The Forgotten War GB (6/25/08 - 2/28/09) - Deadline Extended Yet Again!
    December 2003
Posted by sanderson_91 on Friday, September 19, 2008 7:53 PM
Harv - great looking Sabre.  I've finally finished my F-86F done as Shirley's Texas Tornado.  Here are a bunch of pics:
I'm now getting started on the Monogram A/B-26 Invader. I'll post some progress pics as I go.  Thanks!
Steve
    September 2007
Posted by dirtball on Friday, September 19, 2008 7:59 PM
   Steve, that looks fantastic!!  Is it 1/48? Also the yellow stripes look painted on with the pannel wash. Are they?Thanks for the post. Hope mine comes out as good!!.......Harv
"I once shot an elephant in my pajamas. How he got in my pajamas, I`ll never know!"
    December 2003
Posted by sanderson_91 on Friday, September 19, 2008 8:13 PM
Harv,
Thanks!  This is the 1/48 Hasegawa F-86F-30.  I did paint the ID Stripes - what a lot of making!  There are also about a million decals to put on this bird - but the end result is well worth it.  I also used four shades of Alclad - Polished Aluminum, Duraluminum, Aluminum, and Pale Burnt Metal around the tail.
Steve
    July 2004
Posted by mucker on Saturday, September 20, 2008 9:15 AM
Steve:
you really nailed that one! Wow! My only criticism is that the pictures are too small! Are you able to re-load them on Photobucket to a larger size, such as 640 x 480? That's a true beauty. If you re-photoed with a plan backdrop, you've got magazine article quality there.
The Alclad was flawless, too. What did you use as the undercoating for the Alclad?
Great stuff, Steve. She looks like she could take off and fly right now.
    November 2006
Posted by dupes on Saturday, September 20, 2008 12:26 PM
Wasn't I just saying something about awesome Sabres making me want to build a Sabre?
Steve - your definitely falls into that category! Those stripes, and decals, and NMF...all top-notch. Thumbs Up [tup]Thumbs Up [tup]
And you build armor, too...man after my own heart. Laugh [(-D]
    December 2003
Posted by sanderson_91 on Saturday, September 20, 2008 2:26 PM
Mucker and Dupes,
Thanks for the kind words!
 Mucker - Here are some larger images for you.  I need to get some blue construction paper and make a better photo area.  I used Krylon Gloss black and followed Swanny's instructions for the use of Alclad - this was may first use of Alclad - I really like it!
Dupes - I'm just starting to dabble in armor - I've only built a few armor kits, but have several in the stash that I want to get into soon.
    July 2004
Posted by mucker on Saturday, September 20, 2008 4:24 PM
Much better!
That really is a beauty. I'm glad your first Alclad experience was a good one. Some are scared off by NMF but if you have good results, like your Sabre, it makes it easier to select a metal airframe the next time.
    November 2006
Posted by dupes on Saturday, September 20, 2008 10:01 PM
Steve - think I just missed it...is that the Hasegawa kit, or Academy? And is that the kit pit?
If you're just starting in armor, that 1/48 Tamiya you have there should be perfect. Their 1/48 stuff throws together very easily - lets you spend more time painting and weathering. Thumbs Up [tup]
gzt
    May 2007
Posted by gzt on Saturday, September 20, 2008 10:02 PM
Gentlemen, you are doing excelent job here !
Absolutely fantastic Sabres !!!
John:
I studied a bit on Sabres wings and thanks to your explanation I finally decided to take a shot.
I have Hasegawa F-30 kit and I got Revell F-86D. After some thinking I decided to do it exactly the same way as it was done on the field Smile [:)] except opposite direction. I am going to cut a leading edge off of the F-30 Hasegawa F-30 set and tha same with Revell kit. Than I am going to use Revell leading edge (with slats) into Hasegawa kit.
 According to my sources Hasegawa kit has very good (practically perfect) sweep angle what is wrong on Revell kit. This is a reason I will keep Hasegawa wing and just replace the leading edge section.
 One thing bothers me though. The tip of the wing supposed to have aileron edge being part of the wing tip. None of the wings show this kind of configuration.
Do you have any pictures of the early wing (prior to 6-3 modification or even better maybe you have some drawings of the early Sabres wings ??
BTW: I faund drawings of F-86 however those may be wrong since even "A" wing has triangles at the root. In my understanding those were features of 6-3 modifications on Fs and some Es.
Flying is a thrill #2 known to mankind. Landing is #1.
http://www.rwd-6.org
    December 2003
Posted by sanderson_91 on Sunday, September 21, 2008 10:23 AM
Dupes,
This is the Hasegawa in 1/48. It was a pretty nice kit to build.  The only area that gave me trouble was the nose area - the nose cone was wider than the fuselage.  I also added weights under the cockpit so that this would not tail drag.
I used the True Details cockpit set (#49010) instead of the kit cockpit.  I did add to the kit gunsight with some small disks and decals to give it some life.  I also added a few details to the back deck since this are is exposed with the open canopy and the kit area is just blank.
I've liked the T-34 so far, I still need to add the right side tracks and then weather it. I've read a few articles on the dot weathering method which I'm going to try so the results should be interesting.
Steve
Posted by jeaton01 on Sunday, September 21, 2008 1:59 PM
Greg:
Yes, the sweep angle is better on the Hasegawa kit.  Too much on the Revell, and the Academy kit is off in other ways in my opinion.  The Revell F-86D has better upper surface detail and panel lines, and the aileron/tip configuration is correct for unmodified F-86A through early F blocks.  The triangle on the wing root is not present on the unmodified wings or on the F-86D.  It was necessary to allow the ammunition box doors to open.  On the early wings the wing root is right at the aft edge of that door.  With the leading edge extension the wing root would have trapped that door so it was necessary to make the wing leading edge easily removable in the overlap area. One bolt is all that holds it in place, accessible through a hole in the leading edge.  All ailerons on 37' 1" span Sabres form part of the wing tip.  The F-40 and F-86L wings had the 1 foot extensions to the wing making a span of 39' 1" and the ailerons stop inboard of the wing tip extensions.
I do have hundreds of photos of an F-20 with the 6-3 mod and the F-86L at the McClellan museum, but most are not up on my web site.  I have done detailed drawings of the F-20 6-3 wing but they are not quite done yet.
John
    September 2007
Posted by dirtball on Tuesday, September 23, 2008 12:39 PM
I need a favor. I thought I would post here first since its about my 1/32 Hasegawa F86. Does ANYONE have a spare set of leading edge flaps they would be willing to sell or trade?? One of mine hase snapped twice now, and I just tried to glue again. But it was on a paper towle and now the 2 have become one!. I realy dont want to try and find another kit(unless you might to want to sell the whole thing). Please help..................Harv
    September 2007
Posted by dirtball on Friday, September 26, 2008 12:20 PM
Not much going on here! Small update. Put the engin together with as few parts as I could to save weight. Goning to spray some silver on it and call that done, wont see it anyway. Also as far as front flaps go, I have a bid on ebay for the whole kit. The MISSES wasnt very happy about it especialy since I have a bid on an old Revell Mosquito also! Next week I will be on vacation for a few days and wont have a way to post. So you all behave yourselves, and post something............Harv
    July 2004
Posted by mucker on Friday, September 26, 2008 4:52 PM
Harv:
Sorry about the mishap. I wish I was able to help.
Have fun on vacatio. You know better than I do, but give the missus all theattention she needs on vacation!
    September 2007
Posted by dirtball on Monday, September 29, 2008 10:11 AM
   Well, lost the bid on replacement kit on ebay. SSOO...I may have one more fix up my sleeve for the leading flap i boogered up. We`ll see. Be gone  Wed. thru Sunday on vacation , and will get back to the Saber on my return..... On a happier not, I did win my 1/32 revell mosquito. I think I did real well with it. Got it for $35 including shipping! The others that were bid on were bettween $45-$75!..............Harv
    September 2007
Posted by dirtball on Tuesday, October 7, 2008 2:18 PM
   HELLLOOO, anybody out there??    I think I salvaged my leading eedge flap...Ihope. It looks ok, but you can tell the difference between the two. So on to the wing tips and then PE in the wheel wells. Will post some pics by this weekend ...I hope............Harv
    July 2004
Posted by mucker on Tuesday, October 7, 2008 7:05 PM
Good news, Harv.
Hopefully I'll start my T-33 over the weekend. I have some business travel this week limiting my bench time.
I have the Hobby carft kit in Korean War markings waiting at home. I also have the True Details cockpit and wheels so I hope to make this one fairly nice.
    December 2007
Posted by mg.mikael on Sunday, October 12, 2008 7:52 PM
Here it finally is, my finished M-30 122mm Howitzer!! Used pastels for dirt, and iron powder for soot. Shell crates are painted in ModelMaster Enamel Italian Sand, with a burnt umber wash. Overall this Zvezda kit was a joy to build, however instructions were confusing in some areas, and some of the parts do have tricky positioning. Though I would still recommend this kit to anyone who has at least built a few kits before. Thumbs Up [tup]
All questions, comments, and suggestions welcome.Smile [:)]
"A good plan executed now is better than a perfect plan next week." - George S. Patton
  Photobucket
    September 2007
Posted by dirtball on Sunday, October 12, 2008 8:53 PM
  MG, that came out Super! I gave you an extra thumbs up for being the first in almost a WEEK to post a pic!! Realy good job though. Hope you do something else, you got time you know......Harv
    July 2004
Posted by mucker on Monday, October 13, 2008 7:49 AM
That's awesome, Mg. Can you enlarge the pictures a bit, though? THe weathering looks good from what I can see. The crates are a nice addition. Is there a diorama in the planning?
    September 2007
Posted by dirtball on Monday, October 13, 2008 2:49 PM
Another pic-less update. The leading edge flap fiasco continues! BUT... I did win anothe one on ebay this weekend! Only $21 with shipping!. So when it gets here, I`ll be able to get back on it.........Harv
    December 2007
Posted by mg.mikael on Monday, October 13, 2008 6:42 PM
Sorry no diorama, my skill level is just not there yet, plus I don't have the time to complete one. But I will make some sort of wood base for it though.
I'm gonna start a thread about this howitzer in the Armor section, later today, I'll put up bigger pics in that thread. Hope you check it out.
  Photobucket
    September 2007
Posted by dirtball on Tuesday, October 14, 2008 9:36 AM
WOW thursday I`ll be 59!!But I feel like 30......most of the time. Yesterday I felt more like 79..................Harv
    July 2004
Posted by mucker on Tuesday, October 14, 2008 10:20 AM
Harv, you don;t look a day over 57! Whistling [:-^]
Happy early birthday. Happy B-Day [bday]
A slight case of bronchitis has had me away from the bench, but I'm slowly but surely detailing the True Details cockpit of the T-33. With any luck I'll take pictures over the weekend.
    September 2007
Posted by dirtball on Tuesday, October 14, 2008 10:46 AM
   Mucker, my friend, thanks a bunch. Ever since you posted you`d build the T-33, I`ve been excited to see picks. Love that plane!. Hope you feel better soon..........Harv
    September 2006
Posted by raptordriver on Thursday, October 16, 2008 9:54 PM
Hey Mucker, are what-ifs allowed? I have a 1/48 Monogram Helldiver I was going to build in korean markings. If so I'm in!Big Smile [:D]
Andrew
    July 2004
Posted by mucker on Friday, October 17, 2008 11:50 AM
Andy, unfortunately I'm trying to keep this as a historic GB. I do apoligize.
It is quite a neat idea, though and I'll be looking for it on the Aircraft forums. Are you going with the gloss dark navy blue color?
    September 2006
Posted by raptordriver on Friday, October 17, 2008 12:06 PM
Its all cool, I understand I am going for Gloss Blue paint job.Smile [:)]
Andrew
    September 2007
Posted by dirtball on Thursday, October 23, 2008 1:57 AM
  Well it looks like its up to me to reserect this GB again! Good news. Got home from work tonight and on the table was a package. And in it was a 1/32 Hase. F86. So now I have replacement front wing flaps!!. I can forget the one that snapped 3 times. So with any luck I`ll be at the bench tomorro working on the 86..........Harv
    August 2007
Posted by some assembly required on Thursday, October 23, 2008 7:36 PM
im so disgusted with the fit and detail on tamiys mig that i put everything back into the box and will try to find something else this weekend for the GB.Angry [:(!]
