This weekend's update is small, relatively speaking, due to the fact that it coincided with my 12th wedding anniversary and, while my wife is very understanding and supportive of the hobby, that only goes so far!
Due to poor weather yesterday I wasn't able to get any painting done until today. While I did get a head-start on the track assembly yesterday, the progress there isn't sufficient enough yet to justify any photos, so this update will be light on pics as well. All paints referenced on Testor's Model Master Enamels.
The day's efforts meant spending a lot of time with the airbrush out in the garage and the first step was to lay down a primer coat of Italian Dark Brown. This helps insure all the bare plastic areas are covered and provides a solid foundation for the base coat. Once that was on and dried, I applied the base coat using a personalized mix of 80/20 Dunkelgelb/Light Gray. This is applied in multiple very thin passes, slowly building it up over the Dark Brown so as to avoid a single heavy wet coat.
Once that was on and dried, I started in with the camo pattern. I used Khaki for the olivegrun stripes first to set the framework of the pattern then applied the red-brown alternating stripes using a 50/50 mix of Leather/Military Brown. I then went back over the pattern using the previous 80/20 dunkelgelb mix to correct over-spray and fine tune the pattern. The final step was to hold the airbrush about 1-2 feet away from the model and then spray a very light overall mist coat of the same dunkelgelb mix to tie everything in together. The gun is still not attached to the vehicle base to allow for the later detailing to be accomplished.
At the same time as all that was going on, I also airbrushed the road wheels. All of the wheels were mounted on wooden toothpicks using small blobs of blue-tack poster putty to keep them in place. The rubber rim portions were sprayed with Flat Black and then a circle template, with the correct diameter holes masked off, used to spray the dunkelgelb hubs.
During the week I'll likely keep plugging away at the tracks and, once they're done, install the road wheels and go from there.
