Picking up from last week, the latest round of effort dealt with the white wash scheme as well as the remaining exterior details and getting that squared away.
First up, I used an old brush and stippled and dry-brushed MM enamel Russian Armor Green over the previous air brushed Flat White finish to create some wear and depth to the finish.
The same process was repeated with the Flat White to overlay the Green and mute some of the harshness and create the sense of brush strokes and transparency between the two colors. For the cupola the process was the same but I used Panzer Gray instead of the Green to keep its contrast as an add-on part compared to the original green of the T-34.
The process is pretty hard on the brush, so be prepared for it to consume the brush potentially in the process! By the time I was done, the brush was worn down pretty good but it was a noble sacrifice for the result achieved.
With that done, it was time to add the tools and other details for the exterior. Tools were detailed with MM Metalizer Gunmetal for their metal portions and given a light dry-brushing of Steel, the wood handle for the shovel was done with a base coat of 50/50 Light Gray/Panzer Dunkelgelb followed by a treatment of umber artist pastels, and the Bakelite handles on the wire cutters done using Italian Dark Brown. Spare track links were also detailed and installed at this point.
Rear hull got some attention as well, the exhausts were detailed with a base coat of MM Metalizer Gunmetal followed by a light wash of thinned enamel Rust. Once dry, some Burnt Umber and Black artist pastels were used to deepen the look and create some diesel soot accumulation. The rear Notek lenses were picked out with Tamiya Clear Green to round things out.
Front hull saw the addition of the hull MG and the driver's periscopes picked out using a combination of enamel Silver and Tamiya Clear Smoke. Enamel Silver was used for the reflective insides of the headlights as well.
Next up will be laying down the protective Future coat, adding the decals, and then starting in on the remaining weathering for the hull.
