Wooden ship modeling - I hope I'm not in over my head
    August 2004
Posted by cwalker3 on Saturday, September 16, 2023 11:28 AM
Starting to get bored with modeling so I decided to branch out a little and try out wooden ship modeling. I figure since I've been modeling for over 20 years and I used to be a woodworker, I thought this would be a good next step. So after doing some Googling I headed over to Model-Expo and picked up Model Shipways three kit beginners package.
The first one out of the gate is the Grand Banks Dory. This is in 1/24 scale. I run into a problem right at the start when I find out they sent me the instructions in Spanish. So while I wait for a new set to come in the mail, I'm working off of the instructions on their website. So far I've built the frames and now I'm finishing up gluing up the bottom to the frames. Waiting for glue to dry is boring as all get out but it's good to get my hands back into woodworking, even if it is just balsa wood. Here's where I am so far.
Cary
    March 2022
Posted by missileman2000 on Sunday, September 17, 2023 8:35 AM
What glue are you using?  On wood you can use oll fashioned model airplane glue.
    May 2023
Posted by Greysteele on Sunday, September 17, 2023 9:10 AM
Check out the nice folks over at Ships of Scale (https://shipsofscale.com/sosforums/). They are primarily wooden ship builders and a quick search turned up several threads about that same exact kit. Lots of good advice and techniques to be gleaned there. Good luck with your build!
"In polite society, we call our obsessions hobbies." – Stephen King
    August 2005
Posted by EdGrune on Sunday, September 17, 2023 9:16 AM
Check some of the wood working YouTubes/Instagrams and go to some of the wood shops, Rockler, Woodcraft, etc.
They will often use a often use a fast drying PVA wood glue such as TiteBond augmented with CA with an accelerator as a clamp until the glue dries
    August 2004
Posted by cwalker3 on Sunday, September 17, 2023 10:09 AM
missileman2000
You mean good ole tube glue?
Cary
    August 2004
Posted by cwalker3 on Sunday, September 17, 2023 10:11 AM
Greysteele
Thanks for the link. I'll check them out.
Cary
    August 2004
Posted by cwalker3 on Sunday, September 17, 2023 10:46 AM
EdGrune
Without Youtube I would indeed be lost.
Cary
    October 2019
Posted by Tanker-Builder on Sunday, September 17, 2023 11:06 AM
Hi Gary!
     Those kits are okay for sure. Mine allowed me to turn to Acrylic Sheet. Yup! I got sheet thin as I could, and built according to their plans and even R.Cd a few.
    I had a seemingly inexhaustibla supply of the stuff, cause when I did my Last Court Use Commission, it had to be large ,R.C.d and to get the materials sized right I had to buy in bulk!
     I built the Wood ones later and they were a blast!
    October 2003
Posted by sharkbait on Sunday, September 17, 2023 1:11 PM
Re "Ships of Scale" https://shipsofscale.com/sosforums/
Great site...there's my afternoon shot to hell as I explore it.
You have never been lost until you've been lost at Mach 3!
    March 2022
Posted by missileman2000 on Monday, September 18, 2023 7:34 AM
cwalker3
missileman2000
Yep.I think that Lepage is still available forget, forget which others.
    September 2012
Posted by GMorrison on Monday, September 18, 2023 11:33 AM
Welcome aboard. You are taking the right approach, working on larger scale models. Interested to hear what the other kits are that you have on the list. The skipjack is a nice kit.
I like solid hull kits as the level of difficulty of assembly is a lot less than p-o-b.
I'm a little confused by the glue discussion and not sure if Don was clear. I don't think he meant model airplane glue for styrene models. Don does build wooden model airplanes too, I think he might have meant a glue like Ambroid.
I use CA a lot. If you'll be painting the wood it works well' but if you are planning on a clear stain it can be too visible.
Tip on the wood- your kit it made of basswood. It's a hardwood such as linden, with little to no discernable grain. It's easy to get from either online sources, or many hardware stores. I've even found it at CVS. Quality varies of course.
Balsa, which you aren't using, is to be avoided. It cuts, sands and paints poorly.
I look foward to progress of the dory.Mmmm, fish n' chips!
Bill
    August 2004
Posted by cwalker3 on Monday, September 18, 2023 4:58 PM
GMorrison
Bill
That makes sense about the glue. I was thinking Testors red tube, but I also know of Ambroid so thanks for clearing that up.
As far as what's next, I bought a three kit set that takes you step by step from the easiest boat to the hardest so that you learn as you go. Besides the dory, the other two kits are a sailing pram and a lobster smack. All three by Model Shipways.
Cary
    September 2012
Posted by GMorrison on Monday, September 18, 2023 5:54 PM
Oh I saw that on Model Expo. Good choices!
Bill
    March 2022
Posted by missileman2000 on Tuesday, September 19, 2023 8:16 AM
GMorrison
Bill
Yes, those models are, in my opinion, far better than the European kits
