Spray Booth
    March 2011
Spray Booth
Posted by PWright on Wednesday, November 9, 2011 9:30 AM
I want to make my own spray booth.  I was at Home Depot and saw a charcoal duct non filtered range hood.  Would this work for enamels?  I work in the basement and have no way of ducting.
    October 2003
Posted by ModelNerd on Wednesday, November 9, 2011 9:43 AM
Wouldn't do it. First, those hardware store fans aren't rated to remove volatile fumes (ka-boom!). Second, the filter will weep vapors eventually, once it becomes saturated. Ducting is really the way to go.
- Mark
    January 2009
Posted by fermis on Wednesday, November 9, 2011 7:07 PM
I built my own a while back and used a bathroom vent fan for the exhaust. I also work in the basement. I cut out a 4" hole just above the block (basement wall), and under the subfloor, and used a dryer vent with some screen to keep bugs and little critters out.
Is your washer and dryer also in the basement? If so, you could make a section of the dryer hose seperable, to attach the booth vent when you paint.
Posted by Don Stauffer on Thursday, November 10, 2011 8:50 AM
There should be a rating on the airflow.  I have found through building several homemade booths that the fan needs to be at least 100 cfm to do a decent job.  And even that requires a free flowing filter (I use furnace filters).
Is there a window in the basement you could build a terminal for a duct in?  I use clothes dryer hose for a duct.
    June 2009
Posted by Electric Blues on Thursday, November 10, 2011 10:03 AM
Made mine out of cardboard and shipping tape. Installed the largest computer fan I could find. I use a dryer duct to shoot the exhaust out my window and into a filter.
    January 2009
Posted by Griffin on Thursday, November 10, 2011 1:05 PM
For safety's sake you should use an "explosion-proof" fan.
    April 2004
Posted by rudedog72 on Thursday, November 10, 2011 1:50 PM
I whole heartedly agree with the assessments of the others.  Find a way to duct out the fumes.
I built my own spray booth out of an old computer table, some pieces of 1/4 inch "chipboard?", a 20 inch florescent light, and a 6-in, inline duct fan like this one:
http://www.suncourt.com/Inductor_Pro.html
I wired all of that together with a plain old junction box, a power tool replacement 3-prong cord, a light switch, and hooked a long dryer vent hose out the back.  I lived in a condo at the time and I had to crack a sliding door and run the hose out onto the patio so I didn’t gas myself, the wife, or the dogs out of the place.  I know everyone says you should also use a fan that won't spark on you but I have never had an issue with the one I chose.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former."
- Albert Einstein (1879-1955)
    January 2009
Posted by Griffin on Thursday, November 10, 2011 2:09 PM
No one ever has a problem, until they do!
    June 2009
Posted by kermit on Thursday, November 10, 2011 2:42 PM
Guess im going to be the odd one out...
My spraybooth consists of a large xl size cardboard box with the lid taped inside as a back board. It keeps the overspray where i want it: inside the booth.
My ducting/ venting consists of the window above it. Whenever i spray i open the window to let fumes out. Whenever i am done spraying enamels (not too much anymore as i am using acrylics most of the time) i just let the fumes evaporate through the window and go outside of the room for a little bit and have a coffee.
Poor mans solution but it works for me. Just needs patience...
Richard
"Success is the ability to go from one failure to another with no loss of enthusiasm." - Sir Winston Churchill
    August 2011
Posted by GreenThumb on Thursday, November 10, 2011 3:11 PM
Griffin
While that would be ideal a real "explosion-proof" fan is out of the price range of most of us.
Any good squirrel cage blower fan with the motor outside the airflow is perfectly safe as long as it is used properly. None of the commercial made spray booths I have seen use true "explosion-proof" fans.
    January 2009
Posted by Griffin on Thursday, November 10, 2011 3:38 PM
Sounds more or less like mine.
GreenThumb - I totally hear what you're saying. I was just stating a 'best-case-scenario' I guess.
    August 2011
Posted by GreenThumb on Thursday, November 10, 2011 9:17 PM
Griffin
Nothing wrong with being cautious my friend. Wink
    February 2007
Posted by mitsdude on Friday, November 11, 2011 1:29 AM
Reality check: if you value your lungs  there is no way you can use just a filter with enamels, you MUST use some type of exhaust system.
I use this exhaust fan. Its basicly a squirrel cage,  917CFM.
Take off the bag and attach dryer duct (to the outside). That black connection on the side sucks air from you spray booth. Both connections are 4in diameter, the same as dryer duct. You can see the motor is on the outside and never comes in contact with the fumes. This will handle a rattle can full blast.   I also removed the stand.
Central Machinery 94029 1 HP Mini Dust Collector
For a squirrel cage fans/blowers, also called shaded pole, check Grainger. I'm not sure if you have to be a business to buy from them. Some people say yes others say no.
Shaded Pole Blower,115 Volt
Also do an Internet search for places that sell hydroponic equipment. Look for exhaust fans/blowers. Generally much cheaper than Grainger.
    October 2011
Posted by kptom on Saturday, November 12, 2011 2:44 PM
Perhaps a cost effective alternate would be to use a bilge blower fan found on most boats with an I/O motor. They are used to evacuate the bilge of gasoline vapors prior to starting up the boat. Just an idea....
Posted by Don Stauffer on Sunday, November 13, 2011 11:15 AM
The flat plastic fans used in computers and stuff, called muffin fans, are brushless, and should be pretty explosion proof.  They come in a wide range of flow rates, though, so you must check the CFM.  I am using one of those in my homemade booth- it is 120 cfm.
fox
    January 2007
Posted by fox on Sunday, November 13, 2011 12:44 PM
I built my own booth out of a salvaged overhead kitchen cabinet with a heater filter in front of the Grainger exhaust fan. Didn't have to be a business to get the fan and it has worked great. When in use, I have a board with the outlet duct of the fan placed in the window frame and close the window to hold it in place. It only gets a little chilly in the winter  for a minute when I open the window to put the board in place. Fan is VERY quiet. Total cost of the booth was around $100. Cabinet was free. Switch was an extra that was laying around in the workshop. Light is a fold-up that is swapped back and forth from the workbench. My wife even rigged up a sheer curtain in the front of the cabinet so that I could keep the fan on for a while when done painting to aid in drying without dust getting on the model.
Jim Captain
 Main WIP:
    January 2003
Posted by TomZ2 on Sunday, November 13, 2011 12:56 PM
I use a ModelExpo’s Compact Spray Booth (HSE420 - actually the Compact Spray Booth, Exhaust Hose, & Filter Combo #HSE420PRO). What I like is the way this beast folds-up into a 16-1/2" × 6" × 9-1/2" box (the spray area is 16" wide × 13" high × 14" deep). Available @ http://www.modelexpo-online.com/
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    November 2011
Posted by jcbreslin on Monday, November 14, 2011 11:21 AM
Here's mine. It's made with 1/2 foam core boards, (Which makes it very light Wink ) doubled up for stability. It's 20" wide and 12" deep. I used a 4" computer fan which, if I remember, is rated at 120 cfm, and a dryer duct to go out the window. I think I got the fan for about $12. It works pretty well. I may add a second fan one day just to increase the outflow. I think the total cost was around $60, with most of the cost coming from the foam core at $4.50 a sheet. It's held together with liquid nails to seal it and drywall screws for strength. That is a clear piece of plastic at the top to let more light in. I got that from an old cheap poster frame I had lying around. I use an A/C filter from Home Depot at the back.
[View:/themes/fsm/utility/booth:550:0]
    August 2011
Posted by GreenThumb on Monday, November 14, 2011 3:06 PM
No offense jcbreslin but a 4" computer fan is woefully underpowered for a spray booth.
    November 2011
Posted by jcbreslin on Monday, November 14, 2011 4:28 PM
None taken. Cool
I went back to check specs. It's a 4.72" with a 133 cfm rating.
It hasn't actually been too bad. I knew it would be on the low end for power, but since I'm using mainly acrylics it gets the job done. The fact that my duct hose is about a foot long probably helps. But like i said, another fan is probably in the future. Wink
    August 2011
Posted by GreenThumb on Monday, November 14, 2011 6:18 PM
jcbreslin
Those numbers have to be inflated. My Badger spray booth has a squirrel cage fan that is fairly powerful and it's only rated at 165 cfm.
    November 2011
Posted by jcbreslin on Monday, November 14, 2011 6:34 PM
Hmm, I'm not sure, but maybe. Here's a pic of the fan I bought. The package lists it as 133.60 cfm.
Here is a link for newegg.com, they list specs as the same too. http://www.newegg.com/Product/Product.aspx?Item=N82E16835185054
Either way, it serves it's purpose. Like I said, I may get a second eventually.
    August 2011
Posted by GreenThumb on Monday, November 14, 2011 7:50 PM
I think they are probably rated in a different manner. Where is Gip when you need him?
He knows all about this subject. Wink
    July 2007
Posted by troublemaker66 on Monday, November 14, 2011 8:47 PM
I made mine from an old desk and Lexan battery shields..2` x 2` clear squares, and use a bathroom "fart sucker" for an exhaust, 3 " flex hose. Works great...hardly have any dain bramage..Big Smile
Len Pytlewski
Posted by Don Stauffer on Tuesday, November 15, 2011 9:18 AM
GreenThumb
Those muffin fans come in a wide variety of flow rates.  You need over 100 cfm, but the more powerful ones are in this range. The one I use is 120 cfm, and works fine.  I use a furnace filter, which does not have too bad a pressure drop.
    August 2011
Posted by GreenThumb on Wednesday, November 16, 2011 4:17 PM
I have two of these lying around that would make a great fan for a window type application.
This is a Comair 10" fan.
    July 2009
Posted by Back to the bench on Thursday, November 24, 2011 11:27 AM
Lots of useful info at this site...
http://www.briansmodelcars.com/tutorials/tutorial/23
Gil
    April 2011
Posted by Italian Starfighter on Thursday, November 24, 2011 2:57 PM
.....Take a look....................Ciao Enrico.
http://custom.ultramini.net/cabina-aspirazione-laerografo/
http://img.photobucket.com/albums/v381/tigerman12/ThatsAmoreGBBadge.jpg
    July 2007
Posted by troublemaker66 on Thursday, November 24, 2011 3:05 PM
Italian Starfighter
Ha! I have a multitude of those storage bins at home and never thought to use one as a paint booth..lol.  What a good idea...Yes
Len
Len Pytlewski
