Question for DVoss...
Posted by BlackWolf3945 on Wednesday, June 30, 2004 8:05 PM
When using images as part of a hyperlink in one's sig, why doesn't the cursor change to the pointing finger-thingy when it passes over said imagesQuestion [?]
Fade to Black...
Posted by David Voss on Wednesday, June 30, 2004 11:04 PM
It only appears on the images which have been forced to display smaller than they really are. It's supposed to help indicate the image is clickable (to view the full size).
Example...
Image #1 is 70 pixels wide x 50 pixels high.
Image #2 is 480 pixels wide x 348 pixels high. Because it's width is greater than 350 pixels, there's a javascript function which tells the browser to display it as 350 x 254 instead of it's original dimensions. Although the dimensions within the browser has been changed, the actual file size has not changed.
Did I lose anyone -- show of hands if you're still confused. Wink [;)]
David Voss Senior Web Developer Kalmbach Publishing Co. Join me on the FSM Map
    September 2003
Posted by roadkill_275 on Thursday, July 1, 2004 1:57 AM
Thats a good looking Lightning there David. Did you build it?
Kevin M. Bodkins "Meddle not in the affairs of dragons, for thou art crunchy and taste good with ketchup" American By Birth, Southern By the Grace of God! www.milavia.com Christian Modelers For McCain
Posted by David Voss on Thursday, July 1, 2004 10:03 AM
I wish!
I took it off the homepage. It links to the a review for Trumpeter's 1/32 scale Lightning.
Posted by BlackWolf3945 on Friday, July 2, 2004 1:51 PM
Geez, I already knew that. But that's not what I'm asking.
I just want to know why the cursor doesn't change while passing over the smiley or other images in my sig, while it does change, say, for the smilies in that conspiracy thread...
Fade to Black...
Posted by David Voss on Friday, July 2, 2004 2:41 PM
Blush [:I]
Oh, I didn't realize those were links. I see what you're talking about now. I find that interestingly odd and to be honest, I don't have an answer at the moment.
Posted by BlackWolf3945 on Friday, July 2, 2004 6:43 PM
Okay, no prob! Was just curious.
However, I do expect a solution by noon-ish (your time) on Monday... Wink [;)]Tongue [:P]
Fade to Black...
