Not a bad start! I don't share it around much, but in my past modeling life, I didn't really get that thinner was for "thinning" paint. Wouldn't spray through the airbrush? Kept clogging up the works? MORE PRESSURE! Yeah.
These days, complete 180. I've come to appreciate that thinner is better and that a light touch is absolutely crucial when airbrushing, especially any kind of shading (though post-shading still scares the pants offa me).
With that in mind, a few things to consider:
- Thin your paint more. 3:1 paint to thinner isn't going to get you very far. For pre-shading you want at least 1:1, but if you're going after fine lines to follow the panels, 2:1 or even further is probably the better bet.
- Try Tamiya's lacquer thinner. Even if you're totally against it, it's not going to kill you if you're spraying tiny lines at low pressure. I've found it gives me a significantly improved degree of control and much prefer the way the paint performs with it versus X-20A, especially for fine work like this.
- 1-2" is way too far for line-trace work. When I do mine, I get in so close I'm worried the needled might scrape the surface (one thing I love about the H&S Infinity is the ring guard thing that prevents that). Light touch on the tigger, too. I'm often balancing that tripping point between no paint/paint flow.
- Someone mentioned motion. Always. A still airbrush is a pooling or spidering waiting to happen. Keep moving. In the case of panel lines, I go back and forth, up and down, sometimes run panels like Pac-Man. If your paint's thinned enough, a slip-up isn't going to kill you, since you'll be at maybe 50% opacity, and need more than one pass to really darken the line.
- Vallejo. Model Color can be made to airbrush extremely well with Future, Testors Acrylic Thinner, or Windex. I've never been able to get it or Model Air to do the ultra-thin lines Tamiya pulls off with ease, however.
- The real key to preshading is what you do on top of it. I know modelers who "pre-shade" by painting the entire thing black. Heck, I do it with armor. And I've been experimenting with different streaking shading and such, busting out different colors to add depth and nuance. Saw over on Flory Models I think some brilliant pre-shading work on a sprayed hinomaru that involved white, yellow, orange and pink. Thin enough red on top, and those things peek through.
