Engine for theTamiya 1/35 M4 Sherman Tank Early
    November 2016
Posted by calmo2 on Tuesday, November 23, 2021 5:47 PM
Hello; I have been building cars for the last 4 years but would like to try building Armor for a change. My first attempt will be the Tamyia 1/35 scale A4 Sherman Tank Early. With all my previos cars, I like to wire and plumb the engine. I was wondering if anyone could tell me if the engine grills on this tank can be built in the open position or not. If they can be built in the open position is there any place out there where a guy can buy a 1/35 scale replica of the gas engine that went into this tank? As a neewbe I would appreciate any help from you guys and gals out that have been building armor for a while. Thanks Cal.
    May 2009
Posted by Pawel on Wednesday, November 24, 2021 1:52 AM
Hello!
Sherman engine is not something you see done often in scale - so if you take it on it will be very interesting to see. Now did you try a google search? I did and here's what I found:
This kit would probably be the easiest to buy and then build:
35321 CONTINENTAL R975 ENGINE – Miniart (miniart-models.com)
Then there are resin kits from CMK, Tank Workshop and Verlinden (Verlinden kits are hardest to get - no longer made - and also sometimes not very accurate).
Anyway, showing off this engine probably won't be a drop-in - would have to look up the instructions to see if you have to cut out at least some of the hatches/doors and you would probably have to scratchbuild some features of the open engine compartment like engine mounts and whatever else is installed there. Take a look at scalemates.com - this site will tell you all the possible accessories, many even have downloadable instructions and reviews to help you. Good luck with your project and have a nice day
PaweĊ‚
www.vietnam.net.pl
Posted by Rob Gronovius on Wednesday, November 24, 2021 12:38 PM
Once upon a time, Verlinden made the resin engine for the M4. It came in just the engine and entire compartment for the Tamiya M4 early. You might still be able to find it on eBay or other old stock.
https://www.scalemates.com/kits/verlinden-productions-1120-sherman-m4-engine-and-compartment-m4-tamiya--155911
Tank Workshop did one as well. https://www.scalemates.com/kits/tank-workshop-tws0035-radial-engine-and-engine-compartment--220200
I think they were not a lot of money back in the day.
Posted by HeavyArty on Wednesday, November 24, 2021 2:55 PM
Posted by CapnMac82 on Thursday, November 25, 2021 2:21 PM
The radial is a repourposed aircraft engine, so, you might have to look for aircraft model aftermarket--which will be complicated by those bing in 1/32 rather than 1/35.
Luckily refernce photos abound
    November 2016
Posted by calmo2 on Thursday, November 25, 2021 9:22 PM
Thanks guys: I realy apprciate all the info on this question. The info I got on the radial is that it was pre war. Then I found that there was also 3 other engines put in the Sherman. They were the "GM 6046 "twin" Diesel, the A57 Multibank, and the Ford GAA48 gas engine. I was hoping I could find the Ford GAA48, or the GM6046 Diesel.  I am thinking that one of these would fit in the engine compartment without a bunch of alterations. Maybe I am biteing off more than I can chew.LOL. Maybe I will just stick with just building the tank and let it go at that unless I can find a 1/35 scale of either one of the above engines. Thanks again guys for helping out a newbee to the model armor world.
Posted by Rob Gronovius on Thursday, November 25, 2021 10:01 PM
Well, yes, the "A-designation" of a Sherman tells you what engine it used. Unlike many other tanks, Shermans were produced in parallel lines because of engine availability not because they were more modern versions.
So the M4 and M4A1 only used the radial engine.
The M4A2 used the twin diesel engines and were used by the Marines and lend lease to Soviet Union.
The M4A3 used the Ford GAA engine and became the standard US tank in the later stages of the war.
And the M4A4 used the Chrysler multibank engine. It went to the UK, but they called it the Sherman V (or Roman numeral 5).
The Brits called the M4 the Sherman I, M4A1 Sherman II, M4A2 Sherman III, M4A3 Sherman IV and the M4A4 the Sherman V.
So the Tamiya M4 Sherman early can only use the radial engine. None of the Shermans are "pre-war" because they all came after the start of the war.
The radial engine Sherman was used during D-Day in the M4A1 Duplex Drive amphibious Sherman.
The M4A1 was also used Post War in the US, by Allies and many other nations. The Radial engine was used in the latest M4A1E8 (76) tank.
Posted by T26E4 on Friday, November 26, 2021 9:59 AM
Rye Field Model is about to release the Ford GAA Sherman tank engine as a stand alone plastic kit but it comes without the engine compartment.  These are only proper for M4A3.
As others have said, you need the Miniart Radial -- but you'll need to build up the engine compartment around it
Roy Chow
Join AMPS!
http://www.amps-armor.org
