Normally I post updates on Sundays but since today was a day of working on the details and then the only thing left is the tracks, I figured I'd go ahead and post today.
The first area of attention were the road wheels, these were assembled from their separate halves and installed onto the vehicle and allowed to dry to provide a solid foundation. Next came the various tools and bits of equipment mounted on the hull. These were detailed individually, with the metal surfaces painted first with non-buffing metalizer Gunmetal and then lightly dry-brushed with Steel. Those with wood handles had them painted with my own custom mix of "wood" color followed by an application of burnt umber artist pastels. The handles on the wire cutters were painted with Italian Dark Brown to recreate the bakelite look since they aren't wood like the rest of the tools. The spare wheels were also installed and the exhausts base coated with the same metalizer Gunmetal and then given a light wash of Rust for their finish.
I also created some light scuffing/scratching in the fighting compartment area where the crew would stand to operate the gun by alternating dry-brushing and stippling of some Burnt Umber. This was then toned down and blended back in with dry-brushing and stippling of some Dunkelgelb. Last but not least, the spare barrels were painted with Gunmetal metalizer and very lightly dry-brushed with Steel and fitted into their clamps.
Next in the detail department was the gun itself. The barrel, ammo feed tray, and the ejector tray were given the same treatment as the spare barrels. The gun sight was detailed with Aircraft Interior Black and the spent shell basket installed. I used the three Tamiya kit-supplied ammo clips and painted up two with yellow heads for HE rounds and one with red heads for incendiary shrapnel. The brass casings were painted with non-buffing metalizer Brass and the fuse caps painted with Steel. The tabs on the ammo clips on the real thing are meant to hook into each other to feed the gun but the Tamiya parts don't allow for that, so only 1 clip was loaded into the gun and the other 2 were set on the ready tray.
I've already started in on 1 of the MK track runs, got about a dozen links assembled before deciding to call it a day. Tomorrow will be a "day of tracks"!
