1/350 USS Carl Vinson Project.
    April 2015
Posted by Wolfman_63 on Thursday, June 15, 2017 9:01 PM
I had some time tonight to start detailing the hangar bay walls. I started with the small wall between bay 2 and 3. Below are the pictures. How is it looking so far?
(NOTE: I have not painted the fire doors, just put logo on it to see how it looks)
Website:
David's Scale Models - https://www.davidsscalemodels.com
    April 2015
Posted by Wolfman_63 on Saturday, June 24, 2017 5:02 AM
Kind of a slow week as I was busy with some other things this week. I was able to get the starboard walls and doorways mounted and detailed. The aft walls are detailed but still need to be mounted. Will be starting to paint and decal the long port walls and to detail the GSE bay tonight.
Website:
    April 2015
Posted by Wolfman_63 on Friday, June 30, 2017 4:54 AM
The hangar bay deck is finished. All walls mounted, deck markings and painting done, weathered/stained deck, and GSE area lighting done. I even added toolboxes and benches to the back wall of the GSE area. Here are numerous pictures. Will be starting the flight deck next. (Hangar bays to be filled with aircraft and GSE equipment later)
Close up of GSE area with toolboxes and benches.
Website:
    April 2015
Posted by Wolfman_63 on Monday, July 3, 2017 3:03 PM
CVN-70 Project - After 5 attempts I finally figured out how to do the landing light "meatball" It's difficult to get a good picture due to the brightness but it does look cool.
Website:
    July 2017
Posted by Woogey on Tuesday, July 4, 2017 12:44 PM
Good day Wolfman,
Happy Independence day!  I am glad I stumbled across your build as I am doing the same exact version of the Carl Vinson. My Nimitz model is scheduled to arrive tomorrow.  I will be using the hangar bay details released just last week on Shapeways.  I am Very interested in your decal set graphics.  Are you planning to do a CVW-15 airwing set?  I have searched hi and low, but no one seems to do this wing yet?  Your build is looking great!
-Woog
    April 2015
Posted by Wolfman_63 on Wednesday, July 5, 2017 3:46 PM
Thanks! I just sent you the Hangar bay decal sheet picture.
As for air wing from 1983, Starfighter decals has VAQ-134's decals but all others are not available.
However, when I get to the aircraft I will be making my own sheets for each squadron.
I already built a plane from each squadron in 1/48 scale (see http://cs.finescale.com/fsm/modeling_subjects/f/2/t/165305.aspx ) so getting pictures will be easy. Just need to scale them from 1/48 to 1/350.
Website:
    April 2015
Posted by Wolfman_63 on Sunday, July 9, 2017 11:28 AM
CVN-70 Project - After I cut off all the catwalks (have PE version) I put flight deck together and made sure it fit the hull. I then started the long process of drilling and routing the fiber optic deck lights. I have the rear approach line done and am working on the foul line. The approach line will use a white LED and the foul line will use a blue LED. I drilled the holes at an angle so the optic lines will lay flat. I also mount them sticking up. Once the deck is painted and detailed I will trim the optic lines flush. They will be nearly invisible until the lights are on. Once all the lines are installed I will make them look like overhead pipes then prime and paint. The hangar bay LED's will be mounted after painting. I will need to do the island before I install deck to hull so I can run the wires for the island lights.
Website:
    April 2015
Posted by Wolfman_63 on Thursday, July 13, 2017 8:24 PM
CVN-70 Project - I finished the runway optic lines and halfway done with the foul line. Have about 28 more lines to run. I have quite the bundle. It's going to be a while to get them lines up and laying flat.
Here is a preview of the lights (just used a table lamp to see how the pattern looks)
Website:
    April 2015
Posted by Wolfman_63 on Friday, July 21, 2017 5:57 PM
CVN-70 Project - All the fiber optic lines have been laid out. Starting to glue them down so I can route them. It's slow going. Have to do it in sections.
Website:
    December 2006
Posted by Fly-n-hi on Friday, July 21, 2017 7:04 PM
Wow! Gonna keep an eye on this!
    April 2015
Posted by Wolfman_63 on Wednesday, July 26, 2017 4:15 PM
So the runway and foul line optics have been laid and glued. Looks like I can light them with just 5 LED's. Runway in white and foul line in blue. Tonight I will run the bow lights then I need to route all the fiber optic lines so they are flat and aligned evenly. Hoping to have pictures of the deck lit up with LED's by weekend.
Website:
    April 2015
Posted by Wolfman_63 on Friday, July 28, 2017 4:51 AM
CVN-70 Project - All the fiber optic lines have been run and the LED's have been installed as the source. The pictures are the result. Note that I have not trimmed the fibers down yet since I need to paint and weather the deck before I can trim them flush. They do look very bright in the photo's due to the way the camera sees the light. Once trimmed the brightness will not be as bright.
Coming in for a landing view:
Website:
    April 2015
Posted by Wolfman_63 on Sunday, July 30, 2017 6:41 PM
CVN-70 Project - Spent the day setting up the hangar bay lighting. I just taped everything to see if I had the placement right. Here is a trial fit test.
Website:
    April 2015
Posted by Wolfman_63 on Tuesday, August 8, 2017 4:27 PM
CVN-70 Project - The flight deck has been painted and fiber optic lines trimmed flush. Still need to add decals and weathering.
Website:
    December 2003
Posted by scottrc on Sunday, August 13, 2017 11:05 AM
The hanger deck pics are very impressive.
    April 2015
Posted by Wolfman_63 on Saturday, August 19, 2017 2:52 PM
Been a busy two weeks with taking care of other things so model time has been limited. I was able to get the hangar bay GSE tractors, Captains boat, and liberty launch together. Just need to do a little bit more detailing and decals. Next week I will be starting on the island.
20882996_10209951993223904_7144196802916
20882608_10209951993383908_4799882848738
20915416_10209951993103901_8081964508410
20842217_10209951993143902_1476601799027
Website:
    April 2015
Posted by Wolfman_63 on Sunday, August 20, 2017 8:15 PM
CVN-70 Project - Starting on the island Drilling lots of holes to light up the numbers and adding LED's for the island rooms. The lighted 70 looks funky because the fibers still need trimming after I paint the walls. Over 50' of fiber optic just to light the numbers on one side of the island. Working on the other side next.
Website:
    April 2015
Posted by Wolfman_63 on Friday, August 25, 2017 4:32 AM
This week I started working on the island. I ran all the fiber optic lines to light up the ship numbers and the yellow flood lights that light up the flight deck. Surprisingly I was able to get the lines routed with room to spare. I also modified the level for the Mk 95 NSSM director bays and added the LED light.
Website:
    April 2015
Posted by Wolfman_63 on Sunday, August 27, 2017 4:43 AM
The lower section of the island is now done. I trimmed the fiber optics and applied the decals.
Website:
    April 2015
Posted by Wolfman_63 on Monday, August 28, 2017 8:33 PM
The upper levels of the island are together. Need to start building the 19 aircraft that will be placed in the hangar bay so I can assemble and wire up the ship.
Website:
    April 2015
Posted by Wolfman_63 on Wednesday, August 30, 2017 4:21 AM
Here is the first proof sheet of the decals for the aircraft. I will be doing all 86 aircraft that was aboard when the ship pulled out of Norfolk Virginia in March of 1983. Still need to do the decals for the A-6's as well as all the numbers for all the aircraft.
Website:
    July 2017
Posted by Woogey on Wednesday, August 30, 2017 4:06 PM
Wolfman_63
Oh my God! Those decals, I got to have them!   Would you possibly consider contacting  Starfighter decals to see if they would  do a production run?  I also had question about the low-vis aircraft that had started to infiltrate their way in by the time of this cruise.   Did you plan to do any of those, or just stick with the continuity that you have shown us here?   I know both of the F-14 squadrons had some Low-vis as well as the prowlers, and a couple of the corsairs I think?
Sincerely, Preston
    April 2015
Posted by Wolfman_63 on Wednesday, August 30, 2017 5:09 PM
Actually when we pulled out of port they were all the hi-vis scheme. About halfway thru the cruise they started painting them lo-vis. When we pulled into San Francisco half of the planes were hi and half were lo-vis. I can email you a high resolution proof and you can print your own. Never thought of contacting a company to buy my designs.
Website:
    July 2017
Posted by Woogey on Wednesday, August 30, 2017 5:17 PM
I actually have been hoping these guys would put together a CVW-15 airwing set for a long time.  They have some good stuff.  http://www.starfighter-decals.com/1350-de.html
-Preston
    April 2015
Posted by Wolfman_63 on Wednesday, August 30, 2017 6:37 PM
I know. I bought the VAQ-134 and deck tractor decals from them for this project.
Website:
    April 2015
Posted by Wolfman_63 on Thursday, August 31, 2017 4:22 AM
 Here is the rest of the decals. The A-6 squadron and the various numbers and letters for the aircraft. Starting to build aircraft tomorrow.
Website:
    January 2009
Posted by F-8fanatic on Friday, September 1, 2017 12:03 PM
This all might very well be the coolest thing I've ever seen in modeling....I'm VERY impressed....that hangar bay lighting looks quite realistic.
    April 2015
Posted by Wolfman_63 on Saturday, September 2, 2017 4:07 AM
F-8fanatic
Thanks! Yes the hangar bay does. Not a lot of folks have seen a carrier hangar bay at night while at sea.
Website:
    April 2015
Posted by Wolfman_63 on Sunday, September 3, 2017 4:09 AM
Started building and detailing the aircraft for the hangar bay. Adding the photoetched parts on a 1:350 aircraft takes some time. Planning on 28 aircraft staged on the hangar deck. So far eight of the A-7's are built. Plan is to build all, then paint all, and finally decal all.
Website:
    July 2013
Posted by steve5 on Sunday, September 3, 2017 4:18 AM
man that's a project on it's own , nice work so far too .
