The yellow appearing as red is due to the use of orthochromatic film.
There are a couple of great pics of a Fw190A in Brett Green's Gotterdamurung, one taken with orthochromatic, the other with panchromatic film, and you would swear they were of different machines, so differentlyis the yellow rendered in each frame.
Steve, great job on the Kondor and the Emil.
With the paintwork on the 109 bear in mind most Emils we repainted from 70/71/65 to 71/02/65 in the field. This included raising the upper fuselage camo demarcation line from very low on the fuselage, to very high, to better suit the conditions in France and the UK.Often the paint was applied with brooms, rags or sponges, hence the less than straight demarcation lines.
I know what you mean about tape usage, I used shed loads on the He 111!
The Hurricane is almost done.....
...aiming to finish off both this and the 111 tomorrow.
Only one cock up on the Hurri, I managed to apply the wrong serial number, don't know how, but I did. Luckily it's obscured by the squadron codes.
Karl
