Micro Gloss Airbrush Cleaner?
    July 2004
Posted by stikpusher on Wednesday, December 7, 2022 8:57 PM
For any users of Micro Gloss/Micro Flat, what do you use to clean your airbrush afterwards? They recommend dunking the airbrush in 3” of a water/detergent solution in a container and spraying that through the AB. Does anybody here use some off the shelf stuff to clean their airbrush afterwards? Windex, Simple Green, Lacquer Thinner, Isopropyl Alcohol, or some other stuff?
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    April 2020
Posted by Eaglecash867 on Thursday, December 8, 2022 6:13 AM
Never used the stuff myself, but since it cleans up with soap and water, I would think that Windex would work well for cleaning the airbrush.  Its what I use for any other water-based acrylic product that I run through mine.  Lacquer thinner or alcohol would probably gum things up.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    July 2004
Posted by stikpusher on Thursday, December 8, 2022 10:08 AM
I tried using it a few times back in the 90's, and was quite happy with the results, at least with Micro Gloss. But I don't remember what I used back then to clean my airbrush afterwards.
       - Plankton
LSM
    March 2013
Posted by patrick206 on Thursday, December 8, 2022 3:45 PM
Hi, Stik -
Alcohol will work fine, lacquer thinner or acetone and denatured alcohol, all of them will get it done. Like any other product, just avoid letting it set for any long period or it can be a bit more difficult to remove it. In that case I would use MEK.
I have to disagree with soaking the airbrush body in anything, unless the air valve is removed.
Patrick
    January 2010
Posted by rob44 on Thursday, December 8, 2022 9:01 PM
I use car window washing fluid diluted with distilled water and a bit of isopropyl alcohol. I then wash that out with Acrylic thinner.
If things are really gunked up I have soaked the dissasembled AB in Windex for a while and put it in an ultrasonic cleaner. Windex has ammonia in it which can damage the AB, so be sure to rinse it thoughly with thinner or distilled water.
    July 2004
Posted by stikpusher on Thursday, December 8, 2022 11:40 PM
I tried a few different fluids- Windex, then Aztex airbrush cleaner, and finally some distilled water to make sure anything that could ruin the next paint used through this airbrush would not. I'm not sure which one did the trick, but it worked great afterwards.
       - Plankton
LSM
