Ditto. It helps if you use a pair of tweezers to dip it slowly into the Future so as not to make bubbles form on the piece. Remove slowly also. Touch an edge of the piece to the paper towel to drain off any excess before setting down on the towel. Best to let it set at least overnight to cure before handling again. If any bubbles dry on the piece, no problem, just dip in some windex to remove the Future and repeat dipping in Future.
It might take a few tries to get it right, but the result is worth the effort. Let us know how you make out.
Stay safe.
Jim
