As advertised in the last update, the tracks were the next step and this of course follows the usual pattern with MKs, using the provided jig and assembling the runs by installing the workable pins on either side.
While the MK instructions suggest 97 links per side, this is too short and I ended up using 99 links. Because I wasn't careful enough with the pins to insure they actually did seat all the way in, I had several weak pins resulting in the need to run liquid glue along the entire track run and treat it as if it were static indy links instead. I base painted the runs with Testors Model Master Non-buffing Gunmetal, then dry-brushed Steel to create a metallic look, and applied a thin wash of Raw Umber to finish the look before installation. I also used the spare MK links available for the front hull run and finished them in the same way except for using a wash of Rust in place of Raw Umber and dry brushing additional Burnt Umber for their finish.
With that out of the way, I applied a coat of Future by air brush and applied the decal markings. Instead of the Tamiya decals, I hunted in my spares bin and used some Cartograf markings left over from a previous DML build, the Tiger I Initial. Using the cover photo on Panzerwrecks 6 as an inspiration, I added a 3-digit vehicle number to go with the balkenkreuze. The decals were treated with Walther's Solvaset to snug them down to the hull and then a second sealing coat of Future applied. This was allowed to sit overnight before starting in on the weathering process.
The first step was the application of an overall wash of Raw Umber to all of the upper hull surfaces. I used a round 0 sable brush and worked carefully section by section, adjusting any excess as I went with clean thinner.
Then I applied a dot filter of Raw Sienna to add some earth tones to the weathering and some slight streaking for variation. This was followed by a pin wash of Burnt Umber to further pop out the details.
As a final step, I lightly dry-brushed the lightened Dunkelgelb mix used for the base coat to all the surfaces, blending and fading the camo in the process a bit more.
Next came a wet treatment of Mig Pigments Dark Mud, Europe Dust, and African Earth. The three were mixed together first as powders, then ordinary water added and the mixture applied by a large sable brush to the undersides and running gear. This was allowed to air dry over the course of about 1 hour to get to this stage. The pigments end up a slightly lighter color this way than if applied dry, which is why I mix several colors in together.
After it was dry, I proceeded to remove the excess pigment and adjust the finish. This is accomplished as a two-step process, the first is to use a set of stiff bristled brushes to remove as much of the excess as possible. I wear a dust mask while doing this as the very fine pigment particles go airborne very easily and aren't good for the nose/mouth/sinuses/lungs to be inhaled! Once all the excess is removed, the next step is to use a series of moistened q-tips to tone down and adjust the level of pigments.
Then, as a final step, I dry-brushed some Steel to bring back out the high-points on the track faces and everything was finished.
