Aircraft Work reviews
Posted by didfaI on Friday, January 2, 2004 2:46 PM
For the past year I've been relying on your "Browse-By-Subject" Aircraft list for info on different models. Each time I look for anything other than P-51, P-38, Bf-109, etc., there is no listings for A-26, P-61, T-28. You say that you're working on it, but I think no additions in over a year is not an indication of 'working on it'. I've tried to get info from your index, but sadly most of the ariticles are OOP. When are you going to update this section, if ever?Disapprove [V]
Posted by Anonymous on Monday, January 5, 2004 10:40 AM
The Browse-By-Subject function is what the name implies: a very quick, broad search function. As it's presently configured, it covers material going back only to the Dec. 2000 issue, and it's designed to hit only popular subjects. There are no listings for the A-26 or P-61 because we haven't done a feature article or Workbench Review on either of those aircraft since 12/2000. The
We have to manually add identifier codes to each article's entry in the table of contents; the code set for specific aircraft or vehicles is limited to the most common subjects (the T-28 is not one of them, but A-26 and P-61 are).
As each new issue is added to the site, we add the browse codes, but I suspect we may never go back and add them to the pre-2001 material because it seems to be adequately covered by the site search function http://www.finescale.com/fsm/search/Default.asp?mode=advanced&search= and the magazine index http://www.finescale.com/fsm/html/TheMagazine/MagazinesIndex/MagazinesIndex.asp (for that I *do* want to compile a new cumulative index).
