Alan Panzer II ready for paint! *PICS*
    July 2006
Posted by bufflehead on Saturday, August 11, 2007 11:42 AM
In another thread I said the Alan Panzer II C was the worst plastic model kit I ever built. However, that's relative because its only the 8th kit I've built since returning to the hobby.  I just wanted a quick, little kit so I could practice on painting schwarzgrau vehicles and this kit was cheap and had few parts (compared to Dragon's Panzer I B).  Several weeks later here is the finished assembly ready for primer and schwarzgrau.  Most of the time spent was in correcting all the little molding flaws, improper fit of tracks, fenders and other items, and adding better fittings and accessories.
I didn't have a whole lot of references so some of my additions or corrections might not be totally accurate (ie, the fire extinguisher came from an old Panzer IV kit).
All the work I did on it makes it look pretty OK in my eyes.  I just hope I don't mess up the paint job!Dunce [D)]
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
Posted by tigerman on Saturday, August 11, 2007 12:00 PM
I think you'll be fine Ernest. It's looking pretty nifty so far. Did you come up short on links on the left side or did it break? Hopefully you can repair it.
 Eric
    July 2006
Posted by bufflehead on Saturday, August 11, 2007 12:09 PM
Thanks Eric.  The tracks are broken into two runs each for painting so they're not glued in those spots.  They'll be glued together on the suspension when the tracks are fully painted. Cool [8D]
Ernest
    May 2005
Posted by CDNTanker25 on Saturday, August 11, 2007 12:36 PM
Looks good and solid!  Now paint her up!  LOL Thanks for clarifying the tracks, was a little curious about that too!
James on the bench: Merkava II With MCRS-20% Merkava IID 75% IDF Magach Batash
    July 2003
Posted by diggeraone on Saturday, August 11, 2007 12:45 PM
you have done a great job.even if they are not the best kits to do you did it and thats a great modeler who can fix that is not right.Digger
Put all your trust in the Lord,do not put confidence in man.PSALM 118:8 We are in the buisness to do the impossible..G.S.Patton
    January 2005
Posted by biffa on Saturday, August 11, 2007 1:52 PM
Ernest wow you have really done a number on this one dood and i know from experience it couldnt have been easy but to say this is only number 8 this is quite impressive, a very well done and i look forward to seeing her painted.
Ron.
Ron g.
    January 2007
Posted by the doog on Sunday, August 12, 2007 12:21 AM
Looking good, man! Nice work on the jack assembly there!
Git 'er done!
    July 2003
Posted by madmike on Sunday, August 12, 2007 12:29 AM
Very nice so far! Beats the heck out of the old Tamiya one in the detail department. I am eyeing off a resin 1:72 Millicast PzII currently.
Love to see an IM release one day.
cheers
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
    July 2004
Posted by wbill76 on Sunday, August 12, 2007 12:31 AM
Nice work, the weld seams in particular add to the detail among the other additions. Ought to look good with some paint on! Thumbs Up [tup]
Posted by m1garand on Sunday, August 12, 2007 1:15 AM
Nicely done and would love to see it with fresh coat of paint in near future.
    February 2007
Posted by roosterpelo on Sunday, August 12, 2007 1:21 AM
looks nice. i like how you improvised and found spare parts or scratchbuilt for the bad pieces. i espically like the weld seams, what's the secret? look forward to seeing some paint on it.
chris d.
    September 2005
Posted by treadwell on Sunday, August 12, 2007 5:39 PM
let me 'ECHO' what the others have said!-- with your extra work, it is gonna look extra special --- treadCool [8D]
Posted by mark956 on Sunday, August 12, 2007 5:48 PM
Very nice. Can't wait to see it after it's painted. Thanks for sharing.
Mark
    July 2006
Posted by bufflehead on Sunday, August 12, 2007 8:01 PM
Thanks for the good words everyone, I really appreciate it and am glad others are enjoying the build so far.  Its already primered, basecoated and now is getting the highlight treatment.  I'll post some in progress photos in a couple of hours or so.
roosterpelo - I used 2 different methods for the weld seams.  For the turret I used the method Tom Cockle uses in his fine Osprey book, "Modeling the Early Panzer IV".  He uses a 2 part putty called ZimItRite (very similar to Aves Apoxie Sculpt) and rolls it very thin.  The thin string of putty is applied to the area and then a toothpick with a convex tip is used to make the weld beads.  He makes it look so easy and the results are fantastic, however I found the putty hard to use.  It kept sticking to everything and had a hard time laying straight.
I then resorted to the stretched sprue method for the hull.  I simply stretched some sprue to the appropriate thickness, cut it to size and glued them in the seams.  If there wasn't a seam I made one using the reverse edge/tip of a #11 blade.  This method is so much easier and less stressful!!  Once these were dry I used the hot knife method using a sharp blade tip to make the weld beads.  I brushed Tamiya Extra Thin Cement on these to soften the beads and to remove any stringers leftover from the hot knife.  The results may not be as nice as the putty method, but I at least I still have some hair left!Laugh [(-D]
Ernest
    February 2007
Posted by roosterpelo on Sunday, August 12, 2007 10:56 PM
thanks for sharing ernest. i just finished a T-34 where i had to make the weld seam on the turret, and i just masked it off with tape, and applied some tamiya putty. i have some aves and i'll have to try that method, or the thin rod treament with glue and a hot knife. thanks for the helpful tip.
roo
chris d.
    July 2006
Posted by bufflehead on Monday, August 13, 2007 9:18 PM
No problem roo!  The tape and putty method works too!  I just like to experiment and try different methods.
I tried to post this last night, but the forums were down.  Then I tried to post today, but turns out my work has blocked photobucket.  Anyway, this is what I've done so far:
I primered with Mr. Surfacer 1000 in a spray can, then preshaded with Tamiya XF-17 Sea Blue (suggested by fingerseddie), then mistcoated with Vallejo German Grey.
My lights are bright and wash out the subtle shadows created by the preshading.  Ugh, in fact the shading on the turret is practically gone....guess I got carried away the the mistcoating!  Looks like I'll be doing some postshading tomorrow!
The tracks were sprayed with an enamel mix of MM Flat Black and MM Rust to achieve a milk chocolate color.
Ernest
    January 2007
Posted by the doog on Monday, August 13, 2007 10:18 PM
Looking very nice, bufflehead! The little extra details really put a shine on this build already!
    July 2006
Posted by bufflehead on Monday, August 13, 2007 10:41 PM
Thanks doog!  Everythings gone good so far, except I lost one of the turret hatches.  I think I washed it down the sink...so I'll be doing more scratchbuilding!Sigh [sigh]
Ernest
Posted by tigerman on Monday, August 13, 2007 11:19 PM
That's shaping up real nicely Ernest.
 Eric
    June 2006
Posted by ps1scw on Tuesday, August 14, 2007 6:20 PM
Other than swearing off coffee for a week and a steady hand, how do you paint the pioneer tools.  I always leave them off until after everything is painted.
    February 2007
Posted by roosterpelo on Tuesday, August 14, 2007 10:29 PM
i don't think you lost the preshading at all bufflehead. from my view on pic two, i can clearly see the preshading. you might have went overboard in your eyes, and no one can really tell as you are looking at your model in the flesh (plastic?) but its starting to come alive. waiting impatiently for weathering and the finished product.
chris d.
    July 2006
Posted by bufflehead on Wednesday, August 15, 2007 12:08 AM
By swearing off coffee for a week and strapping my hand to a vise! LOL!  Actually its not that hard.  The trick is to use a post it note and slip it under, over, between the tools and whatever you don't want to get paint on.  Then a lot of touch up painting!!Laugh [(-D]
Ernest
    October 2004
Posted by jthurston on Wednesday, August 15, 2007 7:26 AM
A post-it note! Here's me slappin my forehead. I've been looking for just such a technique.
    March 2005
Posted by alex2005 on Monday, August 27, 2007 5:21 AM
In the other thread (where Buffle dissed the Alan kit as not great,) I mentioned I actually like this kit (not perfect, but for about 20$ CDN, no complaints).  I was thinking of getting another one, to do better than last time, and Buffle's postings sure are a hard sell in that direstion!   Very nice model, looking good!
One 'beef'; according to my research, the Pzkw I Ausf c, as represented by this kit, is very limited to where it would have been used; in short, the tank would have been up armoured (and looking VERY different) just before Barbarossa.  So, 1939 to early '41, Poland, France, Norway, the Low Countries.  Even placing this vehicle in North Africa wouldn't be quite right.  Mine's going to the crossing of the Meuse by Rommel;s 7th Panzer, June 1940.
Hey!  A thought; I had a dickens of a time placing the decals onto the turret (they broke, it was quite trying, so I am marking the tank per some different methods I could find photo support for); how were the decals for you, Buffle?
    July 2006
Posted by bufflehead on Monday, August 27, 2007 1:13 PM
Hey alex!  I agree with you on the limited operational use of the Ausf C.  I'm not even sure these were used in Russia, but if its a Russian or African theatre Pz II you interested in, then I recommend Cyber Hobby's brand new Pz II Ausf F!!  Its awesome, with great details and even a full interior, but definitely more costly than Alan's kit.  I got mine for $40 (ouch!) but it was a promotional deal and came with some free PE sets!
I have to say Alan's decals suck major Censored [censored]!!  My turret decals also broke and I had to replace them with decals from Dragon's Pz I Ausf B kit.  Probably not accurate, but I've got no other decals that look appropriate.  The ones on the hull managed to stay together but I had to use the all-white crosses because the black&white crosses were misaligned.  I'm almost done with the decalling so I'll be posting photos in a few days.
Ernest
