The Mission Carmel is back on the ways. I've given up the idea of a parallel build, so the second kit will get salted away for now.
Here's the hull as modified so far, and the original part in the background.
Added the fillets at the forward, midship and stern structures. I think this really is the single most important mod and makes it look right.
Cut down to laden freeboard, around 12 feet,
Cleared off the "half capstans" the cast railings, and the boat deck structure.
Cleared off an "impressive" part of the kit, which is the vent pipe system that was cast into the deck piece and ran from the access hatches to a central collector main. On the ship, this was a fairly small diameter pipe, but on the kit is a big pipe with unions , flanges etc, While it looked "busy" it made no sense, Fred correct me if I'm wrong.
It's removal can be seen by the white areas, and I'll replace the lines with thin wire.
I will build up the distribution system piping that runs fore/aft and end it in the pump room trunk structures. More on that later.
Glued a piece of stretched sprue up the sternpost, filled and sanded it in to get the correct pointed profile.
