Battle of Britain GB 2008 - 21 June to 31 Oct 08
    December 2004
Posted by luftwaffle on Monday, August 11, 2008 6:55 PM
 Daywalker wrote:
Darren- Could you add the Spitfire I built to the list too?  Figured it counted as one that sat around for a while waiting to get finished.  Thanks!
Darren, hey while you're at it could you make a slight correction on My Do 17, it's actually a 1/72 Monogram kit.  Thank you sir!
aka Mike, The Mikester My Website
"He has all the virtues I dislike and none of the vices I admire."   -Winston Churchill
    April 2005
Posted by Thunderbolt379 on Monday, August 11, 2008 7:19 PM
Hi all,
Well, I'm sold on the Promodeller wash! It's a fantastic result, I'd never have expected so crisp and clean a definition in so small a scale, and also that the contrast would feel so 'right' -- amazing! There's been discussion lately about panel washes being more artistic than realistic, a situation where less-is-more, and this certainly feels on the realistic side of that equation.
I see there are four shades -- which did you use, Mike? I'd have thought black would be too stark for 1:72 except over a very dark base colour -- if pursuing other techniques I'd have been mixing a mid-gray.
Got two bits for the Dornier glued together last night. Poor fit on the nacelle halves, they needed reinforcing and will call for a spreader of some sort to match the cowl width. I have the main wing together and will add the nacelles in the next bit of work.
Cheers,
TB379/Mike
http://worldinminiature.blogspot.com/
    December 2004
Posted by luftwaffle on Monday, August 11, 2008 7:43 PM
Mike,
I used the "Dark" wash (which is kind of a medium-dark gray color) on my Emil which is good for light to medium colors.  I have not used the Black yet, but I think it would work well for darker schemes, here's an F-4 that I did with the dark, I think it would have looked better with the black because you don't get much of an effect here:
    September 2003
Posted by Daywalker on Monday, August 11, 2008 7:48 PM
I went over to the Sprue Bros site, and they're out of the Dark.  I opted for an email notification when it is in stock.  Can't wait to try it after seeing your results! Thumbs Up [tup]
Frank
    April 2005
Posted by Thunderbolt379 on Monday, August 11, 2008 7:53 PM
Hi Mike,
I see -- I think I'll order some! The gray is subtle... Frankly, your F-4 looks the deal to me, it comes out on the realistic side of the equation, and while the eye has become used to clearly accented panel lines as a modern modelling standard, my eye sees a much more realistic effect here -- it makes me want to pull out something and build it quick!
This shade should also be excellent for USN gray-and-whites... the possibilities are endless. I'll have to watch the use vid at the site.
Cheers,
Mike TB379
PS: That's a beautiful Ferdinand of JG54 -- what was the kit, and what decals???
    December 2004
Posted by luftwaffle on Monday, August 11, 2008 8:18 PM
 Thunderbolt379 wrote:
Hi Mike,
Cheers,
Mike TB379
Thanks, Mike.  It's the FineMolds kit and the decals are Aeromaster's "Luftwaffe Top Guns".
Posted by rjkplasticmod on Monday, August 11, 2008 8:45 PM
Beautiful work on the Emil, Mikester Thumbs Up [tup].
Regards,  Rick
    September 2004
Posted by razordws on Monday, August 11, 2008 8:45 PM
 Wow, that is looking real nice there Mike.  I'm really going to have to step up to the plate with you and Frank setting the bar so high on the 109's.  Thanks for the tip on the wash.  I think I'll have to hunt some down too.
Dave
    April 2005
Posted by Thunderbolt379 on Monday, August 11, 2008 9:13 PM
Hi Mike,
FineMolds and Aeromaster -- gotcha!
The decals arrived in today's mail, many thanks! I checked them against the instruction sheet and found where they go, with the exception  of the white 'B's -- where on the airframe would they end up? I can research the KG3 squadron badge and take a crack at creating it as a custom decal on some white inkjet decal paper I have.
Excellent!!!
TB379/Mike
    December 2004
Posted by luftwaffle on Monday, August 11, 2008 9:22 PM
Mike, I think the white "B"'s are the outline for the red "B"'s, it's a two part decal so you get a red "B" with a white outline.
I'm confused on the squadron badge, I thought I put those in the envelope, should be the red and white shield with the two Maltese crosses on it?
    April 2005
Posted by Thunderbolt379 on Monday, August 11, 2008 9:54 PM
Hi Mike,
Yes! I checked the envelope again and there they are -- the badges.
Ah, now I see! It's actually a black fine B that overlies the heavier white B to create the fuselage code. No worries!
Well, I gotta crack on with this beast. I'm doing some PhD work right now on a gray and cold afternoon in Aus, so I might reward myself with a bit of plastic art... One nacelle half left to scribe! Then I can assemble the port nacelle, mount both to the wing and get some filler into the joint (looks like it'll need it, no way will that gap pass muster as a natural panel division!)
I'm still waiting for that package from Hong Kong, I'm dying for that Tamiya Emil!
Cheers,
Mike/TB379
    December 2004
Posted by luftwaffle on Monday, August 11, 2008 11:05 PM
Phew! Thought I was losing it there, glad they're in there! Big Smile [:D]
    April 2005
Posted by Thunderbolt379 on Tuesday, August 12, 2008 12:20 AM
Hi Mike,
Right, everything's under control -- accessories are on their way too. Vacform clear parts, weighted tires, balkenkreuzers and swastikas. Next I need to go shoppig for paints, and some of that panel wash.
I've scribed and assembled the starboard nacelle. The parts fit is poor, very flimsy, it'll take some superglue here and there. They'll strengthen up when the engines are attached, but that'll be later in assembly.
Cheers,
Mike TB379
Posted by darson on Tuesday, August 12, 2008 2:26 AM
Gents I've updated the front page with the completed builds so if I have missed anything else out just drop an abusive post, I'll get the message Wink [;)]
Frank, first up I need to say sorry because I completely missed your 109.  I've just gone back a few pages and checked it out and WOW fantastic job and very nicely photographed as well Thumbs Up [tup]Thumbs Up [tup]Thumbs Up [tup].
Mike RLM 02 is the correct color for the IP before the Germans switched over to RLM 66 and fantastic work on that 109 of yours, you would honestly never know it wasn't 48th scale.
Cheers
    April 2005
Posted by Thunderbolt379 on Tuesday, August 12, 2008 2:45 AM
Hi Darren,
This is a busy build, and a lot of fun! Could you update my listing also? I'm still waiting on that Emil (any day now, c'mon Australia Post! You can do it!), but I've made a good start on the vintage 1:72 Matchbox Do 17 Z-2, with decals courtesy of Luftwaffle and accessories by Squadron.
Cheers,
Mike / TB379
    September 2003
Posted by Daywalker on Tuesday, August 12, 2008 7:17 AM
Thanks Darren, much appreciated!  It was a great kit and one I enjoy building often.  Prolly will do another one for next year's BoB GB! Big Smile [:D]
I don't remember the page it was posted on, but Stan (Phoenix7187) finished his 109 as well. Thumbs Up [tup]
Frank
    December 2004
Posted by luftwaffle on Tuesday, August 12, 2008 9:06 AM
Cheers
Darren- Thanks! I had some color pics of the IP but they were restored aircraft, which are always suspect.
    July 2003
Posted by sidure on Tuesday, August 12, 2008 12:29 PM
Mike, very nice work indeed and like the way its turning out
Steve
    December 2004
Posted by luftwaffle on Tuesday, August 12, 2008 1:01 PM
OK, she's finished, all of about 2 1/2 days of work, this is a record for me I think!
Once again "White 2" of 4./JG 51 operating from Marquise, France in August of 1940, piloted by Ofw. Hans Illner.  Illner's combat career lasted until 5 November 1940.  While flying over England in another aircraft he noticed a Spitfire coming in from behind.  As an evasive maneuver he put the plane in a high speed dive but lost the starboard wing while pulling out.  He was obliged to bale out and was captured.
What's next on the agenda?  I have no idea!
    October 2004
Posted by sfcmac on Tuesday, August 12, 2008 1:45 PM
 Absolutely astounding Mike! That has got to be near the best 1/72 109 done in 2 . 5 days I have ever seen! Bow [bow] I am crazy about your choice of markings as well. Looks concasmigorical fer sure! Yo!
 All the work here is just the best thing since sliced bread! Been all I can do to keep up with the E-mails! Darren may have to take holiday just to keep up! Make a Toast [#toast]
    September 2003
Posted by Daywalker on Tuesday, August 12, 2008 2:17 PM
Outstanding work Mike!!!
2.5 days?  My spinner took longer than that.  Beautiful work there my frind, and the photos are awesome too! Bow [bow]
Frank
Posted by rjkplasticmod on Tuesday, August 12, 2008 2:20 PM
Mike,  Absolutely beautiful Emil Thumbs Up [tup].
Regards,  Rick
    December 2005
  • From: back seat of your car with duct tape streched out
Posted by soulcrusher on Tuesday, August 12, 2008 5:02 PM
Now thats some top notch work there Mike! I love that Emil and the markings are a nice choice also.Thumbs Up [tup]
        Soulcrusher
    February 2007
Posted by Luftwoller on Tuesday, August 12, 2008 5:09 PM
Oh yeah Mike. Shes a doozy for sure. Looks spot on from here anyhow. You say you did it in 2 1/2 days. Frabulungtious for sure buddy.
Plenty of time till the end of the GB so hows about another 30 or so?
...Guy
..'Your an embarrassment to the human genus, makes me ashamed to call myself Homo'.
    December 2004
Posted by luftwaffle on Tuesday, August 12, 2008 6:09 PM
...Guy
Thanks for the comments guys.
Guy- 30 more, huh?  Only if you know a good divorce lawyer (barrister?)! Laugh [(-D]
    December 2005
Posted by soulcrusher on Tuesday, August 12, 2008 7:06 PM
Well I am still at a standstill! No Airfix Hurricane that I ordered back on the Aug 3 and no decals that I order over two weeks ago from a different supplier! The good new is i made good progress on my  Tamiya Fw190 D for the Fw190 GB. She is already in the paint shop. Stark contrast compared to the Hurricane when airbrushing. On the Hurricane every color separation is masked. On the 190 every color separation is soft edged! Man I better have something in my hands tomorrow afternoon or I'm gonna start kickin' some butts!
        Soulcrusher
    April 2005
Posted by Thunderbolt379 on Tuesday, August 12, 2008 7:18 PM
Hi Mike,
That's a 2.5 day build? I'm absolutely blown away! Your 109s are amongst the best work I've ever seen, and you really give me a standard to aim for! The overall standard of work on this GB is amazing, it's truly publication quality, and I'm very glad to be involved!
Mike/TB379
    December 2005
Posted by soulcrusher on Tuesday, August 12, 2008 7:19 PM
Almost forgot! Darren than you for updating my info on the front page but i need one more favor from you pal. My Classic Airframe fabric wing Hurricane has risen from the dead! She has been stripped cleaned up and repainted now currenty wating on a very late set of new decals. thanks buddy.
        Soulcrusher
Actual photografic proof!
    September 2004
Posted by razordws on Tuesday, August 12, 2008 8:17 PM
Pbbbth.... pplnnvbbber...  sorry for the unitintelligible blather.  Just tying to comprehend how Mike built that Me 109 in 2 and half days.  Confused [%-)]Confused [%-)]  Outofthisfreekinworld Mike!  Bow [bow]Bow [bow]Bow [bow]
Mine is going to take 2 and a half months at my current rate.  Sigh [sigh]
Dave
    July 2003
Posted by sidure on Wednesday, August 13, 2008 1:15 AM
Holy cow Mike. Stop joking with us, please tell me its 1/48. I cant make a 1/48 look that good. Your build inspired me to do an 1/72 Airfix to go along with my FW-200, someone asked for a scale refrence so I am building Gallands bird. I can only hope mine is half as good as yours turned out. Congrats on a great build.
Steve
