M270A1 MLRS Maintenance - Done!
Posted by HeavyArty on Thursday, September 24, 2020 8:15 PM
My latest build is of a US Army M270A1 MLRS launcher undergoing maintenance.
I am starting with the excellent Trumpeter 1/35 US M270/A1 model (01049).
I will be building it with the cab tilted forward showing the engine, transmission, fan, radiator, etc.  I will be adding the engine, transmission, radiator fan, and other engine compartment parts from the Meng M2A3/M3A3 Bradley interior sets.  It will look something like this.
So far, I have started by cutting the floor of the cab out of the larger plate that also makes up the forward parts of the fenders that go over the tracks.  I carefully cut the floor plate out and then cut away the rear section behind the notches where the rear wall connects.  The area with red "X"s below can be discarded.  Next, I cut the rear and side walls of the cab off below the raised line with bolts.  I discarded the cut off part.
I also boxed in the back of the cab that is below the bolt line.  There is about a 1/4 inch of the back wall exposed that has to be covered up.
Next I prepared the hull and rear engine cover.  I added torsion bars to the hull and the Meng final drives.  I also added a boxed in fan below the air intake vent.
Here are the Meng engine and transmission.  I had already taped up the transmission for painting.  Surprisingly, it only took a little bit of trimming to get the Meng engine and transmission parts to fit in the Trumpeter hull.
Here are a few of the other parts.  There is the Meng radiator fan, a hydraulic reservoir, the air cleaner box (made from an M60 side-loading air cleaner), and the removed shift console.
I am currently painting all the parts up and will install the engine/tranny and all the other parts soon.  More pics later.
    September 2018
Posted by Sergeant on Thursday, September 24, 2020 10:43 PM
I will be following your progress on this build Gino. The cool thing about these Forum builds is they are like virtual workshops for modelers, where we get to see how and why things are done the way they are by other members.
Harold
Posted by Gamera on Friday, September 25, 2020 7:36 AM
Oh cool, thanks Gino- neat 'under the hood' as it were demo!
Posted by HeavyArty on Friday, September 25, 2020 10:29 AM
Thanks guys.  It has been fun so far.  I hope to have some more pics of it all painted and installed soon.
    February 2011
Posted by GreySnake on Sunday, September 27, 2020 6:59 AM
Looking forward to seeing more progress, thanks for sharing.
Posted by HeavyArty on Tuesday, September 29, 2020 3:59 PM
Thanks GreySnake.
Work continues.  I have pretty much completed the engine compartment.  I just need to add a few decals and run a few wires here and there.
Here is the rear engine cover with it's fan and shroud for the radiator in the center; fuel filler pipe, and air cleaner and intake hose on the right.
The lower hull with the engine, transmission, intake fan, and battery box.  If you notice, the whole shift tower is attached to the transmission and does not pivot with the cab.  There is a square cut-out in the cab floor that this fits into as it closes.  You will also see a rod and gearbox across the front of the hull.  This is the cab lift mechanism.
With the rear engine cover in place.
This is how it will look with the cab in place.
More to come as I move on to the cab interior.
    January 2015
Posted by M. Brindos on Tuesday, September 29, 2020 8:20 PM
Loving it, Gino.
- Mike Brindos
Figure Painting Moderator -- Genessis-Models
    August 2020
Posted by Dodgy on Tuesday, September 29, 2020 9:53 PM
Don't know a lot about modern military vehicles, but this build is looking very impresive mate.
I long to live in a world where chickens can cross the road without having their motives questioned
    September 2018
Posted by Sergeant on Tuesday, September 29, 2020 9:59 PM
HeavyArty
Gino, are you doing this from memory or do you have photographs and drawings to work from? Are you planning to have a technician working on the equipment?
Harold
Posted by HeavyArty on Wednesday, September 30, 2020 6:55 AM
Thanks guys.  I am enjoying this one.
Sarge, it is a little of both.  I do have some TM pages and other referances to fill in what I don't remember.  I do remember quite a bit since I worked with MLRS launchers off and on for about 8 years.  It is amazing what you forget though.
    September 2018
Posted by Sergeant on Thursday, October 1, 2020 12:48 AM
HeavyArty
Sarge, it is a little of both.  I do have some TM pages and other referances to fill in what I don't remember.  I do remember quite a bit since I worked with MLRS launchers off and on for about 8 years.  It is amazing what you forget thouugh.
I am alway amazed at the level of detail and customizing you do on a model. It is fun to watch you work through a project. I read some place you have been building scale models for 40-years. I believe you learn a few things in that much time.
Harold
Posted by HeavyArty on Thursday, October 1, 2020 7:38 AM
Hi Harold.  Yes, I have been building pretty much non-stop since I was a kid and I am pushing 50 now.  I have two older brothers who built cars and planes and of course, I wanted to do what they did.  I guess I have picked up a few things over 40 plus years of building.
Posted by Gamera on Thursday, October 1, 2020 11:56 AM
That looks great!
You just need a mechanic figure!
    February 2011
Posted by GreySnake on Saturday, October 3, 2020 7:20 AM
The work on everything in the engine compartment is very impressive.
Posted by HeavyArty on Tuesday, October 6, 2020 8:09 AM
Thanks guys.  A mechanic is planned...eventually.
I am still plugging away at the build.  I have completed the cab interior.  I added a few parts from the Royal Models MLRS Update set.
From it, I used the seats with seat belts; hoses and filter apparatus for the NBC system; and a few other smaller PE and resin parts.  I also added a fire extinguisher from the spares box between the seats and a HALON fire extinguisher on the left side of the front wall.  The rest is from the kit, to include all warning placards.
Here is the completed cab interior.
Next up is the completed engine compartment with placards added and weathered.  I also added a HALON bottle on the front right as well.
Cab doors and the side engine compartment door interiors.
I have also completed the LLM (Loader/Launcher Module).  I added the internal lifting hook/hoist mechanism that attaches to the rocket pods from ones left over from a Dragon M270 kit.  For some reason, Trumpeter deleted these.  They are needed if you do not have the rocket pods uploaded.  They are hard to see, but they are in there.  Trumpeter has all the other internal parts included and nicely molded.
You can see the internal hook/hoist mechanism in this pic hanging from the cables below the booms, just above the rocket pods.  These hook onto the pods to lift them up onto the booms, then the booms retract to load them into the LLM.
The LLM overall.
Lastly, I will be adding the APU, A/C unit, and weapon mount from the Dragon M270A1 kit to make this a pretty current M270A1.
I am planning on making it a vehicle from 6-37 FA (MLRS), 2ID in South Korea in NATO camo.  It is just about ready for paint.  More to come later.
    September 2018
Posted by Sergeant on Tuesday, October 6, 2020 10:04 AM
Good morning Gino. Fascinating the way you break down the components of this model. I have only recently started to learn some of your technique. One I noticed today is the way you paint the seats with shading you create what looks like real material. I love the HALON fire extinguishers. Hand painting, adding wear and weathering to the interior, engine compartment and LLM in modular approach you have much greater control over the interior detail. That makes a lot of sense. I started using your method on my M109A2.
By the way I received a second AFV Club M109A2 and M109 L23 to make an M109A1. It will also have that cool resin engine you reviewed. It may be one of the few M109A1 models ever made. When my M109's are finished I will have the first three versions in the series.
Great work on your MLRS and good lessons for interior modeling.
Harold
Posted by Gamera on Tuesday, October 6, 2020 11:45 AM
That interior looks incredible- really nice work there.
And interesting, I'd wondered how you loaded the rockets into the thing- I had no idea they came in a pod that was loaded as a unit.
Posted by HeavyArty on Tuesday, October 6, 2020 3:27 PM
Thanks Harold.  I'm glad this build is helpful to you.  I'm looking forward to seeing your M109A1 build.  It should be nice.
Thanks Gamera.  Glad you learned something about the MLRS as well.  Another MLRS tidbit; the slang name for the M26 rocket pod container is "Six Pack" since it holds six rockets.  Too bad it isn't six cans of beer.  Wink
    September 2006
Posted by RBaer on Thursday, October 8, 2020 9:45 AM
Fine work so far!
"Six Pack": neat, send a sixer to a bad guy.
Apprentice rivet counter.
    June 2014
Posted by BrandonK on Thursday, October 8, 2020 9:59 AM
Man, those placards really add the details to the kit. Your attention to all the bits is amazing. I love the work.
BK
On the bench:
Tamiya 1/35 M4A3E8 "Fury" with crew,
1/32 Kittyhawk Kingfisher,
1/35 Meng Panther Ausf A Early,
1/48 Pro Modeller P-51C "Boise Bee"
On Deck:
Tamiya 1/48 F4U Birdcage,
1/25 Revell 32 Ford Coupe
1/12 Bandai "Mandolorian"
2022 Completed:
1/25 Revell 29 Highboy
1/48 Tamiya Sea Harrier
1/25 Revell 70 Boss 429 Mustang
Posted by HeavyArty on Thursday, October 8, 2020 12:31 PM
Thanks gents.  Unfortunately, I haven't had time to get it painted.  I hope to do so this weekend.  More to follow...
    February 2011
Posted by GreySnake on Wednesday, October 14, 2020 7:57 AM
You did excellent work on the interior and engine compartment.
Posted by HeavyArty on Thursday, October 15, 2020 7:25 AM
Thanks GreySnake.  I did get some paint on it last weekend, but life is getting in the way.  I am on an unplanned trip, so I won't get back to it for a couple weeks.
Posted by Gamera on Thursday, October 15, 2020 11:27 AM
Looking forward to seeing what you post when you get back to her.
Posted by HeavyArty on Sunday, October 25, 2020 9:37 AM
I have continued work on my M270A1 MLRS undergoing maintenance.
After a couple week break where I took an early trip to go meet my first grand daughter (she came a few weeks early and mom and she are doing wonderful), I am back at it.
I have painted all the parts in NATO camo and marked it as launcher C-22 from 6-37 FA (MLRS), 2ID in S. Korea.  I made the decals myself, including the Asian Royal Lions on the front of the cab, from home printer decal paper.
I added the A/C unit, APU, and MG mount from the Dragon M270A1 to bring it up to pretty current standards, about late 2015-early 2016 based on Load Test date of 23 OCT 15 on the side of the LLM.
I also added Combat ID Panels (CIPs) to the sides and front.
The doors and side engine access panel.
Next up is tracks, final assembly and a light weathering.  More to come soon.
    October 2019
Posted by Tanker-Builder on Sunday, October 25, 2020 10:49 AM
Hmmm;
 I stumbled on this. I will watch with interest.
Posted by HeavyArty on Sunday, October 25, 2020 5:54 PM
Glad to have you aboard.
    February 2011
Posted by GreySnake on Monday, October 26, 2020 12:46 PM
Those decals came out amazing.
Posted by HeavyArty on Monday, October 26, 2020 9:10 PM
Thanks GreySnake.  It is not hard to make them once you get the hang of it.
Posted by HeavyArty on Wednesday, October 28, 2020 8:23 AM
The M270A1 MLRS Launcher is complete. I weathered it with a couple washes of a dirt brown color and a lighter sand color to give it a well-maintained, slightly dirty look, as you find vehicles in the motor pool.
You can see below that I added the steering linkage from the steering parts under the cab to the transaxle. I also connected the wiring harness to the cab underside.
I highlighted the interior of the LLM with a bit of aluminum to bring out the details.   I also blackened the face of the LLM to represent the charring that occurs as the rockets are fired.
