Greg
A question about MCW paints....
So I perused their website, noticed they offer both enamels and lacquers. I neither understand why, nor do I understand enough about paint to know the pros and cons of one vs the other.
Sure appreciate any and all insight.
i can offer my experience here as well Based on using MCW for the last couple years.
lacquer -
dries super fast. I can tape it, including burnishing edges down in as little as 15 minutes.
MCW & MRP spray right out of the bottle. I tend to use some mr color leveling thinner with MCW if ikm going for a gloss finish, or f the air is real dry and the paint is spider webbing on me even after adjusting the air pressure down a bit.
can be applied super thin
can be applied right over kit plastic with no primer
stinks like crazy. Use ventilation
dries to a gloss finish if you apply it with a "wet" look to it. decal right over this without any other product needed. Microsol beads on it so almost useless lol
my favorite primer is Citadel but have used tamiya fine, mcw, Duplicolor decanted with no issues.
Enamels -
Dry SLOW.
MCW enamel needs a thinner (i use hardware store lacquer thinner), and a hardener if you want to do anything in less than a day. 4hrs dry to touch and 8hrs dry and can tape it.
Superb gloss without using a clear. Show car gloss if you use their clear.
Applying it thin tends to take away the gloss.
I don't have enough experience with it to speak to not using a primer. I've used mr surfacer, mcw, citadel and duplicolor auto primer decanted from spray can all with good success. Have only used lacquer primers under my enamels whether it was mcw or Model Master.
this is Citadel primers with MCW Enamels for the vibrant colors and mcw lacquers for the dark blue(yep it's blue, just painted on a black primer fading to bone white primer from back to front).
edit-forgot to mention there was a noticeable increase in shine using the enamel gloss clear vs the lacquer gloss clear! In the end my final coat was the enamel clear over everything.
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
