Matching AIM-9M anodizing
    February 2021
Posted by MJY65 on Tuesday, August 17, 2021 1:35 PM
Has anyone found a stock color or successfully home brewed a good match for the gray-green anodizing on AIM-9M Sidewinder guidance sections?
The closest I've come is a mix of Tamiya XF-51 Khaki, XF-77 Gray and X-31 Titanium Gold.  Close in color, but a bit too glittery.
Any good tips?
Thanks,
    May 2009
Posted by Pawel on Tuesday, August 17, 2021 2:55 PM
Hello Mike!
I don't know the exact colour you're talking about - a photo would really help here - but I think you're on the right track trying to mix colours with some metallic. Maybe try replacing gold with a mixture of yellow and silver - that should help reduce the amount of alluminium dust in your paint and do the trick.
Good luck with your projects and have a nice day
Paweł
www.vietnam.net.pl
    February 2021
Posted by MJY65 on Tuesday, August 17, 2021 3:02 PM
You can see that the guidance fins are a truer gray than the body to which they are attached.
    November 2008
Posted by plasticjunkie on Thursday, August 19, 2021 8:08 AM
It looks like a metallic dark grey green so I mix dark grey, dark green and a tiny dot of silver and I adjust till it looks right.
 GIFMaker.org_jy_Ayj_O
    August 2005
Posted by EdGrune on Thursday, August 19, 2021 8:54 AM
Have a look at Reaper MSP Paints #9157  Olive Shadow.   Its part of their Triad System, base color, highlight, and shadow.   It is a dark dark olive.   Perhaps you could add a touch of dark silver, enough for metalic look but not enough to sparkle
    February 2021
Posted by MJY65 on Thursday, August 19, 2021 9:24 AM
EdGrune
It looks like 9157 has been discontinued by the manufacturer.  Your point about the sparkle is the crux of the issue.  The grain size in most metallic paints is just too large and makes the paint look like a 1970s bass boat.
    November 2008
Posted by plasticjunkie on Thursday, August 19, 2021 9:33 AM
No sparkle in my mix. After it's dry I use a dry Q tip to gently polish the grey green to get a satin finish.
    February 2021
Posted by MJY65 on Thursday, August 19, 2021 9:36 AM
plasticjunkie
Which brand of silver are you using?  I know some are finer than others.
    November 2008
Posted by plasticjunkie on Thursday, August 19, 2021 9:39 AM
MJY65
plasticjunkie
Thinned Testors silver, just a small dot. The polishing with the Q tip gives a nice finish.
    April 2020
Posted by Eaglecash867 on Thursday, August 19, 2021 10:59 AM
I have been using Alclad 111 Magnesium for the guidance section and fins.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    November 2008
Posted by plasticjunkie on Thursday, August 19, 2021 11:08 AM
Eaglecash867
I have 26 Alclad bottles except 111! I wanted to compare but do have a bottle of Model Master Dark Anodonic Grey buffing metalizar that looks close to the front missile color.
    April 2020
Posted by Eaglecash867 on Thursday, August 19, 2021 1:07 PM
Here's a decent pic of the ALC111 on the guidance section of the AIM-9L on my F-14A.
