Hi guys,
Mucker -- yes indeed, the Tamiya D falls together, the main structure consists of anywhere from 8 to 17 parts depending on how persnickety you want to be with definitions of 'main structure,' and the fit is close enough for a beginner to get away with undressed joints. I have noticed the Tamiya plastic reacts a bit with solvent-based putty, you need to mill the surface with wet sandpaper but liberal applications of putty (not that liberal applications are needed) would create surface problems that would stick out like a sore thumb through a NMF. That said, she's a beaty and I'll be building lots more of her. The pit is not quite as good as Hasegawa's, perhaps, but its quite good enough for most, especially at this scale. She'll look the part!
JMart -- we seem to have some characteristic spousal injuries happening... Harv's other half lost her gallbladder, mine lost hers years ago. Yours had leg/knee injuries, mine fell getting out of her truck a fortnight ago and -- you guessed -- has bone and ligament damage and will have a cast for the next month! I'm terrified to hear the next one to show up in case history repeats!
The Mustang is now largely together, I mounted the flaps and scoop details today and did a round of joint dressing. I'll be getting to detail painting soon, landing gear, warload, prop blades, and the yellow trim of the unit. With the month-long extension now in force (correct???) I have time to chase some Express Masks, as they were out of stock at Squadron when I placed my last order.
More pics tomorrow,
Cheers,
Mike/TB379
