Or, continuing on MJY65's line, If possible, go with a air hose from the compressor to a volume tank (air tank) in the house. The volume tank reduces flow fluctuations and you can isolate it if needs be. You could also put your painting reducer on the volume tank and keep the compressor a full working pressure for other things (pneumatic tools, filling tires, etc.). So, no appreciable noise, accessable air and the ability to vary your pressure / flow as needed for the medium you are spraying. A complete win / win situation.
