thanks for all the comments, replies, and the time you took to check out my elephant guys.
dupes, you'll love the Aves. she's a blast to work with, the sky is the limit with this stuff.
FireFox, the only real trouble i had with this kit, is the delicate PE fenders. really have take your time with these suckers. make sure they align together, and once glued on, be very very consious and careful when you pick it back up for painting and things. i tend to forget that they were delicate PE and not moulded onto the hull. other that that, she fit together beautifully.
tigerboy, after painting the base coat on, i applied a few coats of future and gave it a nice dirty wash with a tad of van dyke brown, and raw and burnt sienna. i few if you need it darker, you'll have to be the judge of this. and i always use the .5 tamiya tool, i find it more in-scale.
crockett, i'm not sure of the gray styrene yoru talking about. maybe it was the angle of the camera or something. but it could also be the silver on the teeth that you are talking about. it did turn out kinda grayish in the pics. the pattern i followed was from the kit instructions, and i did a little research and i have found some patterns of this scheme from when (can't recall which unit at the moment) was in hungry. i haven't found any "actual" pics of this, but if its not correct, i had fun making it.
biffa, thanks for the comment about trying the zimm method. it really is simple, and i'm sure you'd have a blast trying it out.
and montana cowboy, your right, his name is jeff. not sure why i kept saying matt.
thanks guys
