oldermodelguy
Brace/support your brushing hand with your left hand. Or if on a bench a stack off book or something. Brace the hand but not so tight you aren't free to rotate it as need be.You'll get it once you see what I mean... I learned as a kid to support that hand, I had a schooldesk I built at and do brush painting and would place the side of the palm of my hand on the edge of the desk when painting small part or assembling small parts for that matter, like back arounf 1959 or 60. I had a friend about 3 years older than me who often had this stuff figured out. Amazing detail modeler, so I'd watch him and pick things up by sight.
I thin to where the paint flows off the brush, I don't know ecactly but maybe 30-40% retarder to paint. Lets put it this way, sometimes it needs two coats. So it's not a thick film going on. With all that retarder intial set time still isn't very long, it doesn't really run but overall cure is longer.
Good morning. I've been trying the bracing technique you suggested, and I think it is definitely helping keep my brush hand from being so jerky (fewer of those 'wild' zigs, sags, etc when I was just using just my unaided brush hand to 'poke motion' apply the paint). I rest my right elbow/upper forearm on my work desk and cradle my brush wrist but not that tightly. I think I asked a similar question on another thread a while back and you gave me similar advice (but I forgot about it; so thanks for having beared with the repeat question!)
Thanks, yes I clearly was not adding enough retarder previously, because my black paint for the road wheels was more like molasses (goopy) than the thinner film I need to be using. I find that the thin coat is easier to work with and doesn't get lumpy when applying it. In many cases, just a tiny jab motion is all that was needed to make the road wheels look more evenly painted from the side perspective.
I gave painting my hand tools a shot, and I think my end results are actually decent (they look like tools with distinct colors for shafts, handles, etc.). I basically was just using the specified two colors (metallic grey and flat earth). I'm already getting more used to how the paint behaves when applied to small surfaces like tools. For example, it doesn't really require sweeping brush strokes along the length of the tools, because capillary action tends to spread out the paint some. I learned the hard way that when painting tools that are vertical (the tools on the rear plate of my Sherman) that the paint will tend to seep downwards because of gravity and the capillary action: I ended up with a parallel line of metallic grey on the rear plate surface running below the actual long tool). So next time, I will adjust by putting just a tiny bit of paint on the tip of my brush so it hopefully doesn't spread out onto the tank's surface. I tried touching up this error by applying some olive drab paint; it is still noticeable but at least looks less apparent than before.
I've realized thatI have been mixing too much paint for these small painting jobs. I've stopped using disposable plastic pipettes to transfer from my paint bottles after stirring: instead, I just use the mixing tooth pick to drip paint into my palette wells (and do the same with the retarder-basically similar technique to what some of you folks have helpfully related to me).
One question I have: I ran into a problem where on one of the tools, the metallic grey dried as a black splotch on one half of the tool. I tried mixing the paint even more in my second painting session, and attempted to touch up the black, but it still wasn't completely going away. Finally, I tried using a toothpick to 'spread' the splotch around, and I found that this worked pretty well: I was able to stretch the silver tint over most of the remaining black. My question: what causes these color inmperfections: do I need to stir my paint longer than one minute (could insufficient mixing be the culprit)? OR is there just variation in the quality of some paints (I've been using Tamiya acrylic for my hand painting)? I know that shaking acrylic paint bottles is a no-no for airbrushing, but could shaking the bottles actually help to better mix the paint for hand painting (are air bubbles less of an issue when hand brushing?
So my results weren't bad with these two painting sessions, and I do think I am improving. I am actually encouraged, and suprised that the small bit of end product (tools) did not turn out terrible....Thanks for advising and reading about my experience. Next session I think I will try to paint some of the figures.
