draw the cammo colours into one 'element,' and de-emphasise the shortcomings of the sprayjob. Then I can add all external fittings and the running gear. Decals and dust should finish the process -- hopefully before the end of the week.
Cheers,
TB379
    April 2005
Posted by wing_nut on Sunday, June 22, 2008 9:37 AM
Lookin' really good tbolt.  I am about to start spraying the same 2 tone on the KT I am working on and was wondering what those colors look like without the green.  Now I know...and I like it.  I wanna see this one done.
Marc
Posted by Bish on Sunday, June 22, 2008 10:40 AM
If anyone is thinking of useing verlindens Tiger I engine compartment, all i can say is DON'T. The fit is awful. Once you manage to squeeze the engine in, the pipe work dsoesn't match.
 I was thinking of useing a Verlinden engine for a Panther, but now am thinking of the Czech Master one, even though its over twice the cost. Has anyone used these before, for what ever vehicle.
    April 2007
Posted by SMJmodeler on Monday, June 23, 2008 7:31 AM
T379:  Sounds like your a bit disappointed now but hang in there.  The first thing I notice is the difference in the spacing of the camo' on the turret versus the hull.  I think the results on the turret are great, I like the tight curves, zig-zags, and variations in width of the lines.  The hull is missing that "random" feel, take another look and see if that helps...
    April 2005
Posted by Thunderbolt379 on Monday, June 23, 2008 7:47 AM
Hi Wing_nut and SMJ,
Thanks for your positive comments -- she doesn't look too bad, though not as authentic as I had hoped. The paint really fought me, and when I got to the hull I swear the AB 'blatted' before my eyes... I had to mop paint off with a paper towel in a couple of places, and was glad to finish up where I did. Yes, the brown areas are proportionally heavier on the hull, and less 'random,' and I've already toned them back with yellow. The problem with getting them any narrower, or even a different shape, is the overspray factor of the yellow -- they'll speckle away to fuzz if I try to narrow them. I think I got the turret as good is it is because the paint was barely flowing through the AB at all. I got finer control with enamels when I did my IP M1.
I could try again, but I'm not confident of better results, and this beast is on a schedule. I was going to work on it today, but didn't get a chance... This build has a week to go, right? I'll take a look in daylight tomorrow, and see if I can refine the paint any more before going to the oil washes.
Cheers, guys,
TB379
    November 2006
Posted by dupes on Monday, June 23, 2008 7:55 AM
A week to go? Holy cow I hope not! Shock [:O]
Pretty sure we've got til the end of the year, right?
T-bolt - how much are you thinning your acrylics? If you're using Tamiya like I do, you need to cut it WAAAAAY down. I use 50% as my starting point - half paint, half alcohol. It takes a bit longer to get coverage, but the control is much better. Smile [:)]
    April 2007
Posted by SMJmodeler on Monday, June 23, 2008 8:23 AM
WHOAAAAA!!!...Shock [:O]Shock [:O]Shock [:O]...big fella', you have until December 31st!!!
    April 2005
Posted by Thunderbolt379 on Monday, June 23, 2008 9:47 AM
Hi Dupes and SMJ,
Yup, I'm thinning at 1:1, even going beyond that in the hopes of control, but not having any luck... I keep cleaning the AB, using my Paasche cleaning brushes on the paint pickup and needle channel, lubricating the needle with petroleum jelly, and have a wide range of pressures available... Thinned paint and low pressure is supposed to equal control, but I've not encountered much. At this point the AB is great for single colour subjects or masked colours, but for softedge I've not got her tamed...
Now where did I get the impression this build finished at mid-year??? Here I was hurrying thinking I needed her done in a week to get my badge!
Thanks guys!
Cheers,
TB379
    November 2006
Posted by dupes on Monday, June 23, 2008 10:55 AM
Dang...that's weird that the paint won't behave for you. Have you tried bumping the pressure up a bit? I know I always shoot around 20-25 in order to get good effects with the hyper-thin paint.
Hey, side note for you T-bolt - I know you expressed interest in the 251 GB a little while ago - the "official" thread is up in the GB section. You should take a look at it.Wink [;)]
That goes for any of the rest of you who are interested as well!!! Big Smile [:D]
    April 2005
Posted by Thunderbolt379 on Monday, June 23, 2008 7:53 PM
Hi Dupes,
Yes, I raised the pressure above 20 and got back some control, but the flow rate was then too great. You know, I'm thinking the problem might have been triger-stick. She was blowing through too much paint as if the needle was getting gummed up and jamming too far open... I'll give it a thorough clean and lubricate and take another crack. If I can thin-down and randomize the pattern a bit more, I'll be happier!
I don't think I'll have time to come aboard the 251 build, unfortunately... I have a Merkava waiting for completion, Battle of Britain is now underway, I've not touched my entries for Mustang and Corsair yet, and I've been casting longing (over-ambitious?) glances at Scott's Red Storm on the Reich, even the Cold War build... I dunno how I'll fit 'em all in! Especially as we suspect we'll be packing to move house yet again in just a few months... YUCK. I'll be happy if I get half of that lot done by next April!
Good news is I've found a source for those Eureka tow cables from Poland at half the Aus price... (Model Point US)
Cheers,
TB379
    November 2006
Posted by dupes on Tuesday, June 24, 2008 7:13 AM
Hey, no problem. I know that moving really bites...if it happens to go well, or you manage to squeeze in some more build-time, let me know! Cool [8D]
    March 2008
Posted by TacoBuff on Tuesday, June 24, 2008 10:59 AM
hey guys, sorry i dropped off the map for a while.
quick question.  I'm working on the single link tracks for my KT that are included in the kit. These are very time consuming to put together, and often don't come out straight.  Any suggestions as to how to ease this progress, or where i can find some affordable replacements?
rememeber 'affordable' being the key word.
thanks
    November 2006
Posted by dupes on Tuesday, June 24, 2008 11:25 AM
Tacobuff - couple of questions for you - what manufacturer KT are you doing? And what kit by said manufacturer? I have a set of left over Tamiya rubber band tracks from the KT "Ardennes" I did, which you're welcome to have if you're interested. Other than that, there are several companies that make replacement tracks, but I don't know if they're going to be a) affordable or b) any easier to put together than the ones you have now.
Go into the armor forum and use the search function, look up "indy track tutorial" or things like that, there's lots of good past info on assembling indy links. Thumbs Up [tup]
    April 2005
Posted by wing_nut on Tuesday, June 24, 2008 11:34 AM
tacobuff, here is a link to a toot the doog put up at armorama.  I follow that procedure and have no problems with the indy links
http://armorama.com/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=1737
Marc
    March 2008
Posted by TacoBuff on Tuesday, June 24, 2008 5:56 PM
hi guys,
thanks for the link Wing Nut, this'll help.
Dupes, i'm building DML's King Tiger Porsche turret kit #6189.  The links are molded onto sprues, so each must be trimmed then cleaned.  I'll try the tracks using wing nut's link, but if that doesn't work, the rubber bands would be a great help (i prefer them anyway).
thanks
    November 2006
Posted by dupes on Wednesday, June 25, 2008 7:38 AM
Hey, no problem, just let me know if you need them. Thumbs Up [tup]
That Doog indy toot is really good. Definitely give it a try. But you have learned now why Dragon switched to Magic Tracks! Big Smile [:D]
Have some pics to put up of the fully assembled and ready for paint Tiger, just need to roll them through photoshop...should have them up by lunchtime. Wink [;)]
    November 2006
Posted by dupes on Wednesday, June 25, 2008 9:02 AM
Alright, the phone stopped ringing for a couple of minutes and I threw these on Photobucket.
Pic #1:
Finished assembly before paint. I made some custom mesh screens, I think I got the size of the grates about right. Didn't make the frames, but they're quite small, and only the most discriminating viewers (i.e., you guys!) will notice anyway. Wired the headlights and smoke grenade launchers. Also tried to simulate some of the cast look on the turret, but it looks like it got mostly swallowed up with the base coat of paint (see pic #2). Yes, there's a row of roadwheels missing, they wouldn't stay in without glue, so I left them off. Wink [;)]
Pic #2:
A quickie after I finished spraying the base coat (didn't bother to set up the booth again). Going with a mix of Panzer Gray I read about incorporating a bit of blue, wanted to give it a shot. Came out verrrrrrry smooth, going to hit the panels with a highlighted coat tonight. Big Smile [:D]
