Hi guys,
Vinyl masks! Why didn't I think of that! I searched Squadron at once but can't find them, and they're not in the last printed catalog I received - which is wierd as I have a wheel mask set or two and they can only have come from Squadron... Any recommendations for an outlet for Eduard canopy masks? I can at lest see if a set is made for this subject.
I'll forget BMF -- thanks for the tip! More frustration in my life I don't need! Tamiya tape -- love it, have plenty, I can give it a shot. I was thinking of perhaps masking the panels while the parts are on their sheet for rigidity, then scoring them out, cleaning up and attaching them. Would you recommend a #11 scalpel blade for a job as delicate as this? I have a handle in my toolkit from years back. (I usually use a cheap carton-ripper for all my craftsmanship, sounds crass but it just comes naturally after all these years!)
Can you also suggest a good clear-parts cement? I don't think white glue is going to be good enough.
My other option is to go with double-sprayed decal film, which I've had good results with, but never on this scale.
Steve -- I remember Parafilm-M, I used it in the university labs many years ago. Very clingy! But maybe a bit thick for this type of application -- we'll see, it might end up being an unorthodox solution.
There's also a fisk-film/frisket material made by Revell, my local toystore has some on special (or they did have last week). Might be of use...
Cheers guys! Well, I have no excuse not to get on with this thing now...
Update -- just did some surfing and while Eduard don't have a set for the Do 17Z they sure have one for the Do 215, which was the export variant of the Z series, and the planes appear to have shared almost identical canopies. CX-187 is the factory ref on the set -- now all I need is an outlet!
Mike/TB379
