Here is a way to make your JLC saw even more useful than it already is. Those that already have one knows how super thin the blade is but the way the blade is held in the handle it may limit the depth of the cut depending on the situation. A Czech modeler I traded emails with a while back breaks off pieces and puts them in an Exacto handle. I found that is slides around a bit so I made a cut in a paint brush handle and CA’s the blade in the kerf and trimmed the side. Works great.
WARNING! These blades are fragile and can break easily. Wear protective eyewear when using. Particularly when breaking off pieces on purpose.
