SureThing decal maker- anyone have some tips?
Posted by autocar1953 on Wednesday, March 26, 2014 2:26 PM
What I have is Word 2007.
Do you have any info on the other problem? What I am working on is one of the triangular signs that say "DecalGear Racing" I can re configure the sign to what I want. I can resize and reproduce all I want onto a sheet. I also have some lettering and things I made on the freeform blank sheet. How do I get them on the same sheet? I tried copying , but it won't let me do that..
500 started, none finished....
James
    January 2013
Posted by cadillac on Wednesday, March 26, 2014 5:56 PM
I tried looking for "Word 2007" Icons. I'm still looking. I'd like to find them as individual Images.
I haven't had any luck yet.
 Everything should be transferable from one SureThing page(?) to any other.
I just moved a Decal Gear.com Racing to a Side Panel page.
Try this... Go back to the Decal Gear.com Racing... Click your Left Mouse Button to make sure your in "Object Mode". If your not... put it in now.
Once it's done and making sure your Cursor isn't touching any part of the decal... press and hold the left Mouse Button. While your doing that... drag your mouse over and past the entire Decal. Once you've done that... release the left Mouse Button. There should be Red Borders around the inner and outer parts of said Decal. Using your Mouse... place your Cursor in the CENTER of the Decal and Right click your Mouse Button. The Menu will pop up and read "Text Mode" at the top, "Cut Objects" under that and "Copy Objects". If you didn't have all of the Decal Parts in Red Borders... it'll only Copy the ones that are. It's a 3 part Decal. If you only had one part of the Decal or a one piece Decal the "Menu" would read "Copy Object" as the third choice.
I'm using a Violet, Triangle "Decal Gear.com Racing" which consists of 3 parts. I can now "Copy Objects".
With that done... I can "Minimize" that Page and Open any one I want. It doesn't matter which one you choose. I'm just going to open a "Side Panel Decal" page.
Once open... Right click your Mouse on the Newly Opened Page. The Menu should pop up again. Now the 3rd option should read "Paste Objects".  Left Click on that and VOILA!
You already know how to move it to where you want so, you should be set.
If you decide to change the "Decal Gear.com" in the Center... That's pretty straight forward too.
 You wouldn't believe what I went through making the Taxi License for the "Conspiracy Theory" Model. I used a picture of Mel Gibson instead of what was used in the movie. I was seeing double by the time I was finished.
 Please keep me posted,
                          Mark.
Insanity, It's not just for the insane, it's fun too.
