I would welcome a tutorial on touchups as well! I don't know of anyone who does have a tutorial on this. It is something so basic and easy, yet frustrating at the same time! Just how much paint can I use on a burn-out? Will it polish out and almost disappear??
"That's Spenser with an "S", like the poet." Robert Urich Spenser For Hire 1985
Classic Plastic Model Club
Hi;
What I have found is this.If you can go to your lowest pressure and Then Just frost it with a mix of 80% clear and 20% color! Oops, Sorry Mike, that's for a real car and you are using Dupli-Color.
I used to brush on a very thin coat (decanted) around the Doors and such and then level the paint up to that. Burn throughs are a pain and hard to fix, maybe when you start to get a good sheen then Lighten up the pressure to almost being like dusting it off , that may help.
I think It looks amazing AND I love the color choice and work you've done so far!
After much preparation, I added another coat of paint to the hood only to have fogging and pin holes in the paint! I knew I should have washed the hood first! But, then I discovered a crack in the paint. Now, this is not on the edge where I have added some styrene to extend the hood, but inboard about 1/4 inch from the edge. Ihave decided to toss the hood into a tub with some Easy-Off Oven Cleaner, remove the paint and start all over again!
More Corvette to come...
Now that DOES suck!! Sorry bout dat Mike. Looking forward to the fix man.
Thanks Joe! I need to repair the crack and I don't know how deep it goes. If it is just in the paint, the crack should disappear. If it is on the hood, I will have to bodywork the hood.
Man, that sucks. I have a friend who paints cars for a living. He's one of the best I've ever seen. Totally show quality work always. He will repaint parts of cars several times before he is satisfied with it. The end result is stunning. You will get there, keep going.
BK
On the bench:
Tamiya 1/35 M4A3E8 "Fury" with crew,
1/32 Kittyhawk Kingfisher,
1/35 Meng Panther Ausf A Early,
1/48 Pro Modeller P-51C "Boise Bee"
2022 Completed:
1/25 Revell 29 Highboy
1/48 Tamiya Sea Harrier
1/25 Revell 70 Boss 429 Mustang
1/48 Hasegawa D3A1 Type 99 Val
Yeah, it does suck! Big time! But, I will fix it and get past it. I'm not trying to get a show-quality finish, just a good finish.
The hood has had the paint removed, been washed and now for it is ready for more bodywork! Oh joy! Have I ever mentioned that I hate bodywork? I do! The crack goes all the way through the hood and I am figuring a way to repair it. I also have to add a coating of filler over the top of the hood and sand it all smooth.
This is more like it! This is just a quick coat of Tamiya Fine Surface Grey Primer on the hood. Another coat of primer maybe and then several coats of Dupli-Color Forest Green Pearl!
Nice save Mike
Thanks,
John
Thanks John!
I have painted the hood this afternoon! Dupli-Color Forest Green Pearl! I let this gas out for a day or two and then start the polishing phase.
I noticed that my last painting sesson left some places on the hood undercolored. I added another coat or two to the hood. Then, the crack reappeared in the upper right hand corner of the hood. I am done chasing this crack around and will leave the paint as is and polish it. This was suppose to be a quick and simple build and then the cracks appeared on the hood. I'm just going to assemble the 'Vette and be done with it.
The Corvette is in the midst of Bare Metal Foil and final assembly before clearcoat.
I clearcoated my 'Vette with Tamiya TS-13 Gloss Clear. Maybe another coat and then some polishing.
Keep up the great job. Its looking good.
Thanks lurch!
I have finished my '68 Vette L89.
A few more...
Turned out great Mike. Fought you a bit, but in the end you pulled off a nice finish.
Thank you, John! I seem to have some trouble with painting hoods lately. I'm working on it!
Excellent Mike! Wouldn't expect anything else after all that hard work.
Jim
Stay Safe.
Main WIP:
On the Bench: 1/48 Tamiya - Vought F4U-1A Corsair for Group Build 'Absent Friends' 50% 1/48 Encore Models - A-37B/OA-37B Dragonfly 50%
fox Excellent Mike! Wouldn't expect anything else after all that hard work. Jim Stay Safe.
Thank you, Jim!
Great looking Vette. Love those C3's.
Oh MY!
Hey Mr.Mike ! It's gorgeous and especially cause it's Green! Love the work!
Great looking model. I love the green color.
Nice metalflake!
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list, we're down to a Monogram 1/72 SR-71 and that Tamiya P-38F/G to use the other nose art Exito Decal (in-flight for this one), & in keeping with MC's hydra theory I bought another F-5E to do in FROG camo! And I just got a Trumpeter 1/32 F/A-18F!
Thanks guys! I appreciate the comments!
TheMongoose Nice metalflake!
The color is actually a pearl/metallic, not a metalflake which is much larger.
